#142
#144
Follow-up that I thought might interest TCL - the seller of the 72 sedan posted his maintenance log, since this is one of those cars everyone squawks about running costs. Details below, but the big figures are:
Total spent: $47,627.90, divided by 26 years it's cost him $1831.84/year to run a vintage Rolls-Royce, $1439/year without the repaint he did last year. Details below.
Date Where Description Cost
12/23/85 Valve Cover Gasket $216.00
12/23/85 Fan Clutch $36.00
12/23/85 Washer Pump $36.00
1/20/86 Rebuild Compensator System $688.00
5/14/86 Fuel Pump $331.00
11/7/86 Bleed brake system $1,330.00
10/16/89 Spark Plugs $80.00
10/16/89 Oil Change $18.00
5/16/90 Rebuild Brake Servos $1,703.00
7/9/90 Tie Rod Ball Joints $580.00
1/29/91 Rebuild Front Brakes $1,419.00
6/1/91 Hubcaps $565.00
6/7/91 Front and Rear Shock Bushings $32.00
6/7/91 Plug Wires $363.00
6/7/91 Torque Arm Mounts $43.00
3/14/92 Rear axle rebuild $500.00
8/18/92 Valve Cover Gasket $300.00
8/18/92 Overhaul Accumulator Valves $600.00
8/18/92 Door locks LF RF LR $270.00
9/4/93 LF Window Regulator replacement $800.00
4/22/94 AC Compressor, dryer, hose, belts replace $1,683.00
4/24/96 Windshield seal $200.00
4/24/96 RR#2 Brake pump push rod $150.00
12/17/96 Heater hose replacement $350.00
12/17/96 Brake system flush $100.00
7/17/97 Overhaul LR Caliper, brake hoses $998.00
8/1/97 Replace high pressure steering hose $300.00
7/27/01 Spark Plugs $80.00
7/27/01 Points and Condensor $100.00
7/30/01 Replace starter motor $662.00
1/2/02 Replace high pressure steering hose $200.00
1/2/02 Replace wiper motor assembly $650.00
1/2/02 Replace wiper transmission $600.00
1/2/02 Spark Plugs $80.00
11/22/02 Overhaul water pump $841.00
11/22/02 Replace thermostat $177.00
11/22/02 Replace front motor mount $168.00
11/22/02 Replace rear motor mount $350.00
11/22/02 Replace trunk seal $450.00
1/10/03 Replace Radiator core $925.00
1/10/03 Overhaul carburettors $425.00
2/2/05 Replace LR bearings $1,002.00
5/26/05 Clean and adjust carburettors $275.00
1/6/06 Replace RF window lift $290.00
1/6/06 Bleed hydraulic system $122.90
2/15/06 Replace trailing arm hoses $424.00
3/8/06 Replace viscous fan coupling $554.00
5/10/06 Replace front right door seal $369.00
4/20/07 Replace driver door seal $449.00
4/20/07 Replace fuel gauge level unit $641.00
4/20/07 Replace power antenna $365.00
7/8/08 Replace battery $163.00
7/8/08 Replace rocker cover gaskets $1,129.00
7/8/08 Replace oil pressure transducer switch $121.00
7/8/08 Repair coolant header tank $321.00
7/8/08 Replace both front shock absorbers $1,620.00
7/14/08 Replace high pressure steering hose $513.00
7/14/08 Recharge AC $100.00
11/11/08 Bleed hydraulic system $250.00
11/11/08 Replace #1 Accumulator High Pressure Hose $483.00
11/11/08 Replace AC Compressor $996.00
11/11/08 Replace AC Dryer / Accumulator $231.00
11/11/08 Replace ignition condenser $140.00
3/4/09 Replace AC Compressor $750.00
3/4/09 Replace Front stabilizer bushings $307.00
3/4/09 Repair fuel sending unit $140.00
3/4/09 Replace both Front Compliance Bushings $1,410.00
3/4/09 Replace LR Bearing pin and washers $1,032.00
3/4/09 Replace steering coupling boot $53.00
6/9/09 Replace Ignition coil ballast $180.00
6/9/09 Replace fuel pump $989.00
6/9/09 O ring for brake reservoir $193.00
10/15/10 Replace windshield $750.00
10/15/10 Replace back window seal $95.00
10/15/10 Replace all door seals $350.00
10/15/10 Replace hood pads $580.00
10/15/10 Respray $10,191.00
4/2/11 Electronic Ignition $240.00
4/2/11 Spark Plugs $90.00
4/2/11 Replace thermostat $95.00
4/2/11 Replace hot water tap $75.00
4/2/11 fan motor $150.00
A hundred dollars on your hair, fifty on your nails, fifty on make-up, two hundred dollars for an outfit. You ladies spend four hundred dollars to bring home a thug that ain't worth ten cents!
