VWVortex.com - Breather Hose Kit, Mk4 1.8T, Reinforced Silicone
    Results 1 to 22 of 22
    Thread: Breather Hose Kit, Mk4 1.8T, Reinforced Silicone
    1. 10-27-2010 01:54 AM #1
      Looking under my hood today and spotted a crack on the breather hose near the top from the valve cover was wondering if anyone has had this kit on their car? http://www.034motorsport.com/engine-...e-p-19987.html
      was also looking at the eurojet ones is there any difference between the.
      TIA!!
    2. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      10-27-2010 02:05 AM #2
      Lots of people run those kits. Both are good and both are super similar to each other.
    3. 10-27-2010 02:14 AM #3
      cool thanks for the quick response!
    4. Member
      Sep 27th, 2009
      GTI 1.8T AUQ
      10-27-2010 09:13 AM #4
      I have the 034 kit. It's a nice piece of work. Practically it replaces all the pieces in the diagram except no. 1, 4 and 16:
    5. Member 01TornadoWolf's Avatar
      Jun 17th, 2009
      Winooski, VT
      2001 Jetta 1.8T Wolfsburg Edition
      10-27-2010 04:16 PM #5
      def recommend the 034 kit. good quality and replaces the brittle L-bend under the intake mani too
      | 802 |
    6. 10-28-2010 02:57 AM #6
      cri-cri
      thanks for posting up the picture! I'm ordering it tomorrow also with the valve cover gasket. My engine looks like there's little oil splatter around the manifold!!
    7. Member DrTrae's Avatar
      May 31st, 2005
      HHI, SC
      2009 2.5l JSW, 2002 1.8t SOCC New Beetle (SOLD)
      11-01-2010 02:52 PM #7
      Sorry to hijack. OP might be interested in this as well.
      Does anyone know if it's sensible to buy the Breather kit, if you want to run their Catch Can kit later down the road? (When I have the money ) I don't wanna buy the whole kit if I only need the lower block and maybe the block to intake mani hoses.
      Also, my question is in reference to a 02' NB 1.8t. I'm pretty sure the hoses aren't exactly in the same spots. I think the PCV and DV are positioned a little differently in their stock locations as well.
    8. Member 01TornadoWolf's Avatar
      Jun 17th, 2009
      Winooski, VT
      11-02-2010 02:11 PM #8
      Quote Originally Posted by DrTrae View Post
      i just use their lower pcv hose and then use 3/4" oil/fuel hose for the upper portion to my catch can. the 034 lower hose made installation easier. the upper portion is really not needed in my mind since it can easily be replaced with just 3/4" ID oil/fuel hose.
      | 802 |
    9. 11-02-2010 06:35 PM #9
      Quote Originally Posted by cri-cri View Post
      Folks who have '03 and up 1.8T who have the small nipple off the valve cover breather 034s replacement for hose number as 10 in the diagram will not work.
      Newer 1.8T has 06A 103 221 AQ.
      It looks like this.
      The extra outlet goes to a check valve which then ends up connecting to the small nipple on the valve cover.
    10. n00b
      Mar 2nd, 2012
      MK$ Jetta 1.8t
      03-12-2012 09:42 AM #10
      If the Breather Hose (3 way) is split, with big tear/ hole, what would be a symptom??? Possible Vacuum leak code? Not holding the boost? NEED HELP
    11. 07-26-2012 12:03 PM #11
      Cri Cri, is that the factory manuel?! where the hell are you getting those diagrams
    12. Junior Member Lampmode's Avatar
      Nov 9th, 2011
      Mount Joy, PA
      2004/VW/Jetta GLS 1.8T
      08-17-2012 01:58 PM #12
      Thought this may be helpful to post. Got it from the dealer. This is more like my engine with the little nipple on the valve cover that has been in question. 034 states the kit comes with a plug for this nipple.
    13. 08-17-2012 02:57 PM #13
      picked up the 034 kit today. has anyone found an online diy or install procedures?!
