VWVortex.com - G60 to Xflow turbo build
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 57
    Thread: G60 to Xflow turbo build
    1. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      GLI X-Flow, ITB MK2, 8vTcoupe
      10-09-2010 03:03 PM #1
      My g60 to X-flow turbo (goal is 180-220 WHP daily)
      I had rebuilt a G60 to stage 4 or 5 or whatever it had every possible bolt on and some mild head work and it was a fun car but after blowing up 2 gladders in the same year I regretted my decision to make my daily GLI a g60 so I ripped the g60 out and installed a new obd1 Xflow for the family car...
      So I decided to make a hybrid Xflow pg turbo and throw it in the coupe that was sitting on the side of my house, because I did not feel there was a kit that would meet my needs for the price I was willing to pay I spent roughly 8 months piecing the parts I would need and have mostly completed the mock up stages.
      I’m looking to make 200 WHP or somewhere in that area with the parts I have. I figure my g60 was around 160-170 WHP on a good day so a little bump in HP and the ease of changing the parts and availability is well worth it in my opinion.
      parts list I used
      Bottom end PG from g60 1.8
      x-flow obd1 head welded surfaced then drilled
      BBM 268/260 cam
      Autotech adjustable cam gear (no longer sold they make a newer lighter one now)
      Arp head studs
      G60 head gasket
      BFI turbo oil pan
      Oil catch can (ebay)
      Innovative wideband for tuning
      VDO boost gauge
      Oil feed line to turbo is 24in from oil filter flange
      Oil return line I used SS braided line to the BFI oil pan
      V belt alt custom mounting 940mm vbelt
      V belt crank and water pump gear
      Beetle valve cover breather oil cap
      MK4 intake manifold
      Mk4 valve cover
      g60 injectors
      Adapter from mk4 manifold to g60 throttle body
      Adapter from throttle body to 3in round
      Solid IC piping from TB to IC (this was a bbm tube refit)
      Forge BOV
      Forge manual boost controller
      Spearco FMIC
      Solid pipe from IC to turbo
      CAI (this was a refit from BBM no longer on there site)
      Kinetics cast 8v turbo manifold with external waste gate
      Tial 38mm waste gate
      Garrett t3 .42 (baby turbo)
      Alot of custom sized silicone couplers (ebay)
      2in header wrap with black sealer paint
      T3 4bolt down pipe 2.5in with 2 o2 bungs (custom refit from ATP)
      Waste gate dump tube (ebay)
      2-¼ Euro sport exhaust with cat delete
      16v Passat duel fan shroud on a factory mk2 radiator capped the end
      Factory mk3 cross flow hoses route the cooling (exception I used mk2 water pump to oil cooler and mk2 heater hose to metal line)
      Digi 1 ecu and harness with custom chip
      lightened flywheel 16v pressure plate 020 trans with shift kit
      Mostly painted with cr@p ceramic paint
      So this is how the test fit went this week as I received parts to put on =)
      So I'm waiting on some pieces to come in from UPS this week and hopefully next few weekend's I will be able to start it So during the next few week's I will sand the tubing if there is a nice day to paint and I need to get some header wrap for the down-pipe and put the wiring harnesses back into it
      Some info I have came across while doing the build.
      G60 injectors are 26lb
      Adding more than a 3.5 bar fpr could make your injectors not fire or over-spray
      Digi 1 ecu with factory map can only handle 15psi (some people push the bar to 18psi)
      SNS has the best ability to custom burn a chip
      Stock clutch and 020 is good for 150-170ish WHP
      MK4 manifolds need support made when installing without the factory heat shield
      To do V-belt on a pg bottom end you need to customize your alt bracktery
      To do aba xflow alt on pg bottom end you need vr6 water pump pulley g60 crank pulley and to make a adapter for the alt to bolt to
      If any information is incorrect please let me know.
    2. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      10-14-2010 12:34 AM #2
      Update:
      finished lower manifold and bosch injectors in the mk4 manifold and got it painted up also got the manifold turbo and waste-gate all painted along with the boost tubes and TB
      really just need to finish the down pipe
    3. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      10-16-2010 03:21 PM #3
      Lunchtime
      got some of the wiring installed just waiting for a few more parts I ended up with a 940mm V belt and had to modify the alt bracket finished up the cold air intake and boost tubes also got my BFI oil pan and my wide-band so after lunch it will be more work
    4. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      10-24-2010 07:46 PM #4
      Got the down pipe pieces this week now I just need to wrap it and put it in
      Down pipe work
    5. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      10-25-2010 12:04 PM #5
      Wrapped and mounted with both o2 sensors in place
      Also got my eurosport wires and did a rear disc conversion whiel I was waiting for a few more parts to show up
    6. Member pendulum's Avatar
      Apr 29th, 2001
      WA
      a 3, a 5, and a domestic
      10-25-2010 03:42 PM #6
      subscribed
      I like the work you're doing, especially with coating & wrapping the tubing. Looks clean
      Mar 31st, 2008
      PNW - Oregon
      10-26-2010 11:25 AM #7
      2 door jetta
    8. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      10-26-2010 12:20 PM #9
      So I have been testing a New south power gasket for the X-flow head on my family car and I can say they work.
