i thought this was good the other day.. really decent write up not for our car but gti.. not sure how alike they are. but its quality info reguardless.
http://forums.tdiclub.com/showthread.php?t=250295
#1
Hey guys, before you tell me to search there is no DIY for the R32 just threads asking questions about getting it done at shops. with that said im going to be doing this with my buddy who is a professional mechanic but not for VW. i have the wheel bearing kit from ECS which includes the new bearing, c clip, and new bolt. i have a 3 jaw puller and the tools needed (sockets, breaker bar, ect) is there antything i should know before doing this and do i have everything needed to change an R32 wheel bearing.
#2
NOREASTR
NEK
#3
the TDI club DIY is good, the only thing is that I was able to remove the bearing piece that sticks to the hub with a small gear puller but needed to use a hose clamp around the legs because it will slip off.
fun job, the bearing tool saves you so much trouble, removing the knucke to have the bearing pressed, specially if you dont have a press will add tons of time to the project.
#5
#6
NOREASTR
NEK
#8
X2. Just did the REAR wheel bearing last weekend. Front bearings were done about a month ago. No need to remove the spindles or have it aligned if you use the bearing removal/install tool. Works awesome but you need to be very careful with how you use it. Use the wrong size and it will screw things up.
Now
Ford Flex AWD, Vulcan Nomad 1600
Prior Ownership:
VW Mk4 R32, Chevy Z71 Colorado 4x4, Audi A6 2.7T (RS6 replica wannabe), Audi 90Q, BMW X5 4.4i, VW 20AE GTI #0651, Aprilia RSV Mille, Suzuki V-Strom DL1000
#9
So I tried to do my bearing today and I'm stopped. Can't find a Allen key /socket to take out the axle. What have you guys done?
#11
You will need to get a 17mm allen socket. To break it loose you will need to have the wheel on and car on the ground as it's torqued on there REALLY good.
#12
The only place I could find that stocked that size Allen key was Sears. They sell it as part of set of 4 for around $45
#13
#14
#15
