Page 1 of 2 1 2 LastLast
Results 1 to 35 of 36
Thread: DIY: Airlift 1000 for Lowered Car (or how to adjust rear height in seconds with coilovers)
  1. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    10-16-2010 09:10 PM #1
    This is not the usual mod you found out here where being LOWER is the PRIMARY GOAL
    This mod will allow your car to be lowered on spring/coilover while carrying heavy weight in the back (camping trip / towing a trailer / etc...)
    Before this mod, I would always spin the rear perch up max manually when camping, that would take me a good 1/2 hour and sometimes would barely be enough to prevent the tire from rubbing.
    After this mod, it would just be a matter of inflating the tubes to a higher PSI, I haven't tested the airlift 1000 with the trunk full but I can tell already that it will support more weight without rubbing tires.
    So here are few reasons why you would be doing this with your lowered car:
    1- You often carry heavy weight in the trunk
    2- You tow a trailer
    3- You raise your car every winter (with airlift you'll do the job in half the time)
    4- Your suspension is saggy in the rear resulting in rubbing tires, Airlift should make it a little stiffer and prevent that
    Let's get to work !
    1: First thing is to contact the AIRLIFT manufacturer to find out what kit will work with your stance and coilover/springs. You'll have to tell them the inside diameter and height of the coil at ride height (installed as the car sits in the driveway; no additional cargo/passengers): http://www.airliftcompany.com/contact.php
    I got Raceland coilovers, The inner diameter of the spring UNCOMPRESSED is 3.5in and the coil height with the car seating on a flat surface (not jacked) is 3.5in from the top of the perch (cut as shown in the picture below) to the rubber part at the top of the spring. I gave them those measurement and was told to get the Airlift 1000 kit 80754 which needs 5.5 inches in heigh in the compressed spring.
    2: you purchased your kit, next we need to cut the perch to make enough room for the bag inside the compressed spring unless you don't use the perch at all of course (I had to try a few cuts to avoid affecting my stance, the less you cut the higher your car will be at the lowest PSI).
    3: Now we need to insert the bag inside the spring, using your knee, compress the bag and slide in using a stick to force it inside, don't be shy here, you'll have push hard, here is the final result
    4: Drill a hole above the spring to route the air line to the bags
    5: Now connect the airlines to the bags and couplers, it's all explained in the manual and is very easy to do. You also have the option to run the lines separably using two air-valve (without coupler), doing so will isolate the bags resulting in more stable cornering, see comments posted down below for more info.
    6: connect the air line to the inflation valve (choose your favorite spot, I liked this one for being hidden and easy to access). Airlift provide everything, you just need your tools
    7: Test the setup by inflating it (lowest PSI while driving for my airlift kit is 5 and highest is 35, your kit might be different)
    8: Protect the air line with plastic wire loom and zip ties
    9: Enjoy (shown below is airlift @ 35psi)
    and here is the car seating with 5 PSI
    10: If the stance is is ****ed up at the lowest PSI, remove the lower red protector if the perch surface is flat (like the pic below, so it doesn't damage the bag), that way the bag will have more room inside the spring
    BIODiesel Powered | MKx Channel VW/Audi Videos United
    MKIV Forum User Guide | Forum Rules
    Quote Originally Posted by dele
    The guys on coils can pull off their own Airless pride thread cos they clearly are the underdogs in the air/static debate, kinda like the equality movement for women.
    May 8th, 2010
    NY
    honda what?
    10-16-2010 09:37 PM #2
    you crazy man. droppin your rear axle without unclipping your abs sensor cable. just plain dangerous.
    love the ride and the point of functionality that you will not sacrifice.
    I thought what I'd do was, I'd pretend I was one of those deaf-mutes.
    Formerly known as Jermi4
  3. Banned gxblade's Avatar
    Aug 8th, 2008
    Flo-rida
    Satin Silver MK4 Coupe
    10-16-2010 09:39 PM #3
    Cutting racelands and using el cheapo bags has be concerned more than the whole ABS wire issue
  4. Member
    May 8th, 2010
    NY
    honda what?
