Page 5 of 27 FirstFirst 1 2 3 4 5 6 7 8 9 15 ... LastLast
Results 141 to 175 of 913
Thread: A TCL First? '67 Rolls Royce project thread...
  1. Member The Maytag Man's Avatar
    Apr 5th, 2002
    Toronto,ON
    VW GTI 20th AE BMP, 1983 VW Rabbit GTI(sold), 1978 VW Rabbit L
    04-27-2011 06:52 PM #141
    Buy My Things!
    Buy My 20th!
    What She Order?
    ლ(•益•ლ) Why you no buy my stuff!?
    78 HÄRE
  2. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 mom wagon
    04-27-2011 08:19 PM #142
    Quote Originally Posted by epbrown View Post
    From the guy selling the Camargue? Nice, yes, but RHD.
    thats the one
    ah, forgot it was RHD. awesome color combo though!
  3. Member MRVW00's Avatar
    Oct 30th, 2000
    Everywhere you want to be.
    B5 2.8Q, Buell XB9S
    04-27-2011 11:19 PM #143
    That coupe is amazing...
    Tucker Max of the Gays and Demokratikally Elekted Minister of Slutty Gay Whoring and Muppet Sex of the People's Independent Republik of Offtopikstan
    RIP Cosmic TDI
    Quote Originally Posted by HideYoKids View Post
    Dann is More sassy than any man with facial hair should be. It's entertaining.
    Sep 13th, 2007
    Chicago, IL
    Mini Cooper S, Porsche Boxster S
    05-01-2011 01:58 PM #144
    I'm still on RROC, but I haven't seen a LHD coupe posted this year. I was liking the blue 72 sedan in Indiana, but everyone talked the owner into keeping it!
    Follow-up that I thought might interest TCL - the seller of the 72 sedan posted his maintenance log, since this is one of those cars everyone squawks about running costs. Details below, but the big figures are:
    Total spent: $47,627.90, divided by 26 years it's cost him $1831.84/year to run a vintage Rolls-Royce, $1439/year without the repaint he did last year. Details below.
    Date Where Description Cost
    12/23/85 Valve Cover Gasket $216.00
    12/23/85 Fan Clutch $36.00
    12/23/85 Washer Pump $36.00
    1/20/86 Rebuild Compensator System $688.00
    5/14/86 Fuel Pump $331.00
    11/7/86 Bleed brake system $1,330.00
    10/16/89 Spark Plugs $80.00
    10/16/89 Oil Change $18.00
    5/16/90 Rebuild Brake Servos $1,703.00
    7/9/90 Tie Rod Ball Joints $580.00
    1/29/91 Rebuild Front Brakes $1,419.00
    6/1/91 Hubcaps $565.00
    6/7/91 Front and Rear Shock Bushings $32.00
    6/7/91 Plug Wires $363.00
    6/7/91 Torque Arm Mounts $43.00
    3/14/92 Rear axle rebuild $500.00
    8/18/92 Valve Cover Gasket $300.00
    8/18/92 Overhaul Accumulator Valves $600.00
    8/18/92 Door locks LF RF LR $270.00
    9/4/93 LF Window Regulator replacement $800.00
    4/22/94 AC Compressor, dryer, hose, belts replace $1,683.00
    4/24/96 Windshield seal $200.00
    4/24/96 RR#2 Brake pump push rod $150.00
    12/17/96 Heater hose replacement $350.00
    12/17/96 Brake system flush $100.00
    7/17/97 Overhaul LR Caliper, brake hoses $998.00
    8/1/97 Replace high pressure steering hose $300.00
    7/27/01 Spark Plugs $80.00
    7/27/01 Points and Condensor $100.00
    7/30/01 Replace starter motor $662.00
    1/2/02 Replace high pressure steering hose $200.00
    1/2/02 Replace wiper motor assembly $650.00
    1/2/02 Replace wiper transmission $600.00
    1/2/02 Spark Plugs $80.00
    11/22/02 Overhaul water pump $841.00
