VWVortex.com - 98 jetta 2.0 Leaking Oil badly from filter housing?
    Results 1 to 3 of 3
    Thread: 98 jetta 2.0 Leaking Oil badly from filter housing?
    1. 10-22-2010 11:10 AM #1
      I'm spewing oil from the oil filter housing? It looks that way , can someone direct me to instructions to replace or is there a hose or a gasket ? Thanks !!!!!!!!
    2. Member Krieger's Avatar
      May 5th, 2009
      Orlando, FL
      Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
      10-22-2010 03:13 PM #2
      might want to read what forum your in...
      2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
    3. Senior Member MFZERO's Avatar
      Mar 13th, 2002
      Haverhill, Ma.
      2011 Kink Gap Xl, 2000 Haro Blammo,'08 Gti
      10-22-2010 04:44 PM #3
      you should look here: 2.0 Liter Engine Forum
      you may need an oil cooler seal. it's about $4.00. you should replace the oil filter at the same time since you will be taking it off anyways.
