VWVortex.com - Key fob not working, central convenience module
    Results 1 to 5 of 5
    Thread: Key fob not working, central convenience module
    1. Member ToTheTop's Avatar
      Apr 12th, 2007
      Long Island, NY
      '02 GTI 1.8t , '02 Passat 4Motion
      11-02-2010 11:29 PM #1
      I have a 2002 GTI 1.8t
      The remote started giving me problems a few weeks ago with locking/unlocking the car. It now rarely works at all, and when it doesn't, my interior lights don't work, neither do windows, heated seats, and alarm. I don't know if it is definitely a bad central convenience control module or if it could be one of the door latches. Sometimes when I hit unlock I will hear a very faint sound like the car is trying to unlock, but doesn't. Other times nothing. I have been removing the dome light fuse and reinstalling it...sometimes it would fix the problem but not so much anymore. Here is a scan...
      Chassis Type: 1J - VW G/J/B Mk4
      Scan: 01,02,03,08,15,17,19,22,35,46,56
      Address 01 -------------------------------------------------------
      Controller: 06A 906 032 LP
      Component: 1.8L R4/5VT G 0005
      Coding: 07500
      Shop #: WSC 05029
      9BWDE61J624002916 VWZ7Z0A3883831
      1 Fault Found:
      17978 - Engine Start Blocked by Immobilizer
      P1570 - 35-10 - - - Intermittent
      Readiness: 0000 0000
      Address 03 -------------------------------------------------------
      Controller: 1C0 907 379 D
      Component: ASR FRONT MK60 0103
      Coding: 0021505
      Shop #: WSC 00000
      No fault code found.
      Skipping Address 15-Airbags
      Address 17 -------------------------------------------------------
      Controller: 1J0 920 906 J
      Component: KOMBI+WEGFAHRSP VDO V02
      Coding: 07232
      Shop #: WSC 00050
      1 Fault Found:
      01330 - Central Control Module for Central Convenience (J393)
      49-10 - No Communications - Intermittent
      Address 19 -------------------------------------------------------
      Controller: 6N0 909 901
      Component: Gateway KCAN 0001
      Coding: 00006
      Shop #: WSC 00000
      1 Fault Found:
      Address 46 -------------------------------------------------------
      Controller: 1C0 959 799 C
      Component: 1J Komfortgerát HLO 0003
      Coding: 00064
      Shop #: WSC 00000
      5 Faults Found:
      00954 - Starter Inhibitor Relay (J433)
      28-00 - Short to B+
      00946 - Interior Light (W)
      28-10 - Short to B+ - Intermittent
      37-00 - Faulty
      00928 - Locking Module for Central Locking: Front Driver Side (F220)
      27-10 - Implausible Signal - Intermittent
      00929 - Locking Module for Central Locking: Front Passenger Side (F221)
      End -------------------------------------------------------
      I don't want to run out and replace the module if there are other possibilities. Any help is greatly appreciated.
    2. 11-03-2010 06:28 AM #2
      Have a look to see if the ccm is waterlogged. My passat b5 ccm earth was submerged in water and i had some of the problems you have. I dried the area and cleaned the terminal and all works fine now.
    3. Member ToTheTop's Avatar
      Apr 12th, 2007
      Long Island, NY
      11-03-2010 02:46 PM #3
      pretty sure it isn't located in the same spot as in the passat.
      i believe it is under the steering wheel and behind the trim...not under the carpet.
    4. Member ToTheTop's Avatar
      Apr 12th, 2007
      Long Island, NY
      11-04-2010 10:01 PM #4
      bump
    5. Member ToTheTop's Avatar
      Apr 12th, 2007
      Long Island, NY
      11-05-2010 04:02 PM #5
      bump, can anyone at least confirm it's location on a 2002 gti?