    11/22/02 Replace thermostat $177.00
    11/22/02 Replace front motor mount $168.00
    11/22/02 Replace rear motor mount $350.00
    11/22/02 Replace trunk seal $450.00
    1/10/03 Replace Radiator core $925.00
    1/10/03 Overhaul carburettors $425.00
    2/2/05 Replace LR bearings $1,002.00
    5/26/05 Clean and adjust carburettors $275.00
    1/6/06 Replace RF window lift $290.00
    1/6/06 Bleed hydraulic system $122.90
    2/15/06 Replace trailing arm hoses $424.00
    3/8/06 Replace viscous fan coupling $554.00
    5/10/06 Replace front right door seal $369.00
    4/20/07 Replace driver door seal $449.00
    4/20/07 Replace fuel gauge level unit $641.00
    4/20/07 Replace power antenna $365.00
    7/8/08 Replace battery $163.00
    7/8/08 Replace rocker cover gaskets $1,129.00
    7/8/08 Replace oil pressure transducer switch $121.00
    7/8/08 Repair coolant header tank $321.00
    7/8/08 Replace both front shock absorbers $1,620.00
    7/14/08 Replace high pressure steering hose $513.00
    7/14/08 Recharge AC $100.00
    11/11/08 Bleed hydraulic system $250.00
    11/11/08 Replace #1 Accumulator High Pressure Hose $483.00
    11/11/08 Replace AC Compressor $996.00
    11/11/08 Replace AC Dryer / Accumulator $231.00
    11/11/08 Replace ignition condenser $140.00
    3/4/09 Replace AC Compressor $750.00
    3/4/09 Replace Front stabilizer bushings $307.00
    3/4/09 Repair fuel sending unit $140.00
    3/4/09 Replace both Front Compliance Bushings $1,410.00
    3/4/09 Replace LR Bearing pin and washers $1,032.00
    3/4/09 Replace steering coupling boot $53.00
    6/9/09 Replace Ignition coil ballast $180.00
    6/9/09 Replace fuel pump $989.00
    6/9/09 O ring for brake reservoir $193.00
    10/15/10 Replace windshield $750.00
    10/15/10 Replace back window seal $95.00
    10/15/10 Replace all door seals $350.00
    10/15/10 Replace hood pads $580.00
    10/15/10 Respray $10,191.00
    4/2/11 Electronic Ignition $240.00
    4/2/11 Spark Plugs $90.00
    4/2/11 Replace thermostat $95.00
    4/2/11 Replace hot water tap $75.00
    4/2/11 fan motor $150.00
    A hundred dollars on your hair, fifty on your nails, fifty on make-up, two hundred dollars for an outfit. You ladies spend four hundred dollars to bring home a thug that ain't worth ten cents!
  5. Senior Member A.Wilder's Avatar
    Mar 1st, 2003
    Raleigh, NC
    99 V70
    05-01-2011 02:31 PM #145
    Good lord some of those costs are extremely high. tie rod ball joints $580?! Door seal $350-450?!?!?!
    Mark Twain
    Nov 8th, 2002
    Whitefish, MT
    2004 Forester 1997 LX450 1975 Rabbit
    05-01-2011 02:37 PM #146
    Lot of things cheaper than I thought.
    The brake work is ridiculous though. Is the brake system tied into something else?
    Sep 13th, 2007
    Chicago, IL
    05-01-2011 03:34 PM #147
    Quote Originally Posted by PoorHouse View Post
    The brakes are tied into the high pressure hydraulics that handle load/ride leveling. Also the fronts have TWO calipers per wheel.
    Sep 28th, 2006
    2006 mk5 GTI
    05-01-2011 05:01 PM #148
    Looking at those prices makes me wonder if service for a Turbo RL would be similar in cost. Tgose seem to be 75-80% depreciated and although they lack the classic beauty of your 67 they still have quite a bit of presence.
