Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 140
Thread: Rota Grid 18x9.5s all around?
  1. Member MobMotorsports's Avatar
    Jul 5th, 2006
    Denver
    MKIV BMP R32
    10-12-2010 08:44 PM #1
    I know wheel fitment questions on here suck but I really dig these.
    Will 18x9.5 Rota Grids fit all around with spacers? Thinking with some 235/40 Winter tires.
    http://www.wheeldude.com/catalog/pro...ba758ac1db1c87
  2. Member gdown's Avatar
    Aug 30th, 2004
    Asheville
    BMP R
    10-12-2010 09:12 PM #2
    I am by no means an expert on the subject, but I think they may be too wide. Great looking wheel though.
  3. Member Harepower's Avatar
    Jan 23rd, 2007
    Eagleville, TN
    07 Silverado, 2012 Forestor
    10-12-2010 09:18 PM #3
    Too wide.
  4. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    10-12-2010 09:36 PM #4
    Quote Originally Posted by Harepower View Post
    Too wide.
    negative ghostrider....
    im running 9.5" all the way around on my R....daily...dropped on its nuts
  5. Member MobMotorsports's Avatar
    Jul 5th, 2006
    Denver
    MKIV BMP R32
    10-12-2010 09:37 PM #5
    Nice. Specs and pics?
  6. Member TurboREX's Avatar
    Aug 6th, 2006
    NYC
    .:Ruined
    10-12-2010 09:38 PM #6
    Quote Originally Posted by fouckhest View Post
    and it looks soooo dope. care to share offsets?
  7. Member Harepower's Avatar
    Jan 23rd, 2007
    Eagleville, TN
    10-12-2010 09:41 PM #7
    more details are needed, ET, and the tires please? You have no rubbing?
    my 235/40/18 BFG G-force sports have no more than 3/4" celarance from the rear struts.
    I'm on 18x 8.5" rims, stock suspension with Bilstein HD struts, no spacers, and I do not have room for an extra 5mm to run w/o rubbing.
    I;m certain the "dropped on it's nuts" is a factor here.
    So without your info I can still say you cannot safely run 9.5" rims w/o spacers and fender rolling or without severely aletered suspension.
  8. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    10-12-2010 09:41 PM #8
    Quote Originally Posted by TurboREX View Post
    thanks mate....
    wheels are 18x9.5 et 30...after spacers, finals are et24 & et10
  9. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    10-12-2010 09:50 PM #9
    read above....plus i will add nothing crazy done to the suspension....just spun down, no perches in rear...fenders rolled up front....215/40s all around....its ALL about the offsets
  10. Member Harepower's Avatar
    Jan 23rd, 2007
    Eagleville, TN
    10-12-2010 09:53 PM #10
    and running stretched tires, and spacers, and fender rolling anything is possible with some work. Seems to defeat the purpose of the car to me, but to each our own.
  11. Member MobMotorsports's Avatar
    Jul 5th, 2006
    Denver
    MKIV BMP R32
    10-12-2010 09:55 PM #11
    So would the Rotas fit?
    I agree your ride sits perfect.
  12. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    10-12-2010 09:59 PM #12
    agreed...my R is my daily...if i want to go fast i have another car for that
    Quote Originally Posted by MobMotorsports View Post
    yes, in theory, they will fit, just depends on the tires, spacers in relation to how low you want to be....
    thanks
  13. Member Navydub's Avatar
    Sep 29th, 2006
    Pleasant Prairie, WI
    Saab STi and a Land Rover
    10-12-2010 10:20 PM #13
    With these wheels I think you'd be better served to run them a bit more narrow with a lower offset to get the concave effect. Vice wider with a higher offset and less concavity. Just my .02
    Turbo Unicorn | HS Tuning | 42DD | Cabin Krew
  14. Member MobMotorsports's Avatar
    Jul 5th, 2006
    Denver
    MKIV BMP R32
    10-12-2010 10:23 PM #14
    Good point but those are pretty deep. Check out the photos lower on the page.
  15. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    10-13-2010 12:53 PM #15
    They will fit with some 215/40/18's and 20mm spacers. You will also need to be low and have rolled fenders to pull them off.
  16. Member Navydub's Avatar
    Sep 29th, 2006
    10-13-2010 01:08 PM #16
    Quote Originally Posted by DarkSideGTI View Post
    20mm spacers?! He's gonna have mexi poke up front
  17. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    10-13-2010 01:11 PM #17
    18x9.5 et18
  18. Member Dez R32's Avatar
    Nov 4th, 2004
    South Florida
    2004 VW DBP .:R32 : 2004 HONDA CBR 600RR
    10-13-2010 01:53 PM #18
  19. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    10-13-2010 01:58 PM #19
    Quote Originally Posted by Navydub View Post
    et24 & et10
  20. Member VWPOPS's Avatar
    May 8th, 2010
    Orlando, FL
    10-13-2010 02:16 PM #20
    Pulling off the grids nicely.
