VWVortex.com - NEED HELP: Battery Terminal Bolt Broke
    Results 1 to 14 of 14
    Thread: NEED HELP: Battery Terminal Bolt Broke
    1. Member shunut's Avatar
      Jul 14th, 2009
      Gilbert, AZ
      2002 GTI, 1.8t, Rave Green, 2010 Audi A4, Aruba Blue Pearl
      10-29-2010 05:31 PM #1
      The bolt that crimps the battery terminal together to hold it on the battery broke today. I contacted VW and you can't just buy the bolt, you have to buy the entire cable, I don't want to spend that kind of money just because the bolt broke, the rest of the cable is fine. Any suggestions on what I can do to make the cable stay connected to the battery, short of replacing the entire cable or terminal?
      Thanks for your help.
    2. 10-29-2010 05:36 PM #2
      Just take your old bolt and go to your local hardware store. May cost you $1.50.
    3. 10-29-2010 05:42 PM #3
      Duct tape.
    4. Member shunut's Avatar
      Jul 14th, 2009
      Gilbert, AZ
      10-29-2010 05:47 PM #4
      Really? I can't say that I have ever seen this type of bolt at the hardware store.
      This is the bolt I speak of:
      Sorry for the bad picture.
    5. Member post-it-note-killer's Avatar
      Mar 25th, 2004
      Mesa, AZ.
      Two VW's, A BMW, a Porsche, and one of those toaster things
      10-29-2010 05:57 PM #5
      I had the same problem. I visited Danny at Berge VW to come to the same frustrating conclusion. This is how I fixed the same problem on my white Corrado. It's been this way for probably close to a year now and has never slipped off or given me any issues. Granted it doesn't look pretty so if you're trying to have a show car then you may want to go a different route.
    6. Member shunut's Avatar
      Jul 14th, 2009
      Gilbert, AZ
      10-29-2010 06:00 PM #6
      Okay, cool, that seems like it could be a solution. Thanks.
    7. Member gtiguy12's Avatar
      May 22nd, 2006
      Phoenix, AZ
      10-29-2010 06:38 PM #7
      The bolts for the battery cable are available seperately. In ETKA, the part number can only be found if you look it up for a 1997 Jetta. The part number is 3A0 915 138 and they are about $8. Mike Bayne at Peoria Vw has them in stock. 623-875-4005
      Quote Originally Posted by VR6Vixen01 View Post
      In part, Jason has to run because it is faster than driving his car...
    8. Member post-it-note-killer's Avatar
      Mar 25th, 2004
      Mesa, AZ.
      10-29-2010 06:46 PM #8
      Quote Originally Posted by gtiguy12 View Post
      Dude, you rock. I actually ended up buying a new battery cable. I just haven't gotten around to installing it yet. Good call on the part number though. Thanks.
    9. Member shunut's Avatar
      Jul 14th, 2009
      Gilbert, AZ
      10-29-2010 07:07 PM #9
      Awesome! I was just thinking I was going to have to mill something out myself, however, hose clamp will have to do until I can get out to Peoria.
    10. Member shunut's Avatar
      Jul 14th, 2009
      Gilbert, AZ
      10-31-2010 10:23 AM #10
      I spoke to Mike over at Peoria VW and he informed me that Berge did indeed have one of these bolts. So I went down and got one, but unfortunately it was too small. The bolt length was fine but the "T" part of it was not wide enough for my terminal Guess the hose clamp will have to work for now...
    11. Member jazzcat2001's Avatar
      Mar 17th, 2004
      Hazelwood, MO
      97 GTi VR6
      10-31-2010 02:22 PM #11
      bought that for my 98 beetle when i had the same issue..think i got the replacement at camelback
      Jim- Owner of rustisnotacrime.com Like us on FB!
      Admin on Rival House. Like us on FB!
      SE Auto
    12. Banned vortexpert.'s Avatar
      Sep 27th, 2009
      Surprise, AZ
      68 chevelle, 98 GTI VR6 S/C, 00 hombre, 02 1.8t jetta wagon, Haro Mirra 540 Air
      10-31-2010 10:49 PM #12
      what engine?
    13. Member cxramire's Avatar
      Aug 29th, 2009
      Buckeye, AZ
      1981 Rabbit Pickup
      10-31-2010 11:52 PM #13
      any bolt will work as long its the same length and will fit thru the hole
    14. Member shunut's Avatar
      Jul 14th, 2009
      Gilbert, AZ
      11-01-2010 10:16 AM #14
      Quote Originally Posted by vortexpert. View Post
      what engine?
      Mine was a 1.8t.
      Quote Originally Posted by cxramire View Post
      How? If the bolt doesn't pull the two sides together and tighten it to the post, it won't hold. If you just put a regular bolt on it, it will just hold the 2 sides were they are and the terminal will not be tight on the post.
