you my friend get plenty of respect from me for doing all that work in your garage.... im in for the win... good luck man.. loks like she is on the way to fully built beast from the ground up![]()
#1
I update this fairly often, and keep most of my posts/pics in this thread. Enjoy
I'm sure some of you recently saw my random progress thread, so here is the random build thread...
So a really really quick run down of the story goes like this:
I had a 94' Wolfsburg Jetta that I traded straight up for my 99.5 GTi in July of 2008
It was a GLX; VR6, Leather, Climatronic, wood grain, the works.
After I picked it up, I immediately started some little bits of work. Springs, Joey-Mod, Boser.
By early October, the clutch was slipping real bad, so I decided to replace the clutch.
Which led to a full motor / trans rebuild.
Which led to a Full "Build"
After talking to some individuals, I started building/buying parts in the following order:
VRt - timing chains, rings, bearings, forged internals. SRI, turbo manifold.
^ the only pic I have of any of that
Then..
Shaved Bay
Then...
Ditch the VRt, get something more "Affordable", with more Available...
1.8t (AWP) swap, 02M w/ RSi (R32) gears, FMIC, 3" APR TBE, 20AE Big Brakes.
Shortly after all that, followed H&R coilovers, Euro Bumpers, GLi front Valance, GLi Side Skirts, 20th AE rear Valance. Shaved hatch.
I proceeded to pull my car from the Shop that it was at, and decided I would do all the work myself, in my garage. Up until this point, my car was more or less just a shell. No work done, just parts. It had sat, torn apart, for months untouched, as I helped the shop owner, getting nothing in return.
From that point forward, all the work was done in my garage at home. 100% by me. All motor work, all body work, all fabrications and modifications we're done by me in my garage.
^i had to modify the rad support to fit the Eurojet Race Core behind the Euro-Bumper.
I had to modify an APR Dual tip Jetta muffler to work with my single tip 20th AE valance.
So I proceeded with body work, and proceeded to finish the engine bay. I sprayed the entire interior of the car with sound deadening. Lots and lots of Sound Deadening.
I picked up more odds and ends, like seats (Recaro Reps), and other items.
At this point, I decided I should be going Big Turbo. So I picked up a T3 manifold, a Garret Super60, made a downpipe, picked up an external wastegate, and made everything work.
After spending about a month trying to get my 03' AWP engine and engine harness to work with my 99' VR compartment and interior harness, I realized that it wouldn't work, and cut through and modified the AWP compartment and interior harness to fit my shaved bay.
And what do you know, after fuxking with the VR harness for a month, 2 hours of shaving and installing the AWP harnesses, and the motor fired right up. No issues. :headbang:
After I got everything running, I realized it wasn't running correctly at all. It sounded like I was making a siht ton of boost, but wasn't seeing anything.
I was also getting a code for O2 sensor, Bank 1, Sensor 1 circuit malfunction.*
So I replaced the sensor, and nothing changed.
That code can be caused by a vacuum leak into the engine. So I vacuum tested everything and found nothing. It had to be the Turbo, which I suspected had blown seals, plus it was dumping coolant into my exhaust.
So I picked up a T04e from eBay for $110 shipped to my front door. New. Never used. Very nice haha.
I figure, I could rebuild my Super60 for $375, for a 250hp capable turbo. Or spend less and get the 50 trim T04e, which is more the size I am looking for. Plus, for $110, I could go through 3 of them for less than to have my Garret rebuilt, because it says Garret on the side.
So after I got the new turbo, I installed, and modified everything to make this set up work. ReWelded the downpipe, reran the oil lines, and blocked the turbo coolant lines.
And whaamm!!! *That siht hauls. It over-boosts, so it's in limp mode making 10psi, but the dump pipe off the wastegate SCREAMS!!!
Next on the list as per motor is*
•Devil's Own Water/Meth Injection
•Eurodyne (Maestro Suite) 630cc MAF-less File.
•Bosche High-Flow fuel pumps, in-line and in-tank
•-6an Fuel Lines
•034 High-Flow Fuel Rail
•Siemens 630cc Injectors
•4.0 bar FPR
•World Electronics Boost Controller
I picked up my Brock B1's, shortly after which I realized I need AirRide before I paint the car. So my next step is more body work, and AirRide, which I'm waiting for the Mk4 XL kit to release.
After getting the Brocks on the car, I realized my rear beam is bent, and that all the body work I had done is being jeopardized by my current ride height and stance. So AirRide will be happening before anything get painted.
Next up is my rear seat delete, and false floor to hide my Air Management, Battery, Water/Meth Injection, and Amp.
This project has been 2 years in the making. I should have it wrapped up by spring
There was a lit more involved with this build. I've just touched the main points. I will be posting pics of other modifications I made, as I remember them
So stay tuned for the finishing touches. It'll be worth the wait.
^PM me if you want to get involved
-Brah![]()
RESCUEdubs: We work purely on Technicalities around here.
99' GTi - 2.2l Stroker foreal | Down Like Syndrome
#2
For HIDS/LEDS PM Me
If you're thinking of doing a ZKW projector retrofit, you're on heroin. If you're thinking of bolting BMW lights up to where your GTI lights sit now, you're on poor quality heroin.
#3
#4
I always wondered where this car disappeared to. Glad to see you're still at it
#5
you dont need air????? just get coils
switches are for bitches![]()
#6
Props. The car is looking so good. Congrats man and Good luck the rest of the way
#7
looks very good, im excited to see the final project
Floss Filthy x Team Big Shark x Gengstout x VIP Modular
I am the east coast dealer for VIP MODULAR Wheels, PM me with all wheel questions pricing, powder coating, chroming, polishing and any other type of finish your little hearts can come up with.
#10
In for this one![]()
#12
wish I could spend as much time on my car as you
what color are you going?
#13
Looks like its coming along nicely
Mad props![]()
#15
Doubtful. I'm siting fully dumped on H&R coils. 1, not low enough for just sitting, 2, too low to drive this car like that. If I didn't have the amount of time and money into the bodywork on this car, I would absolutely rock coils. But just takin it out for "test drives", I already have to fix the driver side front and rear fenders, and my font bumper, and side skirts don't make it out of my driveway the way I'm sitting now.
I'd like to preserve/prolong the glory of this car once its finished longer than 10 minutes haha. PA roads =
Yes Sir, still at it. It's been a long process, but it's finally wrapping up. Job situations take an unfortunate priority over a build of this length
Thanks dude, I'm pretty pumped too
Believe me dude, I wish I could spend more time on it. It's fun at first, but then it becomes something that consumes you (and your wallet). For a while I was doing the "well I've done this much, I might as well do this too" thing, and day to day progress haulted for a while. Once I planned out the car, things started moving along a lot better.
Tha car is goin Baltic Green/Oceanic Pearl, with Mazda Black Forrest (black with fine blue and green metal flakes) roof and mirrors. It really looks good.
^ that's the actual color on my car, that's a shot of the frame rail after I painted it, before I painted the bay black
#17
Good to see that progress is still being made on this car.
Keep it up.![]()
#18
#19
You know I'm in
Got me motivated to start my winter project... Not sure if thats a good or bad thing though
But I will definitely be following this!![]()
#21
Cant wait to see the finished product. Hurry up
#24
Yeah dude, so good. Should be done soon. AirRide is en route
#27
looks like good stuff, <3 the b1's.![]()
instagram @jcdubb3r - exklusiv motorsports.
#29
#34
I'm glad I live right around the corner from Limerick. I definitely want to check this out when its finished. Looks sick.![]()
#35
this build has always been one of my favorites.
lots of real good taste here.
