Results 1 to 14 of 14
Thread: The ominious Megasquirt 3x Want to start a how-to
  1. 10-14-2010 01:29 PM #1
    Okay so I've been working on rebuilding the engine of a 2000 AEB golf I shaved and balanced rods put new pistons and new valves and all gaskets a stainless manifold with t/3 turbo big front mount ic and now the ECU is bad so time for mega-squirt. I want to run 3x but haven't found any reliable information on whether or not it will work with the stock instrument cluster and whether or not some form of IAC configuration is needed. I am planning on posting an in depth thread for the conversion from stock ECU so any help would be appreciated
  2. Member CDJetta's Avatar
    May 11th, 2004
    Melbourne, FL.
    1998 Jetta TDI, 1997 Audi A4 VR6, 1987 Scirocco 16v, 1978 Mercedes 450 SLC
    10-14-2010 04:40 PM #2
    For 2000 it should work fine, I don't see why not. The cluster just needs certain voltages going to it so splicing into the factory interior harness should be easy, it's just making sure the outputs of your MS are the same as the inputs for the cluster.
  3. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 mom wagon
    10-14-2010 06:18 PM #3
    IAC is up to you and how youll be using the car
    im not familiar with how the mk4 cluster gets its info, but you can build output circuits to feed rpm to clusters, im not sure how the mk4 cluster gets temperature or vehicle speed though.
    consider also how this affects the abs system...
  4. 11-13-2010 01:07 AM #4
    Okay, I converted the drive by wire to cable TB from a 94 jetta 2.0. Now I have the MS3 hooked up and I'm putting in all of the sensor values and details, so I have a few questions... First off, what is the style of Cam sensor wheel I know it is a hall effect but how many teeth and how many missing also what about the crank wheel, I believe its a VR but I cant seem to find accurate data on any of the specs also what angle BTDC? I am hoping someone who has done this before will know. I also am not quite sure how to hook up the IAC motor (also from the 94 jetta 2.0) it is a two wire and on the wiring diagram from the jetta it shows both wires connecting to the ECU but on the ms3 one wire goes to the ECU and the other to 12v. Also if anyone has a tune started or something i can go off of that would be nice to have. As I am planning on writing up a full thread for anyone else wanting to megasquirt their 1.8t any help is appreciated and will be reciprocated once I get all of the bugs and small details worked out. Thanks.
  5. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    11-13-2010 07:48 AM #5
    Quote Originally Posted by 5yearplan View Post
    The cam sensor wheel needs to be modified to work with MS. It has 4 teeth on it 2 big and 2 small and you need to cut off both big teeth and the small tooth that is passing through the sensor at TDC. The crank wheel is VR 60-2 teeth with a #1 tooth angle of 78 degrees. The ABA IAC does need 12v on one leg and the other to MS. Run it at 95Hz. I have a couple of msqs kicking around shoot me a PM with your email and I'll send you one.
    The Professor
    Melbourne, FL
    92 Corrado OBD2 ABA Powered by MS3Pro
    M & L EFI Performance
  6. 11-13-2010 10:55 AM #6
    Thanks, PM sent. So how did you wire up your two wire IAC to the ms3x? do I ground the other contact or hook it up to the ms3 sensor ground
  7. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    11-21-2010 08:43 AM #7
    Neither, 12V to pin 1(on the IAC) and pin2 to idle(pin 9) on the MS3X DB37.
    The Professor
    Melbourne, FL
  8. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    11-21-2010 12:59 PM #8
    If you're using a full AEB, it should already have the single pulse cam sensor. It's a hall, not sure if that was posted earlier.
    IAC ~100hz is perfect, just over 30% dc is a good start for warm, more for cold.
    I think a 2000 still uses a tach wire that can be driven from the MS. I know there was on a 99 2L.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  9. Member bluebug300's Avatar
    Jun 30th, 2007
    Barbados
    16v mk2 , 16v mk3
    08-11-2012 09:17 AM #9
    hey guys i NEED some assistance
    I have a mk3 and i've converted to the mk4 dash and complete wiring harness (headlight to brake light). I want to install a MSv3.57 which i previously ran in my 16v mk2.
    1. How do i splice the ms wiring into the mk4 stuff?
    2. Do i need to convert to coil packs or can i retain the dist?
    3. How do i fix the rpm signal prob?
    T.I.A
  10. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    08-11-2012 01:07 PM #10
    Quote Originally Posted by bluebug300 View Post
    T.I.A
    First off, MS1 MS2 or MS3?
    What motor is in the car?
    The Professor
    Melbourne, FL
  11. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    08-11-2012 02:31 PM #11
    Exact year of the gauge cluster would help too.
    -Paul
  12. Member bluebug300's Avatar
    Jun 30th, 2007
    Barbados
    16v mk2 , 16v mk3
    08-12-2012 11:19 AM #12
    Quote Originally Posted by Prof315 View Post
    MS1 version 3.57
    It's a 2.0 16v with ITBs
    Im not sure what year it is but maybe these numbers mean something?
    A few shots of the old 1.8
  13. Member bluebug300's Avatar
    Jun 30th, 2007
    Barbados
    16v mk2 , 16v mk3
    08-19-2012 11:29 PM #13
    Bump
  14. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    08-20-2012 01:22 PM #14
    No clue on the year but it looks late model from the gauge style, my wife's 04 looked like that. 99-00 would be a better bet.
    -Paul