    10-16-2010 09:44 PM #4
    he only cut the rear perches, not the coils themselves. the bags sure look cheap but the company seems legit, and because the springs are still in there the bags are never lifting the whole weight. also if one DID blow because they're linked both sides would go down. not saying it wouldn't be scary as all heck and you might damage your muffler on your way down . . .
  5. Banned gxblade's Avatar
    Aug 8th, 2008
    Flo-rida
    10-16-2010 09:46 PM #5
    Quote Originally Posted by TheLaughingMan View Post
    I know. I just think this whole concept of seeing how cheap you can accomplish low suspension is not a good idea. There is a point where you start doing stuff so dumb that you are asking for something to happen.
  6. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    10-16-2010 09:52 PM #6
    Ya, I realized after that the abs cable was stretched, I was lucky this time, lesson learned
    And yes, if one bag fail or if the air lines get ****ed, the car would drop, I don't see how it would damage anything though, just tire rubbing I guess (unless i got a massive trailer behind lol)
    About the bag quality, it is VERY sturdy, no worry there, It will last
  7. Member White Jetta's Avatar
    Mar 17th, 2002
    Massachusetts
    Why don't you take a seat over there
    10-16-2010 10:42 PM #7
    Dude, this is simply an incredibly brilliant idea. And the install of the lines and air valve is as close to an OEM setup as any i've seen
    Sent on a Post-It by way of carrier pigeon
  8. Member Greg_J's Avatar
    Oct 30th, 2005
    Grand Bend ON Canaduh
    Montana Green '92 GTI w/ OBD2 ABA swap - '03 Jetta Wagon TDI 6spd
    10-17-2010 02:26 AM #8
    this is needed for wagon owners...
    this is what i had to do with my cupkit if i wanted to carry stuff around without scraping my hitch:
    Quote Originally Posted by ennui_delphian View Post
    Don't anger canadiun lesbian...
    May 8th, 2010
    NY
    honda what?
    10-17-2010 08:52 AM #9
    Quote Originally Posted by Greg_J View Post
    this looks like the best way to break a spring i've ever seen. did you put a chunk of aluminum or something in the spring itself to prevent full compression? that must be making all sorts of very localized forces on the spring.
  10. 10-17-2010 11:44 AM #10
    measurements aired up and down?
  11. 10-17-2010 11:55 AM #11
    This idea seems great, the only thing that worries me is that since both bags are running in the same line, the air might tend to shift from one bag to the other when cornering. Similar to running one valve front just the fronts when doing air ride.
    May 8th, 2010
    NY
    honda what?
    10-17-2010 11:57 AM #12
    Quote Originally Posted by Dr.Frag View Post
    but he's doing this on a solid rear axle. there'd be much less shifting than would occur in the independent front suspension on these cars.
  13. 10-17-2010 12:01 PM #13
    If there is body roll, there is a tendency for it to happen.
  14. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    10-17-2010 12:03 PM #14
    ^ I'll take the measurement today
    About the cornering thing, good point there. the Airlift kit comes with a second valve, so you can keep the air lines separated like shown in the picture below. Here is the other guy setup using OEM springs: http://forums.tdiclub.com/showthread.php?t=110896
    I used one airvalve for mine to reduce the inflation/deflation time and ensure both suspension have the exact same psi, maybe not a good idea. I'll contact the manufacture to ask them if what you say is true
    EDIT: got a response from them, here is it
    This can and will certainly happen to some extent; however it is minimal and is not a typical complaint we get or a cause of any issues. It is a matter of personal preference, but unless your load is fairly uneven on a regular basis from right to left I don’t think this change is necessary.
  15. 10-17-2010 01:55 PM #15
    **** a measurement. does this lift the car at all? the pictures arent very clear
  16. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    10-17-2010 01:57 PM #16
    ^ haha, yes it does. But keep in mind that the idea is to keep the stance the same with a heavy load, not create gaps
    @ 5 psi, i can put one finger in the gap
    @ 35psi, the whole hand as pictured
    I'll take measurements anyway and update first post with better pictures
  17. 10-17-2010 02:02 PM #17
    word can i use the same **** without perches? it would be cool to use my backseat sometimes.
  18. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    10-17-2010 02:04 PM #18
    If you meant taking the screwing perch support off, then yes. That way you could go lower too by grinding the perch even more
  19. 10-17-2010 02:08 PM #19
    i dont have any of that. i just put the raceland spring in where the oem spring was and lowered my jack.