  9. Member Air and water do mix's Avatar
    Aug 5th, 2004
    Southern Indiana
    05-01-2011 05:10 PM #149
    Quote Originally Posted by A.Wilder View Post
    Yet the overall costs are quite reasonable. You also have the fact that you're driving a Rolls.
  10. Senior Member Chris16vRocco's Avatar
    Apr 29th, 2006
    W123
    05-01-2011 06:02 PM #150
    Are those costs with labor, or just the price of the parts? Were these parts purchased at list price from a dealer, or from aftermarket suppliers, or with a discount.
    Also, the fan clutch was only $38? The one for my 5.2 Jeep cost twice that.
    Deal with it.
    Sep 13th, 2007
    Chicago, IL
    05-01-2011 07:53 PM #151
    Quote Originally Posted by Chris16vRocco View Post
    All of the amounts are parts and labor using three of independent shops.
  12. Senior Member A.Wilder's Avatar
    Mar 1st, 2003
    Raleigh, NC
    99 V70
    05-01-2011 08:16 PM #152
    ok, that makes a bit more sense.
    Still think the owner got raped on the ball joints and door seals. Unless it has some insanely complex door seal and ball joint.
    Mark Twain
  13. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    05-01-2011 08:30 PM #153
    theres a jag replacement that fits and is about 10x cheaper than the identical rolls branded fan clutch. the indy shop was probably smart enough to lead him toward the cheaper part
    also... theres an early 90s turbo bentley for sale on RROC right now as well. those are MUCH more expensive to run. the guy on there has also posted his costs (dealer serviced with original bentley parts) and its approaching 6 figures as i recall... just since the late 90s. big money
  14. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    05-01-2011 08:32 PM #154
    all of the soft rubber parts for these cars are really expensive. its not like resealing an old mustang
    door seals for older vws arent too much different in price though - if you can even find them!
  15. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    05-17-2011 02:05 PM #155
    bumpers!
    theyre not mint but it fits the rest of the car's patina
  16. Member
    Sep 13th, 2007
    Chicago, IL
    05-17-2011 09:29 PM #156
    Nice - now, about the grill/radiator shell...
  17. Member
    Nov 3rd, 2008
    DC Metro Area
    06 Mustang GT Vert 5MT, 08 TSX 5AT, 95 Volvo 850 GLT 4AT
    05-17-2011 09:57 PM #157
    Does this car not have the little headlight brush things?
    Those are so choice.
    I want a Rolls now.
    http://sixsylinder.blogspot.com
    Quote Originally Posted by stacman View Post
    Top gear recommended it, so I bought it.
  18. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    05-18-2011 12:27 AM #158
    i know i know! hah
    thats probably on the way back burner for now... at least until its on the ground and running and we see if we have any more mechanical things to shake out. a grill is easy to find and fit so im not too worried about getting my hands on one of those...
    no headlight wipers on this guy, i think that was only for the later shadow 2s...
  19. Member 71DubBugBug's Avatar
    Dec 3rd, 2006
    Chicago
    91 Audi D1 V8, 71 Super, 07 E320 Bluetec, 05.5 Jetta 2.5
    05-18-2011 12:48 AM #159
    I might have mentioned this before, but aside from repair costs, I think it would be awesome to daily one of those.
  20. Member
    Sep 13th, 2007
    Chicago, IL
    05-18-2011 03:20 AM #160
    Quote Originally Posted by ValveCoverGasket View Post
    The headlight wipers weren't a common option, and they didn't start until the 1978-1980 Shadow IIs; the wipers mounted where the side intakes are on the Shadow I.
  21. Member XenoLlama's Avatar
    Sep 22nd, 2002
    08 GTI, 95 Jetta GLX, 92 Corrado SLC
    05-18-2011 05:47 AM #161
    Tell me you are bringing her to Leavenworth this year. Show everyone how us crazy northwestern wa folks roll.
