VWVortex.com - How to bypass ignition switch?
    Results 1 to 19 of 19
    Thread: How to bypass ignition switch?
    1. 11-01-2010 12:33 AM #1
      I would like to know how to test/bypass my ignition switch to see if its any good anymore. Any and all help would be greatly appreciated
      Thanks, Matt
      Aug 26th, 2007
      '08 touareg, '97 jb de x2, '86 vr6 Rocco, '84 8v Rocco, '95 Vr cabby, 88 cabriolet 1.8t "both hers"
      11-01-2010 01:17 AM #2
      Just buy a new one it's super easy to replace and for 9 or so bucks it wouldn't hurt to just change it...
      Mar 23rd, 2008
      N/A
      N/A
      11-01-2010 01:29 AM #3
      You can buy a new ignition switch from autohausaz.com for less than $6 (plus shipping or free ground shipping on orders over $50).
      Remove the steering coumn shroud (two screws in the bottom, plus 4 snap together clips).
      Unplug the wiring harness connector from the existing ignition switch. Plug in replacement switch. Turn on and off replacement switch by inserting a slotblade screwdriver into the rectangular hole. You can even drive the car around by inserting the ignition key into the existing ignition lock and turning key to unlock the steering column. Start and stop the engine using the screwdriver.
      Permanently installing the replacement ignition switch is more involved, which is why you should test first, to make sure the old ignition switch really needs replacement.
    4. 11-01-2010 09:21 AM #4
      Ok so from what i am reading if i can start the car on the old switch with a screwdriver then it needs to be replaced?
      Apr 9th, 2007
      DC
      Too many to list here
      11-01-2010 09:33 AM #5
      Dear vw forum,
      Tell me how to steal a VW.
      kthx,
      Thief with 15 posts
    6. Member dankvwguy's Avatar
      Jul 23rd, 2005
      Atlanta, GA
      07 GTI
      11-01-2010 09:38 AM #6
      sooo one of you guys said its super easy and the other says its pretty involved im about to change mine out as well. i have some weird issues with my cd player not turning on, no door alert and my seatbelt chime sounds off when i turn on my headlights. if i push the ignition in (the part where u stick the key) while the car is stationary (with no key in it) and it starts making the normal chime noise. im assuming thats the ignition switch
      THE CBOX KREW
      There's always time for a GI Joe orgy
    7. 11-01-2010 09:40 AM #7
      I too am also having radion problems, blower problems, windshiled wiper, and dashlight problems man.
    8. Member subatomic's Avatar
      Jul 23rd, 2009
      Southcoast Ma
      mk3 jetta vr6
      11-01-2010 09:57 AM #8
      Quote Originally Posted by MJAsony2305 View Post
      I realize radion is a typo but it'd really suck to have to know about quantum field theory to work on your ignition switch
    9. Member dankvwguy's Avatar
      Jul 23rd, 2005
      Atlanta, GA
      07 GTI
      11-01-2010 10:06 AM #9
      Quote Originally Posted by subatomic View Post
      goes with your name perfectly
      THE CBOX KREW
    10. Member
      Apr 9th, 2007
      DC
      11-01-2010 10:10 AM #10
      jiggawatts up in this mother****er.
    11. Member dankvwguy's Avatar
      Jul 23rd, 2005
      Atlanta, GA
      07 GTI
      11-01-2010 10:15 AM #11
      put some neons on the mother****er
      THE CBOX KREW
    12. 11-01-2010 10:16 AM #12
      Hahahaha radio**
    13. Member
      Mar 23rd, 2008
      N/A
      N/A
      11-01-2010 11:24 AM #13
      No, you can't start the car with the oil switch.
      You need a new replacement switch to plug in temporarily to see if your old switch is defective, and needs to be replaced.
    14. 11-01-2010 11:44 AM #14
      Oh ok my bad i was misunderstanding your process all together, thank you for the advice
    15. Member
      Aug 26th, 2007
      11-01-2010 08:50 PM #15
      To change the switch you will need a precision screwdriver like for eyeglasses, a 13mm box end and a ratchet. Remove negative from battery unplug all wiring goin to steering column. Down by ur pedals there is black covers covering the bottom of the colum... Remove them and you will see a single bolt that holds a spline shaft together that's the 13mm. Remove that.. Now at the top there is a sheer bolt on the left hand side of the ignition housing I removed it with a set of needlenose vicegrips. Pull the steering column out.. A small spring will fall out of the bottom be sure to put back in!!! Replace ur switch and reinstall.. That's it in a nutshell don't make it harder than what it is fellas
    16. Banned
      Aug 15th, 2009
      land of groundhogs
      some lms, and some rms
      11-01-2010 08:53 PM #16
      Quote Originally Posted by sweetrocco420 View Post
      its good to have a buddy handy to help line up the spline and whatnot when you put everything back together.
    17. Member
      Aug 26th, 2007
      11-02-2010 12:21 AM #17
      Quote Originally Posted by pennswoods View Post
      def makes it ten times easier lol
    18. Member themagellan's Avatar
      Mar 30th, 2007
      East
      1991 Audi 200 20vt Quattro
      11-02-2010 12:49 AM #18
      Turn key
      + Radio shack
    19. Member
      Aug 26th, 2007
      11-02-2010 01:13 AM #19
      ^ this won't necessarly tell u if it's bad... It will start ur car however...