  20. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    10-17-2010 02:11 PM #20
    ^ That should work too i guess, I always thought that running without perch was CRAZY ! but the OEM spring don't use perch so im stupid
    Just make sure to do step #1, contact the manufacture to find out the kit that fit your setup
  21. 10-17-2010 02:25 PM #21
    Quote Originally Posted by kilimats View Post
    yeah common sense > vortex knowledge every time.
    however, this time im going to trust the internet and buy the same ones you got. if they dont work im blaming you.
  22. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    10-17-2010 02:38 PM #22
    ^ blame urself for not following the DIY
  23. Member LouieTHEkid's Avatar
    Jan 27th, 2007
    3o1 kid
    01 GTI 1.8 57trim
    10-17-2010 06:33 PM #23
  24. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    10-18-2010 08:53 AM #24
    got a response from the manufacture regarding the cornering air pressure issue mentioned above, here is their reply:
  25. 10-18-2010 10:07 AM #25
    Just keep a eye on it, if it happens too often or too drastically, you know what to do.
  26. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    10-18-2010 10:42 AM #26
    ^ true enough, I've updated the first post. But I doubt I'll have problems. Our cars don't carry crazy loads even trunk/rack maxed out, should be OK
  27. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    12-16-2010 03:12 PM #27
    First post updated with more info.
    I swapped my wheel the other day and checked the airlift bag condition, barely any scratches, this thing will last a LONG time
    I also compared the ride comfort at 35psi and 5psi. It definitely makes the rear stiffer, good for achieving perfect stance without rubbing tires
  28. Member DuB fresh's Avatar
    Jun 17th, 2009
    New Hartford CT
    tropic gti
    08-19-2011 09:39 AM #28
    Im assuming these wont work if i wanted to put them in my ultimos and sit at 23 ftg?
    Quote Originally Posted by ventoCL View Post
    bags dont counts. never have, never will.
    CORNSTATUS
    My Shaved bay Build
  29. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    08-19-2011 10:52 AM #29
    Quote Originally Posted by DuB fresh View Post
    you' ll find out by doing step 1 on the DIY
  30. Member jun_1.8T's Avatar
    Oct 31st, 2003
    Brampton, ON
    '02 Jetta 1.8T(gone), MK6 CW Golf
    08-19-2011 12:28 PM #30
    i really want to do this to my car as i sometimes use it for family trips. i got racelands right now too without the rear perch so i guess i could get the same kit as you. just have a few questions though....do i need to put in the protector peice if i dont have any perches? did it ever leak air on you? and will i have my original stance when it is at its lowest setting of 5psi?
    thanks in advance for the help.
  31. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    08-19-2011 02:07 PM #31
    Quote Originally Posted by jun_1.8T View Post
    If you remove the protector piece within the spring, the bag won't support your car as much when fully inflated, I recall trying without and the car would barely lift when inflating it. Best route for you is to keep the proctector without the perch, that should work pretty good
  32. Member jun_1.8T's Avatar
    Oct 31st, 2003
    Brampton, ON
    08-19-2011 02:32 PM #32
    thanks...but at 5psi do i keep my original stance?
  33. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    08-19-2011 03:24 PM #33
    You will if the bag is not too compressed vertically in the spring, with my raceland spring, the airlift bag was not putting pressure on the upper and lower mount while at 5psi. so your stance will just be as low if that's what you worried about
  34. Member jun_1.8T's Avatar
    Oct 31st, 2003
    Brampton, ON
    08-19-2011 05:42 PM #34
    Thanks a lot.
  35. Member Matt_Dubbing_Lopez's Avatar
    Jun 10th, 2009
    NJ
    01' Vw Jetta w/ 03' 5spd 1.8t swap
    10-03-2011 10:54 AM #35
    Ordered my set, gonna try this. 80754 is the smallest bag they make (5inx3.5in).
    Thanks!
    8V Society. RIP #165
    AWP 1.8t Gt2871r, IE rods, Genesis 630cc, Walbro 225, Forge 007, Eurodyne tune on fifteen52 tarmacs
    My 2.Show might be slow but it sure as hell is better then your fast mom and dad paid car....