#145
Good lord some of those costs are extremely high. tie rod ball joints $580?! Door seal $350-450?!?!?!
Mark Twain
#146
Lot of things cheaper than I thought.
The brake work is ridiculous though. Is the brake system tied into something else?
#147
#148
Looking at those prices makes me wonder if service for a Turbo RL would be similar in cost. Tgose seem to be 75-80% depreciated and although they lack the classic beauty of your 67 they still have quite a bit of presence.
#150
Deal with it.
#151
#152
Mark Twain
#153
theres a jag replacement that fits and is about 10x cheaper than the identical rolls branded fan clutch. the indy shop was probably smart enough to lead him toward the cheaper part
also... theres an early 90s turbo bentley for sale on RROC right now as well. those are MUCH more expensive to run. the guy on there has also posted his costs (dealer serviced with original bentley parts) and its approaching 6 figures as i recall... just since the late 90s. big money![]()
#154
#155
bumpers!
theyre not mint but it fits the rest of the car's patina![]()
#156
Nice - now, about the grill/radiator shell...
#157
Does this car not have the little headlight brush things?
Those are so choice.
I want a Rolls now.
#158
i know i know! hah
thats probably on the way back burner for now... at least until its on the ground and running and we see if we have any more mechanical things to shake out. a grill is easy to find and fit so im not too worried about getting my hands on one of those...
no headlight wipers on this guy, i think that was only for the later shadow 2s...
#159
I might have mentioned this before, but aside from repair costs, I think it would be awesome to daily one of those.
#160
#161
Tell me you are bringing her to Leavenworth this year. Show everyone how us crazy northwestern wa folks roll.
#162
Heh, it's nice to see someone else still using a non-ball bearing Craftsman toolbox. I've put off upgrading forever....... Word of advice, get some silicone spray for the drawer sliders. It's not as good as having ball bearings, but will make a nice difference, especially for heavily loaded drawers.
Oh, and nice car!
#163
#164
#165
Looking good, Lewis!
Feeling good, Valentine!
Originally Posted by Boyz in da Park
#166
#167
#168
just got word back from the trans shop that the rebuilt unit is ready, along with 2 other trans worth of spare parts - that will probably get sold on RROC when the time comes.
hoping to pick everything up friday afternoon and take some shots.
found a guy on RROC who will let me borrow a crank bolt socket so i can get runout on the flexplate, and use it while installing the trans.
if i can find enough time this should be wrapped up sooner rather than later
also poking around the car last weekend reminded me i probably need to order some random tuneup parts for when this hits the road - spark plugs, air filter, new plug wires.
thanks for reading and ill keep updating as we make more progress![]()
#170
Always wondered if you had a build thread for this car, or even pics. Subscribed
#171
#172
its baaaack!
and we managed to acquire a sizable collection of RHD 4spd stuff
working with alber's to get some tune up parts for its road debut - air filter looks like an old birds nest! hah and waiting on the crank sprocket tool - should be in this week, then the real work starts![]()
#174
ill keep posting stuff as soon as we make some more progress![]()
#175
Great project, very happy to see something so far out of the norm. Thanks and good luck with it![]()
