Page 36 of 44 FirstFirst ... 26 32 33 34 35 36 37 38 39 40 ... LastLast
Results 1,226 to 1,260 of 1518
Thread: Timeline (pic intensive)
  1. Member dub nutz's Avatar
    Dec 30th, 2010
    stafford, CT
    golf lll vrT, rusty mk4 2.0
    09-28-2012 09:28 AM #1226
    when ever relocating the battery to the rear, you should always run a ground cable from the back to front. grounding through the body works but is not the best way. the amp draw from the starter has a hard time passing through the sheet metal and spot welds. also make sure your engine to chassis grounds are clean metal and the ground on the seat belt should be to bare metal on the chassis, the threads for the bolt could be painted from the factory, this will cause a bad ground. good luck hope you can figure this out
  2. Member catalina2.o's Avatar
    Oct 27th, 2008
    Hillside, NJ
    96 4dr vr(show car), 02 jetta 1.8t
    09-28-2012 12:15 PM #1227
    the only differance from my car to pks car is i have an extra ground in my trunk so i have 2 grounds to the battery in the trunk but the car was starting and runing fine until it stalled at the red light which has me compluzzled.. now thew starter makes a loud screeching spinning sound.. gotta check it out after h2o
  3. Member 87veedub's Avatar
    Oct 22nd, 2007
    Lancaster, PA
    8v army
    10-01-2012 05:52 PM #1228
    Well what's the verdict mane!?
    Quote Originally Posted by jbigs268 View Post
    Then wait till you can afford the CXs, buy them so your kid doesnt get shaking baby syndrome from the racelands
  4. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-01-2012 05:57 PM #1229
    The verdict is....unknown.
    I decided not to take the car down (for obvious reasons)
    Still had a blast at h20 and I'm remotivated to get things cracking.
    I'm going to start at grounds, redo them, ground in better locations, add a ground wire like Bryan's setup, etc.
    Sorry to all who were lookin for it and to those I spoke to, appreciate your understanding and advice, tips, etc.
  5. Member 87veedub's Avatar
    Oct 22nd, 2007
    Lancaster, PA
    8v army
    10-01-2012 06:14 PM #1230
    I really think it's just a bad ground/something to do with your relocation as others said
  6. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    98 GTI Vr6-T (Project) | 96 GTI Vr6 (SOLD) | 97 Passat Wagon Vr6 (Daily)
    10-01-2012 10:49 PM #1231
    Good finally talking to you in person PK. We will def get a photoshoot in when we get our cars buttoned up.
  7. Member Harris_Teeter's Avatar
    May 30th, 2008
    Stool Bend
    Blackish Green
    10-02-2012 01:11 PM #1232
    Quote Originally Posted by Dubblovinboyy View Post
    PK i was curious about this too. i was driving my car for the first time after i did the clutch job and i put it in neutral and it died at the light. now when im driving i cant press over 3 grand or my car starts to break up and my cel starts to flash. then the power kicks in. Idk man its all werid but i want to know if it can be related to each other. Im also in the same boat as to wanting to know why it died cause from time to time my car wants to die when im driving it but never flly dies..
    I could be wrong but for some reason, that sounds like the crank position sensor...I'm sure you didn't touch it during the clutch job, but I've had similar issues when my CPS got wet during a snow storm.
  8. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-02-2012 01:28 PM #1233
    Nice meeting you too, Evan and hell yeah!
    Word Ian, where is the CPS located?
    also, guys, does it matter that my clutch switch isn't plugged in?
    I don't think that will play into any of this.
  9. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    Megasquirt 3x Powered 98 Jetta GT 2.0
    10-02-2012 02:42 PM #1234
    Quote Originally Posted by PKstrategy View Post
    Is it not plugged in, or is it bypassed? If I remember, it wont even spin the starter if its not by passed or plugged in.
    98 Jetta 2.0 w/ Megasquirt 3/3x fully sequential
    ABA 16vT build thread
  10. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-02-2012 04:12 PM #1235
    Quote Originally Posted by SirSpectre View Post
    You're asking about the clutch switch right?
    It's not plugged in.
    But then how was I able to start and literally DRIVE the car without it?
  11. Member Harris_Teeter's Avatar
    May 30th, 2008
    Stool Bend
    Blackish Green
    10-02-2012 04:29 PM #1236
    Right on the front of the block, and held in with one 5mm allen screw. It connects to a white plug iirc
  12. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-02-2012 04:32 PM #1237
    ah yeah, that's def plugged in.
    i don't suppose it could be plugged in, incorrectly?
  13. Member tesh0boy's Avatar
    Dec 7th, 2009
    A bunch of german junk and a pocket bike
    10-02-2012 04:36 PM #1238
    Hate to hear it, but better to be safe than sorry.
    Having car problems down there just ruins the whole weekend when your that far from home.