  22. Member Dobes's Avatar
    Feb 5th, 2003
    2008 Lotus Exige S240 & bland company car
    05-18-2011 08:37 AM #162
    Heh, it's nice to see someone else still using a non-ball bearing Craftsman toolbox. I've put off upgrading forever....... Word of advice, get some silicone spray for the drawer sliders. It's not as good as having ball bearings, but will make a nice difference, especially for heavily loaded drawers.
    Oh, and nice car!
  23. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    05-18-2011 12:03 PM #163
    Quote Originally Posted by XenoLlama View Post
    we'll see how its running by then, thats kind of a long drive! ha
    and yes, very much enjoying the non-ball bearing tool box. i dont really care that it takes 1/10 more effort to pull out the drawers... the money i saved was better spent on more tools anyway
  24. Member XenoLlama's Avatar
    Sep 22nd, 2002
    05-18-2011 12:19 PM #164
    At least you can have someone else drive whilst you recline in luxury in the back.
  25. Member Air and water do mix's Avatar
    Aug 5th, 2004
    Southern Indiana
    05-18-2011 12:37 PM #165
    Looking good, Lewis!
    Feeling good, Valentine!
  26. Member
    Jul 28th, 2009
    Las Vegas
    1986 Volvo 245DL
    05-18-2011 12:38 PM #166
    Quote Originally Posted by Air and water do mix View Post
    Looking good, Billy Ray!
    Feeling good, Lewis!
    FTFY
    edit:
  27. Member Air and water do mix's Avatar
    Aug 5th, 2004
    Southern Indiana
    05-18-2011 12:40 PM #167
    Quote Originally Posted by Mooosman View Post
    FTFY
    Thanks, It's been a while!
    for Jamie Lee Curtis
  28. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    06-15-2011 04:32 PM #168
    just got word back from the trans shop that the rebuilt unit is ready, along with 2 other trans worth of spare parts - that will probably get sold on RROC when the time comes.
    hoping to pick everything up friday afternoon and take some shots.
    found a guy on RROC who will let me borrow a crank bolt socket so i can get runout on the flexplate, and use it while installing the trans.
    if i can find enough time this should be wrapped up sooner rather than later
    also poking around the car last weekend reminded me i probably need to order some random tuneup parts for when this hits the road - spark plugs, air filter, new plug wires.
    thanks for reading and ill keep updating as we make more progress
  29. Member Bull0080's Avatar
    Mar 12th, 2005
    MN & SF
    B7 A4 S-line w/ APR stuff
    06-15-2011 04:49 PM #169
    Cool project, wish I had the room and time. Have fun!
  30. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    1989 Helios GLI 1997 Mk3 ****box
    06-15-2011 05:00 PM #170
    Always wondered if you had a build thread for this car, or even pics. Subscribed
  31. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    06-15-2011 05:04 PM #171
    Quote Originally Posted by Bull0080 View Post
    im quickly running out of both but i want to see this through, so itll get rolling. i think were over the hump now (hopefully!)
  32. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    06-19-2011 03:14 PM #172
    its baaaack!
    and we managed to acquire a sizable collection of RHD 4spd stuff
    working with alber's to get some tune up parts for its road debut - air filter looks like an old birds nest! hah and waiting on the crank sprocket tool - should be in this week, then the real work starts
  33. Member ttvick's Avatar
    Aug 15th, 2007
    Fayetteville, NC
    2004 VW Phaeton V8, 2005 Mini Cooper (sold), 2002 ML320, 1996 Explorer V8, 2000 S2000
    06-19-2011 08:36 PM #173
    This is such a cool project... More updates, please!
  34. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    06-20-2011 10:48 AM #174
    ill keep posting stuff as soon as we make some more progress
  35. 06-23-2011 12:51 PM #175
    Great project, very happy to see something so far out of the norm. Thanks and good luck with it
