Manufacturers:
Active
Capabilities: Adjustable manifold pressure activation
Pump: Shurflo
Electronic Controller option:: not mentioned on site
Chemical compatibility: Water, Alcohol
Failsafe: not mentioned on site
Price range: US$750.00
Warranty: Not mentioned on site
URL: http://activeautowerke.com/cooling/main.php
EMAIL: aatuning@activeautowerke.com
AEM
Location: 2205 126th Street, Unit A Hawthorne Ca. 90250
Capabilities: Mainfold pressure activated
Pump: Shurflo
Electronic Controller option:: Onboard MAP sensor Pump speed controller
Chemical compatibility: Water, 50% Alcohol (recommened)
Failsafe:: water level sensor and power supply failure
Price range: US$390.00 - $570.00
Warranty: 12 months
URL: http://www.aempower.com/ViewCategory...CategoryID=120
EMAIL: emstech@aempower.com
Alkycontrol
Capabilities: Progressive delivery proportional to MAP sensor. Inline filter, metal fittings, and stainless steel braided lines.
Pump: Shurflo
Electronic Controller::Based on PAC module controlling pump speed to vary pressure
Failsafe: Failsafe Bi-colored LED works of pressure sensing, inline filter, metal fittings, and stainless steel braided lines.
Price range: US$425-495
Warranty: 1 year unconditional and 100% methanol URL: http://www.alkycontrol.com/
EMAIL: Online form or phone
Aquamist
Capabilities: Static flow, mappable, fuel injection duty cycle tracking, ECU interface and map switching
Pump: Own design - magnetic piston type and 150W/160psi by-pass Aquatec pump
Chemical compatibility: Water, Methanol. 100% methanol and 10 to 20% nitromethane withteflon seals: supply on request
Failsafe: Dash Flowmeter or fulltime monitoring via signal error comparator circuitry, boost control and map switching output.
Price range: US$585.00-3000.00+
Warranty: 12 months
URL: www.aquamist.co.uk
EMAIL: info@.aquamist.co.uk (sales enquiry), richard@aquamist.co.uk (technical)
Aquastealth
Capabilities: Static flow, Pressure switch activated inline solenoid.
Pump: Shurflo
Chemical compatibility: Water, Methanol, isopropyl and ethanol.
Failsafe: unspecified
Price range: US$239.00
URL: www.aquastealth.com
EMAIL: sales@aquastealth.com
Coolingmist
Capabilities: Progressive, Static flow – single or dual stage
Electronic Controller: Digital 52 MM "all in one" boost guage, failsafe, progressive controller and flow gauge. Injection based on boost, MAF or boost and MAF.
Chemical compatibility: Water, 100% Methanol safe (EPDM Seals)
Failsafe: CMGS progressive controller has built in flow based failsafe. Detect low flow, high flow, out of fluid/hardware failure and flowing when should not be. Normally close or normally open output.
Price range: US$249.95 to $625
Warranty: 1 Year Warranty
URL: www.coolingmist.com
EMAIL: info@coolingmist.com[/quote]
Review of Stage 1 Kit by bootymac
Devilsown
Capabilities: Static flow, PWM pump speed control option
Electronic controller option: 0-5v (selectable scales 2 bar,3 bar,voltage) – pump speed control . Price US$125.00
Pump: Custom Shurflo
Failsafe: over-current sensing
Price range: US$205.00-305.00 + MAP sensor
Warranty: One Year Limited
www.alcohol-injection.com
EMAIL: sales@.alcohol-injection.com (sales inquiry), support@alcohol-injection.com (technical)
Hydramist by Element Tuning (Work with Hydra EMS only)
Capabilities: Full 3D hi-res mappable, inbuilt failsafe.
Electronic controller: Element Hydra stand-alone EMS.
Pump: Shurflo (150W), with 125psi internal by-pass
Chemical compatibility: Water, Methanol, Ethanol, Iso-propyl
Failsafe: DDS3 flow sensing system - auto map switching via DDS3 v7.
Price range: US$799.00 not including Hydra EMS
Warranty: Not yet specified
EMAIL: phil@elementtuning.com
URL: www.elementtuning.com
Gaseous Intercooling TM
Capabilities: Static flow and two stage
Pump: Flojet
Failsafe: Flow switch
Price range: $395.00-540.00 basic to Standard Plus (with solenoid)
Electronic flow controller: US$195.00 sold as an optional extra
Warranty: 90 Days
URL: http://www.blowerworks.net
EMAIL: greg@blowerworks.net
Hyper-drive
Capabilities: Mappable pump speed controller
Pump: Shurflo
Failsafe: low water level sensor.
Warranty: not mentioned on site
URL: http://www.hyp-drive.com/products/alcoholinj.htm
EMAIL: resolution@hyp-drive.com
Labonte Motorsport
Loves Park, Illinois 61111 UDA
Capabilities: Static flow, PPS based on IDC and MPS
Pump: Aquatec
Chemical compatibility: Water, Alcohol (call)
Failsafe: Turbine flow sensor based
Price range: US$295.00 - $700 + add-on optional extra
URL: http://www.labontemotorsports.com/store/index.php
EMAIL: On site fill-in form
Perrin
Capabilities: IDC tracking - PPM pump control (progessive)
Pump: Electrionmagnetic piston pump
Failsafe: low water level sensor and real time flow tracking
Price range: US$749.99
Warranty: Terms and Conditions on Site
URL: http://www.perrinperformance.com
EMAIL: Sales@perrinperformance.com
RSR
Capabilities: Static flow, Port injection
Pump: Shurflo
Failsafe: water level switch
Price range: US$185.00-345.00 + MAP sensor
Warranty: call
URL: www.rbracing-rsr.com/waterinjection.html
SMC (Service work only)
Capabilities: Progressive controller
Electronics controller option: - control pump speed to vary flow.
Pump: Flojet/Rotary fuel pump
Chemical compatibility: Water, Ethanol, Methanol, and Isopropyl alcohol types
Failsafe: tank level sensor at present.
Price range: US$399.00-499.00
Warranty: 90 Days
URL: www.smcenterprises.com
EMAIL: schlupsa31@mchsi.com
Snow Performance
Capabilities: Multi-stage progressive, simultaneous injector duty cycle and boost based injection. Basic boost, MAF,
and vacuum controlled injection systems as well. Non-progressive boost based injection also available.
Pump: Aquatec featuring multiple high temp/pressure features, double seals, etc.
Chemical compatibility: Any ratio of water and methanol.
Failsafe: Flow based, adjustable minimum flow and sample time, and progressive flow based volatge output.
Price range: 304.00-729.00
Warranty: Standard 2 year on all systems, optional Lifetime.
URL: http://www.snowperformance.net
EMAIL: customerservice@snowperformance.net[/quote]v
Spearco Water Injection System
Location: Top-End Performance, N.Hollywood, California.USA.
Electronic controller option: Progressive pump speed controller +$129.00
Pump: Not specified
Failsafe: Not secified
Price range: US$219.00
Warranty: Call
URL: http://www.h2oinjection.com
EMAIL: topend@racetep.com
TTP Engineering
Capabilities: Static flow, Progressive controller –sold separately(PWM pump)
Pump: Shurflo Based
Control option: pressure switch, TPS or MAP (0-5v selectable)
Failsafe:upgrade path available
Price range: from US$299.00(base) + accessories
Electronic Controller: Variable injection rate controller now available
Warranty: Call
URL: http://www.ttp-engineering.com
EMAIL: online form filling
