VWVortex.com - 09 TSI GTI Fault Code: P2015 w/ apr stage 1 .. who has experience with the repair?
    Results 1 to 7 of 7
    Thread: 09 TSI GTI Fault Code: P2015 w/ apr stage 1 .. who has experience with the repair?
    1. Member bannedforlife's Avatar
      Oct 17th, 2009
      Hudson Valley, NY
      09 GTI
      10-08-2010 05:08 PM #1
      Wondering if the fix at the dealer will possibly involve an ecu update that will erase the APR programming.
      I've read mixed things, this is the only code my car is throwing .. does anyone have experience with this specific situation?
      Thanks in Advance!
    2. Semi-n00b My1stVDUB's Avatar
      Nov 16th, 2009
      West Haven, CT
      2009 VW Jetta Wolfsburg
      10-22-2010 04:06 PM #2
      No..I was throwing that same code (P2015) about 2 months ago..took it to the dealership and found out it was an intake manifold problem. They replaced it for free and it was all covered under warranty. I wouldn't worry about the ECU reflashing...even if the dealership does do it, you can go back to the shop that orginially flashed you and they should do it again for free, since you have already bought the program.
      2009 VW Jetta Wolfsburg 2.0T DSG
      APR Stage 1, Neuspeed P Flo, H&R Sport Springs, 20% Tint, Kenwood DNX-5140 HU, Alpine MRP-M450 Amp, Alpine SWR-1042D, NSP Boost Gauge
    3. 10-23-2010 12:32 AM #3
      I think this was the code I threw a couple months back. Had to do with failure with some flapper motor for the intake manifold. They replaced everything under warranty. Mind you I have an aftermarket intake, tune, DV, boost gauge, etc. installed and they had no problem.
      It's apparently a trended issue with VWoA, and will probably wind up being a recall at this rate.
      2013 Ford Focus ST3 // 2015 Honda CR-V EX-L AWD // 2009 Honda Civic EX-L
    4. Member bannedforlife's Avatar
      Oct 17th, 2009
      Hudson Valley, NY
      09 GTI
      10-23-2010 10:00 PM #4
      Thanks for the help everyone.
    5. Member dudeman08's Avatar
      Feb 22nd, 2009
      Philadelphia, PA
      1998 VW Jetta, 1967 Buick Sportwagon, 1972 Plymouth Valiant 4dr (F/S), 2009 VW Jetta GLI
      10-25-2010 05:15 PM #5
      im guessing i should look forward to having this problem when i get my 09 GLI?
    6. Member bannedforlife's Avatar
      Oct 17th, 2009
      Hudson Valley, NY
      09 GTI
      10-25-2010 06:39 PM #6
      possibly. not a big deal to fix, and it should easily be under warranty.
    7. Member toddhought's Avatar
      Jul 13th, 2006
      Chandler, AZ
      2010 DBM GTI
      10-28-2010 06:53 PM #7
      I had the same code on my 2010 GTI about 3 weeks after I got it, it's a short wiring harness to the TB, new harness didn't fix it, but re-routing the wiring to add a bit more slack in the wires did. It's a really close fit, and when the engine heats up, the wires come loose and lose contact.
