VWVortex.com - Low Coolant Warning Light!
    Results 1 to 17 of 17
    Thread: Low Coolant Warning Light!
    1. Member jaso028's Avatar
      Aug 12th, 2007
      02.5 24v GLI, 09 Tiguan SEL 4 Motion
      11-03-2010 01:28 PM #1
      So for a few weeks now we have had the Coolant Warning light come on and off quite a bit...
      I have checked the coolant level and it is always in the same spot.. just above the Min mark...
      there are no leaks we have not added any coolant and have never had an issue..
      its a 05.5... the light will come on and then you shut the car off for a second start it up and you wont see it for weeks...
      I am starting to assume the sensor in the globe is bad or the wiring is messed up...
      has anyone experienced this? if so what have you dont to resolve this issue??
      I found a post about this from 08 but there was no definitive answer if the problem was resolved or not...
      Aug 10th, 2001
      Long Beach, CA
      17 Golf
      11-03-2010 01:31 PM #2
      Geez. Throw some water in it and see if the symptoms change. Fill it to the MAX mark when cold instead of living on the edge.
      John
      I'd stop drinking beer, but I'm no quitter.
    3. Member BluMagic's Avatar
      Apr 9th, 2008
      The middle west
      Twin Turbo Barge & Old Japanese Land Yacht
      11-03-2010 01:37 PM #3
      your coolant is just right at the mark... i had my flush done about 6mo ago. they didn't fill it to max... when it gets cold = molecules contract
      thats why it goes away if you turn your car off and on again when it warms a bit
      XBL B0B_MARLEY_MAR - The "0" in Bob is a zero
    4. Member jaso028's Avatar
      Aug 12th, 2007
      11-03-2010 01:41 PM #4
      wait what? LOL
      My coolant levels are perfectly fine warm and cold...
      The level does not move enough for it to warrant a low coolant warning...
      thats my issue is why am i getting a low coolant wanring when the levels are fine??
      I assume the sensor is bad in the Globe... or could this be another issue...
    5. Member rallydiesel's Avatar
      May 10th, 2006
      SK
      2006 Jetta TDI, 1981 Rabbit, 1991 Jetta TD (sold)
      11-03-2010 01:42 PM #5
      You're probably right. Or more likely there is a bad connection somewhere.
      Once you go "clack", you never go back.
    6. Junior Member Brigand's Avatar
      Jul 4th, 2006
      2006 GTI
      11-03-2010 01:56 PM #6
      I had the same thing happen to my 06 GTI. I added distilled water to the globe to bring it to the MAX mark. Warning has not come back for 1 year.
      Sep 10th, 2010
      2008 GTI
      11-03-2010 02:25 PM #7
      Quote Originally Posted by Elwood View Post
      x2
      If it's sitting at the MIN mark, that's the minimum amount of coolant needed in the tank...aka it's probably triggering the sensor every now and then. Add at least a few ounces of water and you probably won't be having any more problems
    8. Member BluMagic's Avatar
      Apr 9th, 2008
      The middle west
      11-03-2010 02:38 PM #8
      why are you asking for advice when you believe you already have the answer?
      it is a lot easier to add some water than replace a sensor.
      have you not done a coolant flush ever with the car?
    9. Member jaso028's Avatar
      Aug 12th, 2007
      11-03-2010 02:58 PM #9
      Quote Originally Posted by TheHeggz View Post
      x2
      Quote Originally Posted by Brigand View Post
      I guess I could add some water and see... just think its weird that it comes on when its not even below the min line...
      Quote Originally Posted by BluMagic View Post
      I dont have the answer, this is why I asked if anyone else has had this happen and what have they done to fix it...
      I know its easier to add water. But being that the water level is just above the min mark I dont see why or how it would every so often trigger a Low Coolant Warning...
      this is why I am asking about the sensor??
      Yes I have done a coolant flush... actually 2 of them...
      last one was done in Feb this year... and the light issue started back in August...
