VWVortex.com - Oil Light. Flashing and Sound.
    Results 1 to 14 of 14
    Thread: Oil Light. Flashing and Sound.
    1. n00b
      Nov 8th, 2010
      BC, Canada
      1995 VW Golf CL
      11-08-2010 01:07 PM #1
      I have a 1995 Golf cl and when i was driving home the oil light lit up and started to flash and beep. i shifted down into a lower gear and it stopped. when i got home i checked the oil level and it is still full. i drove it this morning and the light never came on. Any ideas on what this could be? thanks
    2. Banned
      Sep 5th, 2010
      11-08-2010 02:10 PM #2
      Your pump is going out, or the sensor, one or the other. Don't drive it now (important!!!) Replace sensor first, don't drive it far, do a few miles running around your hood, in case it needs to be pushed back. If it does come back on, immediately stop car and cut. Then replace pump.
      Good luck
    3. Member scrambledeggs's Avatar
      Jun 28th, 2010
      SEPA
      mk4 24v gti and 2 mk3's all sold
      01-01-2011 03:51 PM #3
      mine did the same thing the other day. flashed and beeped twice then went off. today it beeped once and i think the light flashed for half a second
      Quote Originally Posted by MahTrek=] View Post
      Oh and stop saying jolf
    4. Member Sallad's Avatar
      Aug 29th, 2004
      Kelowna, BC
      '94 Jetta 2.0 16v
      01-01-2011 03:53 PM #4
      Do an oil change and switch to a slightly heavier oil. This helped mine.
      Pro Patria
      Making power, 4 valves at a time.
      MkIII 16v Club.
    5. Member scrambledeggs's Avatar
      Jun 28th, 2010
      SEPA
      01-01-2011 03:57 PM #5
      by the way... oil temp sensor or oil level sensor?
    6. Member scrambledeggs's Avatar
      Jun 28th, 2010
      SEPA
      01-01-2011 04:00 PM #6
      i'm starting to have the same problem. it blinked & beeped at me the other day then same thing today. on GAP, i see the oil temp sensor or oil level sensor so i'm confused
    7. Member Greg_J's Avatar
      Oct 30th, 2005
      Ontario, Canada
      '03 Wagon TDI, '16 GLI Autobahn 6MT
      01-01-2011 06:42 PM #7
      Quote Originally Posted by rankadoodle View Post
      Good luck
      these are the sensors he's ^^ talking about. replace both. white one is located on the oil filter flange, blue one is located on the drivers side of the head.
      http://www.germanautoparts.com/Volks...ectrical/150/4
      Quote Originally Posted by ennui_delphian View Post
      Don't anger canadiun lesbian...
    8. 01-04-2011 03:19 PM #8
      I have the same problem just got my VW jetta 2.0 1999 old body style, and the light for Oil start flashing and buzzing, after we change the Oil and the oil filter, now I'am about to change the two of the sensors, and will change 10w-30 with 20w-50 ... what I know is if the problems are in the sensor and if you add havier oil and more thick, this lie the sensor, and the light goes off
    9. Member scrambledeggs's Avatar
      Jun 28th, 2010
      SEPA
      01-15-2011 02:03 AM #9
      Quote Originally Posted by Sallad View Post
      what oil are you using? 5w30, 10w30, etc?
      i've never had a problem w/ my oil pressure or anything until after my last oil change (which was even a month or two ago and i put in 5w30) and now my light's randomly coming on, flashing and beeping then shutting off. i replaced both switches today then the light was on and beeping for like 30 seconds.
    10. 01-15-2011 02:54 AM #10
      Drain some oil out of your oil pan and see if there is any metal shavings in there... if not finish draining the oil and check the oil pump for clogs.
    11. Member scrambledeggs's Avatar
      Jun 28th, 2010
      SEPA
      01-17-2011 05:34 PM #11
      i have a pretty good thread going, called "flashing oil light" or "oil light flashing" i forget which one. check that out
    12. Member Sallad's Avatar
      Aug 29th, 2004
      Kelowna, BC
      '94 Jetta 2.0 16v
      01-17-2011 07:52 PM #12
      Quote Originally Posted by scrambledeggs View Post
      20W50 all year.
      Pro Patria
      MkIII 16v Club.
    13. Banned
      May 15th, 2006
      PNW
      Jettas.. Dodge Cummins, 1985 Trans Am,
      01-17-2011 08:22 PM #13
      True..... it's a fun thread... full of insight and idiocy
    14. Banned
      May 15th, 2006
      PNW
      01-17-2011 08:41 PM #14
      If it was beeping, your pressure was below 25 PSI while revs were over 2000
      Here is a hint I previously posted, much to the dismay of people quoting the VW manual that was refering to oil recommendations for a new motor.
      Install a real pressure gauge.
      Determine if your oil pickup is obstructed.
      A 200,000 mile car has worn bearings, which allow more flow, which causes a decrease in pressure, so... use a thicker oil. Start with 10W40.. preferably synthetic. If pressure is still low, go to 20W50
      Be advised, I had one Fool jump in spewing nonsense because I said I would not put 5W30 in a high mileage car.... actually, I wouldn't put it in my riding mower.
      This is a very elementary concept. Your motor will determine what oil weight you need... it conveys this info via the oil pressure gauge.
      It does not matter what a 15 year old VW manual says.
      Your motor is not new.