      Redneck Test #1 went car came home from 1hr drive and I cant put my hand on the intake manifold and hold it there its just to hot
      So off it all came and ceramic painted wrapped the mk4 tubular manifold and added a new south performance gasket
      Redneck test #2 went drove around for an hr I immediately noticed my wide-band was reading differently at WOT it was slightly leaner than before without the gasket so pulling over every so often to check and see if I can tell a difference in the manifold temps I was simply amazed in how cool to the touch it was.
      Conclusion: I felt a power difference it smoothed out my idle increased my gas mileage smoothed out my cruising AFR and WOT AFR, now I don't have a dyno or a datalog because it is a AEM wide-band on OBD1 and dyno time just isn't in this cars future
      Now to order another one for the turbo build
      And pics or it didn't happen
    9. Member pendulum's Avatar
      Apr 29th, 2001
      WA
      10-26-2010 12:47 PM #10
      interesting.
      why does a gasket affect driveability? did you use a thicker one to lower compression or something?
    10. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      10-26-2010 12:50 PM #12
      you can barely see it in my pic but if you look closely at the head/manifold the gasket is about the thickness of 2-3 quarters stacked up
    11. Member pendulum's Avatar
      Apr 29th, 2001
      WA
      10-26-2010 12:52 PM #13
      How does that add power though? (reading the link it shows a dyno graph of a 10 hp gain just from a gasket)
    12. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      10-26-2010 12:54 PM #14
      There is also this style which I have on my ITB counterflow car and it is alot thicker not sure if it works any better it also uses 2 gaskets and longer studs.
      no picture is available of the 8v counterflow one
      http://www.evolutiontuning.com/evohe...ds18SOHC8V.htm
      this link has picture of the xflow showing the 2 gaskets and hardware
      http://www.evolutiontuning.com/evohe...ds20SOHC8V.htm
    13. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      10-26-2010 12:56 PM #15
      Quote Originally Posted by pendulum View Post
      Better explanation from there web site
      NewSouth Performance has designed an insulating gasket that radically reduces the heat transfer from the cylinder head to the intake manifold.
      PowerGasket Plus™ gives you up to 5% more power from your engine by reducing the temperature of the incoming air to your engine. This gives you cooler, denser air for more horsepower and performance from your engine.
      The PowerGasket Plus™ is made from a purpose-built high performance composite material. It conducts on average less than 1/500th of the heat of the steel gasket that it replaces. Your intake manifold will stay 30-50° F cooler and your incoming air will stay 20-30° F cooler.
      Cooler air, denser air, means more oxygen. Your engine sensors register these changes and will inject more fuel to give you more power. Cooler air also reduces detonation, so you can turn up the boost or advance your engine timing for even more performance gains.
      http://www.newsouthperformance.com/gasket.htm
    14. Member pendulum's Avatar
      Apr 29th, 2001
      WA
      10-26-2010 03:48 PM #16
      Quote Originally Posted by Svedka View Post
      interesting, thanks!
      edit: doh! don't have them for the 16v
    15. Member pendulum's Avatar
      Apr 29th, 2001
      WA
      10-27-2010 01:09 PM #18
    16. Member papo98jetta's Avatar
      Dec 10th, 2008
      Homestead, Florida
      98 Jetta 2.0T
      10-27-2010 01:44 PM #19
      Nice
      ABA Turbo Club
      228hp 271tq at 14psi with pte GT3561E
    17. Junior Member
      Feb 11th, 2008
      indiana pa
      89 e30 90 corrado
      10-30-2010 02:05 PM #20
      I'm in the middle of the same project. I'm hoping for around 200hp using a very small turbo. Can you give me more info on what chip your using? and are you sticking with the stock fpr?
    18. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      10-30-2010 02:55 PM #21
      stock fpr with a custom burnt chip similar to the SNS one
    19. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      11-07-2010 03:39 PM #22
      Update: Got a few things sorted out
      got my alt stuff finished up vbelt with 940mm belt
      Also took my dump tube back off and painted/wrapped it
      finished my SS oil return line ended up about $60. If I was to do it again I would weld my own bung onto a pan and have a custom line made to fit with less fitting's. I did not like the fact that most just drape around the axel so well see if mine works ok or if I have to drape it around the axel. Had to make a bracket to hold it to the block.
      Just a few little details to finish up
    20. Member Svedka's Avatar
      Jul 3rd, 2008
      Gig-Harbor WA,
      11-11-2010 09:09 PM #23
      Gauges installed just need the boost controller to mount in there somewhere now
    21. 11-11-2010 09:21 PM #24
      looks great now if only i could get my wiring done