  21. 10-13-2010 02:37 PM #21
    NIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII IIIIIIIIIIIIIIICE...!!!
  22. Member RubMyDub2004's Avatar
    Dec 25th, 2007
    Boston MA
    2008 LR STi
    10-13-2010 03:43 PM #22
    I spoke for a long time with Zoeb about trying to get a few sets of these to fit out cars properly. As of now it takes A LOT of fitment tweaks to get the fronts to fit. Due to our set up the fronts would poke an INSANE amount. I remember one member in UK running them for a bit. But he had body work done to pull the fenders out.
    fouckhest yes you are running 9.5 all around.. but you didn't take in account your offset IS FAR different from these.
    I had thought about doing was running a custom staggered set up of the 8.5 grids up front and the 9.5 or new 10s in the rear.
    2004 RS .:R32 WFC: Rota G-forces/ FK silverlines/ Unitronic 1+/ K&N Typhoon/ BMP Roof/ M3 Tails/ Hella Celis/ Flapper Mod_Res Delete SOLD
    2008 Lightening Red STi
    www.chrisprovostdesign.com
  23. Member MobMotorsports's Avatar
    Jul 5th, 2006
    Denver
    MKIV BMP R32
    10-13-2010 03:51 PM #23
    I think youre right. 8.5s in the front and 10s in the rear may be the best option here.
  24. Banner Advertiser xbluewaterx's Avatar
    Jul 20th, 2006
    Denver, CO
    10 VW GTI 2.0T, 04 VW Turbo R32, 06 Audi A4 Avant, 1990 VW Corrado
    10-13-2010 03:57 PM #24
    Yep just make sure you get the correct offset.
  25. Member RubMyDub2004's Avatar
    Dec 25th, 2007
    Boston MA
    2008 LR STi
    10-13-2010 04:02 PM #25
    I literally have NO clearance between my coils and my wheels.. with a 18x9 +35 and a 5 mm spacer.
    I can email Zoeb and see what he has in the factory for a staggered set up in the same color. Hopefully he can pull out the 2 different sizes.
  26. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    10-13-2010 04:56 PM #26
    Quote Originally Posted by RubMyDub2004 View Post
    guys it can be done...just depends on how badly you want to run the wheels...my buddy mike olson has been running them all year...same wheels....9.5" all 4 corners
    http://euromedian.net/2010/09/30/a-l...a-bit-more-go/
  27. Member MobMotorsports's Avatar
    Jul 5th, 2006
    Denver
    MKIV BMP R32
    10-13-2010 05:10 PM #27
    Well that answers that. He's even running the ECS Stg5 big brake kit and 225/40s.
  28. Member RubMyDub2004's Avatar
    Dec 25th, 2007
    Boston MA
    2008 LR STi
    10-13-2010 05:13 PM #28
    I already said it CAN be done and that is has, didn't say you couldn't. I just said it would be easier not too, Te et38 is helpful, with a 5mm spacer you could do it with a fender roll and slight pull, but 225s.. no 235, they might rub the coil.
  29. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-13-2010 06:42 PM #29
    WTF... seat the bead much?
    Suspension travel? none.. Cornering capability? None.. Pothole survivability? None.. Stereo-typing the mee too, trend following kid that you are? Perfect..
    All offenses with no apologies, that is retarded!!
    -Josh
    444hp/413tq - bone stock, all motor, Volkswagen.
  30. Banner Advertiser xbluewaterx's Avatar
    Jul 20th, 2006
    Denver, CO
    10-13-2010 06:46 PM #30
    to the last post that was great Josh.
  31. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    10-13-2010 07:10 PM #31
    Quote Originally Posted by PowerDubs View Post
    see below.....for the record i drove the car to OCMD from SC like that and had no issues....so have fun with your stereo-typing
  32. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-13-2010 07:18 PM #32
    Wow, it survived driving down the highway in the summer? I'm impressed. Not as much as your other 20-something friends who like to hang out in parking lots and pop hoods.
    -Josh
  33. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    10-13-2010 07:21 PM #33
    im just going to leave that comment alone....you are obviously one of the famous vortex "i know all types"....
    have fun knowing it all
  34. Member xVolksR32x's Avatar
    Aug 11th, 2006
    Ellicott City, Maryland
    MKIV R32 DBP
    10-13-2010 07:30 PM #34
    im pretty sure he is saying its not a daily driver. However you claimed that you dd it. All bs aside it looks like it doesnt fit right. Float your boat however you like though
  35. Member TurboREX's Avatar
    Aug 6th, 2006
    NYC
    .:Ruined
    10-13-2010 07:34 PM #35
    its alright p dubs hates everyone who doesnt track their R, btw doesnt a reg gti/golf like the 20th pictured and mike's have different clearances than the R? ie a 9.5 wheel with 20 offset on a gti would be flush to the fender and on a R it would poke?
