Results 1 to 12 of 12
Thread: At what power levels are a "worked" set of ABA rods obsolete?
    Nov 18th, 2007
    Chattanooga, TN
    1992 MR2 turbo
    10-15-2010 03:35 PM #1
    Everyone knows that ABA rods are GOOD in stock form, at what point would a set of shotpeened/magnafluxed/resized/balanced stock ABA rods NOT be up to the task?
    Im talking about high HP on a daily basis (boost obviously is the name of the game here).
  2. Member CrankDaBewstmun's Avatar
    Jul 23rd, 2008
    MA
    1991 GTI ABA 8VT, 1987 Scirocco 16V, 2000 GTI 1.8T K04, 2007 B6 Wagon chipped
    10-15-2010 04:28 PM #2
    I have stock rods in my aba-T. 12-15 psi for two years now. Not driven all year round though, car gets stored over the winter. Dynoed at the wheels 178 hp, 240 ft-lbs.
    If you are going stock rods:
    1. Use ARP bolts on the rod caps (have big end re-sized after install). I did not do this but I bet it would increase strength. I'm doing this for a 16VT project (already done just need to put the motor together)
    2. Like you said any additional processing is likely to help strength such as shot peening, balancing etc.
    Big reason that rods blow through blocks=Over-revving. If you properly size the turbo, you can keep the rev range down, make lots of torque low to mid rpm and have fun without blowing stuff up. All it takes is a mis-shift to over-rev and break things.
    Read up on how inertial forces work inside an IC engine. You would be surprised how rpm increases the load (forces) exponentially on connecting rods vs. actual output power increasing. I read this in Corky Bells book called "maximum boost". Great read
  3. Member Jay-Bee's Avatar
    Sep 22nd, 2007
    North Alberta
    B7 A4 Avant 2.0T
    10-15-2010 06:01 PM #3
    See SalsaGTI's 2.0T for any concerns on power, 300+ whp on stock ABA bottom end, however ANY build can fail if the recipe is off.
    I read this in Samuel L. Jackson's voice to make it more interesting. That's all I got.
    2007 A4 Avant 2.0T Q/MT
    2000 VW Golf 2.0 [Sold]
    Nov 18th, 2007
    Chattanooga, TN
    1992 MR2 turbo
    10-15-2010 09:38 PM #4
    arp hardware would be a given, i forgot to mention that, 400hp is the goal here, i wont be converting to solid lifters or anything like that so the revs will be kept to a max of 6500.
    so the largest benefit of going to, say, a set of IE rods would be weight savings?
    Sep 10th, 2011
    jupiter fl
    1997 jetta trek II 2.slo 04 lincoln towncar
    04-23-2012 09:07 PM #5
    when installing arp rod bots it is required to have the rods resized goodluck if you diddnt
  6. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    04-24-2012 11:26 AM #6
    Quote Originally Posted by nextproject View Post
    No IE rods (and Scat Rods for that matter) use ARP 2000 Cap screws,much stronger than even ARP pro series rod bolts. A bottom end, properly built with IE or scat rods and good pistons should be just about bulletproof.
    The Professor
    Melbourne, FL
    M & L EFI Performance
  7. Moderator root beer's Avatar
    Jun 22nd, 2004
    Linthicum, MD
    96 Golf 83 Scirocco
    04-26-2012 11:51 AM #7
    I'm going to see what stock rods with ARP's jammed in can handle with nitrous. Not the same torque curve as you turbo folk, but i'm betting they'll hold 350whp.
  8. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    04-26-2012 12:08 PM #8
    FYI, ARP 5/16" 289 Ford rod bolts also fit. A set of 8 pro series wave locs costs about the same as a standard knurled VW set. MUCH stronger.
    The Professor
    Melbourne, FL
  9. Member Salsa GTI's Avatar
    Aug 29th, 2000
    Upper Saucon,PA
    2000 GTI VR6 ....... A founding Member of the 8v 300+whp Club
    04-26-2012 02:14 PM #10
    I was going to go for 400 wheel with stock everything on the bottom of an obd2 ABA
    but my life got in the way and i sold the car and stopped vortexing...
  10. Member Salsa GTI's Avatar
    Aug 29th, 2000
    Upper Saucon,PA
    04-26-2012 02:15 PM #11
    Quote Originally Posted by Jay-Bee View Post
    320whp to be exact
    and anything can fail with a chip tune...OOps did i say that...LOL
  11. Moderator root beer's Avatar
    Jun 22nd, 2004
    Linthicum, MD
    96 Golf 83 Scirocco
    04-26-2012 02:16 PM #12
    Come on man, sell the car whatever, but don't stop vortexing
    I keep having to find new armpits of the forum where people might not suck.