    14. Member
      Sep 17th, 2000
      San Ramon, CA
      08-20-2012 01:05 AM #14
      Has anyone used one of these kits with an AWD code engine? The only differences between the AWD and AWW seem to be the valve cover breather tube and the valve cover breather hose.
    15. Member
      Sep 17th, 2000
      San Ramon, CA
      08-20-2012 01:14 AM #15
      Nevermind, just found the AWD kit here http://www.034motorsport.com/engine-...e-p-22919.html .
    16. Member vwtribe's Avatar
      Mar 26th, 2007
      2003 VW GTI 1.8T l 2010 Honda CR-V l 2000 VW Jetta TDI- SOLD
      10-31-2013 08:26 PM #16
      Quote Originally Posted by Lampmode View Post
      What do you do with the hoses that come off of this small nipple once it is capped off? The new hoses in the 034 kit do not have any replacement for those.
      So 10 & 11 hoses would be gone, what do I do at the valve that 10 connects to?
      €uro Grüppe Imports
    17. Member RodgertheRabit II's Avatar
      Sep 13th, 2012
      North Carolina
      JB 20th
      10-31-2013 10:20 PM #17
      034 is a quality kit and works well in many configurations.. (shameless plug, Looking to sell mine to go more braided/custom if anyone is interested)
    18. Member suffocatemymind's Avatar
      Dec 10th, 2007
      Boston
      2003 Jetta Wolfsburg 20vT, 1994 Dusty Mauve Jetta 8v (sold)
      11-01-2013 05:29 PM #18
      Quote Originally Posted by RodgertheRabit II View Post
      Love my 034 kit w/catch can as well
      -Derek
      APR93 | 42DD 3" SS-VB TBE | BFIStg1 | 034CoilCover-CatchCan-PCV | ITG drop-in | MadMaxDV | BKR7EIX | R32-Poly CAB's | PowerFlex StrutB's | BilsteinTC | BBS CS5 17x7.5 ET35 | NewSouth | VCDS | Bentley
    19. Member suffocatemymind's Avatar
      Dec 10th, 2007
      Boston
      11-01-2013 05:31 PM #19
      Quote Originally Posted by vwtribe View Post
      Just cap off the nipple.
      -Derek
    20. Member suffocatemymind's Avatar
      Dec 10th, 2007
      Boston
      11-01-2013 05:48 PM #20
      Quote Originally Posted by westy604 View Post
      It's pretty straight forward...I found removing the metal clip on the block breather housing to be the biggest pain out if the whole thing. A long screwdriver through the IM runners, vice grip pliers, a small flat head, and patience. It really helps if you actually *know* what you're removing and what it all hooks up to. You'll be a little more confident in it all. A 1/4" U-joint and a 7mm socket will be your friend in tightening down the hose clamps.
      Get SAI hose and N249/N112/dipstick assembly out of the way and have at it. I was doing other things at the time which required me to remove the air box and that actually seemed to make things a little easier.
      -Derek
    21. 11-12-2013 01:25 AM #21
      Thanks for all the great info! I had a leak too and here is what I did:
      http://diy-vag-20vt.blogspot.gr/2013...-hose-kit.html
    22. Member vwtribe's Avatar
      Mar 26th, 2007
      11-12-2013 08:00 PM #22
      Quote Originally Posted by Imola Yellow GTi View Post
      It looks like this.
      This is incorrect, as I have a 2003 1.8T with that hose and the Urotuning/034 Breather Hose replacement kit DOES work if you find the correct diagram you will see the small nipple gets capped off and the number 10 hose comes right off of the new check valve and connects right to the underside of the intake manifold. At first this was my concern but after reviewing the various diagrams and variations I was able to see that those hoses are eliminated and the new kit streamlines this functionality. I have completed this swap, though I did get a CEL I was able to pinpoint that I did not tighten the hose clamp enough on that exact hose, after the adjustment and assuring it was on snug the CEL went away on it's own. If I can assist anyone else with this please feel free to contact me and I can share my struggles and resolutions if they will help. (Pick up an extra oil dipstick tube just in case )
      €uro Grüppe Imports
