Originally Posted by
dsl_lvr
I am going to append to this thread even though it is quite old. But... so am I.
'91 Jetta: Intermittent problem 2 or 3 times in January, no problem in Feb-Mar. Continuious problem since mid-Apr. I can't drive the car now.
Cold-cranking: Glow-off the plugs, hit the starter, engine fires immediately but not quite enough to run and then no fire just like the glow plugs turned off. If I keep re-glowing and cranking for a really long time, -like 2-3 minutes, engine will start but only continue running with the starter engaged. After about 10-sec, you can drop out the starter but the engine is barely able to keep going. The engine continues to get stronger as it warms a little and finally is running at full strength after maybe 4-5 minutes. Note: this is ALL cylinders, not a "skipping" condition where one or more cylinders aren't firing while the others are firing normally.
What I have done: I bought a chinese-made glow plug relay off the internet for $8 and it won't even respond normally on the initial glow-off. Wasted money. I have performed EVERY test of the glow plug circuit and original relay as prescribed by the Bentley manual, Passes every one except te one with the temperature sensor wire grounded and you are supposed to get voltage on the glow plugs with the switch in the cranking position. I get 0.0002-volt. But, I really DO have voltage when I crank with the sensor plugged-in and really cranking. I changed the glow plug fuse just for the heck of it. I have not done the current-flow test on the glow plugs because it was running on all cylinders even when this was an intermittent problem so I don't suspect a single bad glow-plug.
This just has me buffaloed. Could it be a shorted glow plug instead of thenormal failure that is an open glow plug? A shorted plug might sink all the current through it and keep them all from getting hot.
Any "out of the box" ideas? Please advise.....
