Keep us posted and please keep it stock. My grand farther was into pre-WW2 British Classics so this thread brings back some memories. He had a Bentley and a Rolls Royce. Cheers!
#211
just got off the phone with the transmission guy, sounds like he wants to see the car again to double check the band adjustment before we go too wild putting miles on it. so its first long trip from home will be for a quick checkup at the trans shop. will probably be a couple weeks before that happens as the paperwork for it is in oregon at the moment
stay tuned for more parts arrivals and updates![]()
#212
#213
#214
Everytime I read this thread I literally search for rollys royces.![]()
Tennessee, Tennessee, ain't no place I'd rather be..
#215
#216
should be picking up some new exhaust for it this weekend to replace the blown out stuff weve got on there now.
new trans dipstick tube should be here any day, then its off to the trans shop for final adjustments
more pictures to come probably next week![]()
#217
Brendan Dolan
Boardwalk Auto Mall
Volkswagen l Nissan l Chevrolet l Lotus
PRJCT.:R Chronicles l What I do in my free time.
#218
and for the record, with a filter change the engine ended up taking about 2.75 gallons of oil.
although upon draining what was in there i discovered some buildup on the bottom of the pan (pan will be getting dropped and new gaskets put in when i have a minute to do that) so perhaps after the gunk is removed itll take a full 3 gallons![]()
#219
this is such a badass project. i have to keep tabs on this.
obin![]()
#220
#221
got some more random parts in this weekend (motor mounts and an oil pan seal set)
as well as relocated the coil to the proper position, picked up a new exhaust from a fellow RROC member across the border, and got in the new spark plug wire set. also sorted out the wiring to the automatic choke solenoid.
ive got an aston martin distributor cap on order that should help the new wires fit up, then the ignition system will be all sorted.
ill have pictures of the new exhaust and all that jazz later this week.
this weeks project is sorting out insurance and getting it all plated up properly to hit the street. goal is to have it at the trans shop before the end of the week![]()
#222
had my first failure to proceed this morning
just died out of nowhere on the freeway this morning on the way to the transmission shop. seems like fuel pump(s)... reading RROC it sounds like its not uncommon to have one pump fail and go unnoticed, until the second pump fails and produces an FTP (failure to proceed)
on the up side, i got a chance to take some really nice shots of it yesterday in the sun with the hood and grill installed.
stay tuned, the adventure continues![]()
#224
i havent been there myself but ive seen pictures in the RROC newsletter i think the local chapter had a meet there where they covered some maintenance and whatnot. looked interesting
i really wanted to just haul this thing to someplace thatll troubleshoot the fuel system when it died, but i guess ill grin and bear it.
itching to get back to the shop tonight and dig through whats wrong though, didnt have time today before work when the tow truck dropped it off
#225
A list of mods, all cars ever owned and something cribbed from a book, song and/or movie were all just here. Sorry you missed out on my unique, snowflake-like individuality.
#227
#228
and photos!
and as i mentioned it left me stranded (or as they say in rolls speak - failed to proceed) yesterday. i originally suspected the fuel pump, and after seeing some of the horrific shots on RROC of failed ones i feared the worst. turns out, our dual pump has been replaced with a different more common dual SU setup, and it all looks to be in very good shape.
and the issue looks to be a failed coil, so an aftermarket replacement will be sourced shortly
the lucas one thats on there looks like it might even be the original coil
couple fuel pump shots:
will have more photos later of ignition parts as those arrive![]()
#229
i see how it is... no one is interested now that the car is no longer on jack stands and looks like a running vehicle![]()
#230
I want to drive it.
I've been looking for a fun weekend/Monterey/wine country car, and I've been surfing Craigslist for a survivor Corniche. I'll probably just end up with a TR-6.![]()
Brendan Dolan
Boardwalk Auto Mall
#231
Looks good all put together - very stately! You've come a long way and should be congratulated.
I had the ignition coil fail on my '66 and the original is the devil to source - I should have just upgraded, as you did.
A hundred dollars on your hair, fifty on your nails, fifty on make-up, two hundred dollars for an outfit. You ladies spend four hundred dollars to bring home a thug that ain't worth ten cents!
#232
thanks
perhaps for the time being youd even let the non-original grill slide??
it matches the chrome bumpers much better in my opinion... in any case its low on the list at the mooment...
im still working out a suitable upgrade for the coil, and debating whether to stick with one that requires the ballast resistor, or to go to an internally resisted coil...
ill probably call albers tomorrow and see what they recommend and what an aftermarket replacement for the stock coil would run.
otherwise ill just pick something at random from the mallory catalog and see how that ruffles the feathers on RROC![]()
#233
#234
I like this thread.
Great project. as the daughter of a British car owner, I fully approve.
A(u). Klasse A, unbeschrankt, ungedrosselt
Compared to a British roadster, all Volkswagens are reliable!
nevAr Lose - DE Minister of Foreign Affairs - IPROfftopikstan
#235
#236
fair enough! ive met another RROC guy just across the border with 2 parts cars, and hes got a couple good grills up there. just a matter of getting the $ together when the time comes...
i was poking around summit last night after i posted, and i think i can find something on there thatll work fine for a good new coil. itll look almost stock and fit in the stock location.
will take some measurements of the stock coil tonight and then order something![]()
#237
This is one of my fave build threads. Keep the updates coming oh and post videos!!!
#238
glad this is up and running, i need someone to drive me around![]()
#239
#241
this no-run issue has me kind of miffed...
first there was no spark, now there is spark... i think i could have had it going again today but the damn thing wet all the plugs during the troubleshooting - im reminded once again why carbs are a pain in the ass
anyway, the coil seems to check out when cold... but i suspect it got too hot last time and wouldnt fire. and it looks like its been thrown down a flight of concrete stairs, so its probably not a bad time to spend the $30 and get another one.
#243
#244
"If you really want feedback, make plans to send it to NRE for a twin turbo LSx install. That'll bring em out of the woodwork."
QFT
Car looks great, love this thread.
#245