    10. Member BluMagic's Avatar
      Apr 9th, 2008
      The middle west
      11-03-2010 03:18 PM #10
      its a VW, the sensors are as sensitive as women on that time of the month... and the dash is as anxious to light up as a stoner.
      just be happy its not an MK4
    11. Member
      Sep 10th, 2010
      2008 GTI
      11-03-2010 03:21 PM #11
      Again...if it's just at the MIN mark, it moves back and forth when you drive, triggering the sensor sometimes. It's really not that hard to understand....have you ever triggered your low gas indicator, then you turn the car back on and it's fine? Same concept
      Your troubleshooting skills seem to leave a little to be desired good sir
    12. Member jaso028's Avatar
      Aug 12th, 2007
      11-03-2010 03:30 PM #12
      slow down.. I drive a MK4?? whats wrong with that? LOL
      my 24V has never done me wrong....
      I completly understand... I dont know why your being such a douche.. cant someone ask a simple question without finding the one a$$ on the tex...
      the Vortex has not and never will change....
      simply asked if it could be or if anyone has heard of it being the sensor... or if this was a common issue.. in my MK4 my coolant is below the min mark and i never trigger a light..
      I completly understand the water level and shifting while driving... I am asking to see if there are know problmes asides from adding water...
      Thank you...
    13. Member jtrujillo86's Avatar
      Aug 21st, 2005
      Denver, CO
      2016 Jetta 1.8T SEL, 2016.5 Mazda CX-5 Touring, 2002 Passat GLX V6 4Motion
      11-03-2010 03:42 PM #13
      HILARIOUS! This is my new sig
      - Jeremy.
      It's a VW; the sensors are as sensitive as women on that time of the month . . . and the dash is as anxious to light up as a stoner.
    14. Member jaso028's Avatar
      Aug 12th, 2007
      11-03-2010 03:53 PM #14
      Quote Originally Posted by jtrujillo86 View Post
      - Jeremy.
      Yeah I meant to tell him that was pretty good...
    15. Member
      Sep 10th, 2010
      2008 GTI
      11-03-2010 04:08 PM #15
      Quote Originally Posted by jaso028 View Post
      Thank you...
      I'm "being a douche" because you're not showing any sense of self sufficiency or common sense. The first LOGICAL step to troubleshooting a tank of liquid that's telling you the level is below what is needed, when you can SEE the level is at or around the minimum, is to add said liquid...no? It frustrates me to see so many retarded posts daily about people asking stupid questions without even trying to think about it themselves. But that's a whole 'nother rant and is a nice side effect of the information age and instant gratification running rampant.
      I'm not mad at you, nor was I trying to be a douche, it just seemed a little funny that multiple ppl told you to increase the coolant level, but you continued to insist that you thought it was something else rather than trying the obvious solution first. Blu was right, sensitive sensors are not out of the ordinary. Don't make a mountain out a mole hill. If you're going to ASK for help, then TRY the reasonable solutions offered.
      I love you.
    16. Member jaso028's Avatar
      Aug 12th, 2007
      11-03-2010 04:49 PM #16
      I love you.
      I apologize... exactly why I cannot be on vortex @ work.. I get pissed here and carry it over.. LOL
      I am not a child nor am i new to Vortex... So we are good here.. I am more familar with MK3 and MK4... Mk5's are whole new ball game of weird ****!!!
      I never said I was not going to try adding water to the level... I was just asking if the sensor in the MKV was or is a know problem... I know VW's are very sensitive.. I am on my 6th one... 5 MK3's and a MK4... I am not new to the oddest of issues, like I said just wanted to know if the sensor was common issue...
      I love you too (no homo)
    17. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      11-03-2010 05:15 PM #17
      AFAIK these cars use conductive coolant level sensors
      Distilled water isn't very conductive, antifreeze even less.
      Is it possible that when you filled it back up you went a little high on the coolant to water ratio?
      Add water to top it off, as the mix gets dirty is will be more conductive.
