VWVortex.com - Bad starter?
    Results 1 to 10 of 10
    Thread: Bad starter?
    1. Member StevenPirre's Avatar
      Mar 3rd, 2009
      CT
      01 GTI 1.8t
      11-17-2010 09:45 PM #1
      Today I drove my car parked it for a few minutes, when i went to start it nothing. The dash lights up battery is at full voltage but there's no sound from the starter. I pop started it and it drives fine however just wont start by turning the key. How do I find out if it is the Starter,Ignition switch, or the Clutch switch.
      Car> 2001 GTI 1.8t Engine Code AWW
      Dec 17th, 2006
      Texas
      2003 Jetta
      11-17-2010 10:13 PM #2
      how did you test the battery? what was the voltage?
      XBOX GT:SO ICY GOON SQD mainly play MW2 and Halo
    3. Member StevenPirre's Avatar
      Mar 3rd, 2009
      CT
      01 GTI 1.8t
      11-17-2010 11:07 PM #3
      The battery was first jumped and that didnt help. Then i used the meter we have at work to test voltage as well as the output. Turn on lights, blower, radio etc. 12.6V with engine off. After starting...pop starting 14.8V Ill check fuses tomorrow. I ruled out the Ignition, i hear my fuel pump when i turn the key.
    4. Member SlayStation's Avatar
      Aug 17th, 2010
      Montreal
      20vT mk1 cabby
      11-17-2010 11:17 PM #4
      Check all your connections at the starter and the battery, make sure they're clean/not corroded.
    5. Member swagger rob's Avatar
      Aug 13th, 2009
      Virginia Beach, VA
      2000 Jetta VRT / 2003 Jeep Liberty
      11-18-2010 08:13 AM #5
      Quote Originally Posted by SlayStation View Post
      That there, other wise you're looking at a bad starter most likely
    6. Member StevenPirre's Avatar
      Mar 3rd, 2009
      CT
      01 GTI 1.8t
      11-18-2010 08:59 AM #6
      How do i check the clutch safety to see if that's the problem?
    7. Member swagger rob's Avatar
      Aug 13th, 2009
      Virginia Beach, VA
      11-18-2010 09:05 AM #7
      there is a switch for it, I always here of it failing the other direction...where it starts with out depressing the clutch. But that could still be a possibilty. check for voltage at your starter, and also check for voltage at the switch. I guess you could do it two ways, check for voltage or read ohms and look for the switch to close.
      I'm sure there is a way to check it in the bentley, but I dont have one on hand
    8. Member munky18t's Avatar
      Aug 30th, 2004
      Nova Scotia, Canada
      2005 Jetta GLI
      11-18-2010 10:12 AM #8
      There a braided copper wire that runs from the starter to the selnoid that will rust apart... same thing happened to me and left me and the wife stranded on the side of the road on our honeymoon
      You can see it in this pic
    9. Member StevenPirre's Avatar
      Mar 3rd, 2009
      CT
      01 GTI 1.8t
      11-18-2010 01:34 PM #9
      Thank you. Ill check that out. Its not the clutch switch I jumped the pins on the connector and got nothing. So Its the starter. From looking at the picture i see the copper wire. Did you repair it or get a new one? How should I repair it?
    10. Member swagger rob's Avatar
      Aug 13th, 2009
      Virginia Beach, VA
      11-18-2010 01:37 PM #10
      It's probably better to just replace it, for the piece of mind