    Yeah Right!
    All of your cars suck, you wear skinny jeans and smell like chicken nuggets.
    Oldskool.Industry
  14. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-02-2012 04:58 PM #1239
    yeah man, it's true.
    or worse off, on either the ride there or back.
    I've come to terms with it all and I'm going to start with the basics and try to isolate the issue.
  15. Member MYGTI_MA's Avatar
    May 3rd, 2010
    North of Boston
    1997 GTI 2.0 // 1983 Rabbit Diesel
    10-02-2012 05:37 PM #1240
    better to be safe man not worth killing a car to get to h20i
  16. Member catalina2.o's Avatar
    Oct 27th, 2008
    Hillside, NJ
    10-03-2012 04:10 PM #1241
    pk ive got an extra crank sensor laying around if u wanna try that ..
  17. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-03-2012 04:15 PM #1242
    word man
    and yeah Bryan, sure.
    Send it on over B
    I'll PayPal you for shipping or whatever.
  18. 10-03-2012 07:38 PM #1243
    Good seeing you in oc
  19. 10-03-2012 09:07 PM #1244
    God dam PK 36 pages..
    Sell me some wheels for my corrado
  20. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-04-2012 09:12 AM #1245
    Word, Leaston! I'll get those pics up soon.
    Yeah Brendon, holla at me
  21. Member JASENR's Avatar
    Dec 16th, 2008
    LG6S VR6
    10-04-2012 10:14 AM #1246
    I'm waiting.
    B.H.C.
    Quote Originally Posted by polo freaks View Post
    I don't dance, I stance b.
  22. Member HandsomeDan's Avatar
    Sep 24th, 2008
    New York
    how many fingers?
    10-04-2012 10:22 AM #1247
    crush it.
    Blowin' smoke out. The BBSs poke out.
  23. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-04-2012 10:52 AM #1248
    word Jasen
    shutup (Corey?) Gimme them Nothelles.
  24. Member HandsomeDan's Avatar
    Sep 24th, 2008
    New York
    how many fingers?
    10-04-2012 11:51 AM #1249
    who the **** is Corey?
  25. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-04-2012 11:53 AM #1250
    eh, wrong person.
    shutup handsomedan, and let me has them nothelles.
  26. Member HandsomeDan's Avatar
    Sep 24th, 2008
    New York
    how many fingers?
    10-04-2012 12:07 PM #1251
    They're yours for the right price.
  27. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-04-2012 12:16 PM #1252
    let me get the bitch running solid and we'll talk.
  28. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    10-04-2012 12:54 PM #1253
    If you get nothelles I got dibs on the Hocks
  29. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-04-2012 01:00 PM #1254
    Which ones?
  30. Member Dubblovinboyy's Avatar
    Feb 5th, 2010
    Brooklyn NY
    97 Gti VR6
    10-04-2012 03:48 PM #1255
    i have an extra crank sensor if you still need that. let me know.
  31. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-04-2012 03:58 PM #1256
    yeah man, drop by my crib or the meet tonight and i'll definitely try that out.
  32. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    10-04-2012 07:34 PM #1257
    Which ones?
    No wonder I can't ever find a set, you keep taking them!
    Uhm. Whatever set you feel like parting with
  33. Member catalina2.o's Avatar
    Oct 27th, 2008
    Hillside, NJ
    10-05-2012 09:52 AM #1258
    evan you gotta lower it first
  34. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    10-08-2012 08:29 AM #1259
    So I decided to move the battery up front to stock location just to test what the hell is happening.
    This would take the distribution block and my "new" ground location in the trunk out of the equation.
    Well, as soon as you go to start the key, it clicks and car doesn't crank, spin or anything.
    With the battery being back up front and the distribution block out of the picture, what the hell can be causing a short?!
    We decided to put the battery back in the trunk and even still, when you try to crank the car it just clicks once and you lose everything. If you take the terminal off the battery and reapply, sure, it's all back - gauge, lights, etc. But the car will not start, crank, spin or anything.
    The stock wiring harness was untouched in terms of extending, etc.
    I simply rewrapped it in grip tape and that's about it.
    I tested the battery and its consistent at 12.5
    We tested the connections from end point to end point and it stays at 12.5
    some other info:
    ECU was replaced and is running the older C2 chip
    02 harnesses were extended (8 wires)
    starter is brand new and was bench tested before installing
    Battery is a brand new optima red top
    The confusion is why did the starter at least spin before (1 week ago) and now, we don't get anything?
    I'm betting on a short, but I don't know where the **** to start.
  35. Member catalina2.o's Avatar
    Oct 27th, 2008
    Hillside, NJ
    10-08-2012 09:16 AM #1260
    undo the grounds on the driver frame rail by the powersteering. unwrap the tape and make sure the wires didnt come loose from the butt connectors, maybe they came loose and you lost those grounds
