Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 106 to 140 of 150
Thread: Consolidation of Information: Haldex into Corrado. (02m, Syncro)
  1. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    10-04-2012 11:13 PM #106
    Well eventually I would like to have a mk2 rear crossmember and gas tank... wouldn't we all.
    But first I have to finish up this 02m
    Mar 20th, 2009
    Rochester, NY
    95 urS6, 91 golf, 84 rabbit, 09 hypermotard, corrados
    10-05-2012 08:14 AM #107
    Quote Originally Posted by JamesS View Post
    I dont have the time or money to try and source stuff from Europe. It is a pain in the ass and people are unreliable.
    you will spend more time (which is =$) ****ing around with the wrong **** than if you just did it right
    passat gas tanks and floor pans dont fit corrados. neither do the rear beam mounting plates. get the right parts, bolt them in and enjoy the car. rather than hack something together
  3. Member cata's Avatar
    May 19th, 2006
    Canada eh
    10-05-2012 10:42 AM #108
    ^thank you for confirming this. Deff not touching that Passat floorpan anymore.
  4. Member
    Mar 20th, 2009
    Rochester, NY
    10-05-2012 10:50 AM #109
    Quote Originally Posted by cata View Post
    golf 2 stuff is the only stuff that fits, and even that needs minor modifications.
  5. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    10-05-2012 06:26 PM #110
    If I run vr6 hubs redrilled to 4x100 in g60 spindles I am assuming I would use g60 wheel bearings? From what I can see the wheel bearings themselves are the same but they mount differently- although this would probably be the difference between + suspension and normal suspension.
    Just trying to make sure I order the right parts.
  6. 10-05-2012 08:32 PM #111
    Corrado syncro using Passat mounts, crossmember and fuel tank.
    Build thread.
    Located up in Edmonton, if somebody wants to take a closer look at how the parts don't fit togeather.
    -Dave
  7. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    93' SLC VR6 90' G60 99' Jetta
    10-05-2012 08:39 PM #112
    Damn son is that your fuel tank in the last pic??? Switch to a fuel cell.
    Sent while sitting on my ass VIA my iPad
    [B] INSTAGRAM: europeein
    Facebook: facebook.com/addmichael
  8. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    10-05-2012 08:49 PM #113
    Quote Originally Posted by MrDave View Post
    -Dave
    And if you used the mk2 mounts you wouldnt have to do those modifications to the body... although Im sure you know this. For someone with your fabbing skills it doesnt seem like much to use the 4 bolt axle mounts compared the just bolting in the 3 bolt ones.
  9. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    10-05-2012 08:50 PM #114
    Quote Originally Posted by HavokRuels View Post
    Fuel cells are lame and put the weight too high IMO unless they are custom made.
  10. Member
    Nov 1st, 2009
    Phenix City, AL
    90 jetta coupe w/R32 engine swap - Project
    10-05-2012 09:31 PM #115
    Yes the g60 bearings will work.
    My R32 swap and shaved bay jetta coupe build
    http://forums.vwvortex.com/showthrea...ding-the-beast
  11. 10-05-2012 10:44 PM #116
    To fit the rear diff and rear subframe, at an absolute minimum, the spare tire well needs to be removed.
    To fit the mk2 syncro or the B3 syncro tank, the rear floor needs to come out. By the time you're doing that sort of thing, fitting the B3 4-bolt mount is really nothing.
    I wanted to run a factory-type fuel tank, not a fuel cell. As it stands, to insure the car I had to have a safety inspection. I mentioned nothing about modifying the car for AWD, the mechanic mentioned nothing about the car being modified or anything looking out of place. I'd say that's a good sign.
    The Passat tank is a hemeroid on the back of the car.
    Here's another one:
    He made it fit with the mk2 syncro floor.
    And is running the Passat crossmember.
    This thread:Corrado-newbie-and-another-AWD-corrado-build
    -Dave
  12. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    10-05-2012 11:00 PM #117
    Here's another one:
    -Dave
    Your car is so clean, you should have just removed the spare well in its entirety.
  13. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    10-05-2012 11:03 PM #118
    Its not his car...
    But anyways, I think that the passat tank could be overcome easily with thinking out of the box. What about just adding a rear valence to at least hide it?
    Quote Originally Posted by eodtech View Post
    Thanks
  14. 10-05-2012 11:35 PM #119
    That's the plan, just not there yet.
    I mounted my amps in what was left of the Passat's spare tire well.
    Covered that with a shortened cover plate from a B3 wagon.
    -Dave
  15. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    10-07-2012 04:17 PM #120
    The more I look at it the more I just want to say FFFF it and put in a fuel cell (but mount it low):
  16. Member raddo's Avatar
    Dec 22nd, 1999
    Pasadena Maryland
    93 Corrado VR6T,06 Audi A4 2.0T
    10-07-2012 08:02 PM #121
    Now your thinking like a fabricator. Fuel cells are easy to make so why not make one to fit since your going to all this trouble to make your car syncro anyway. That's my thought on the whole fuel cell topic anyway. I wish my house would stop falling apart so I can get my project underway
  17. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    10-14-2012 04:57 PM #122
    I have finally finalized in my mind the plan for the rear end. Looking at PSUCorrado's syncro swap again I realized that grafting floor pans and trying to source european parts just isn't worth it when it is so straightforward to just do a custom setup. The passat setup is a compromise and offers no benefit compared to a fuel cell setup. I have decided that I would much rather have a fuel cell to fill up in my trunk then a tumour on the back of my car.
    All I am going to do is remove my spare tire well, mount up the axle using the mk2 3 bolt mounts and then weld in the differential support. Then I will put in a 12 gallon or 15 gallon fuel cell but mount it behind the diff and as low as possible. Doing it like this will make it MUCH easier and straightforward. All I need now is a fuel cell, mk2 axle mounts, haldex axle conversion and differential support.
    Doesn't mean much to other people, but I am pretty happy I finally have a definitive plan to work towards.
  18. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    11-02-2012 06:03 PM #123
    Quick update of the original post, added some pics and info.
  19. Member VRT's Avatar
    Dec 7th, 2001
    Canada
    90 corrado 20/20 haldex, 2003 jetta
    11-02-2012 07:28 PM #124
    Any question You need to have answered? I think I have a good handle on it
  20. 11-02-2012 07:42 PM #125
    James,
    the 3-bolt rear beam brackets from a Quantum Syncro Wagon can also be used on the mk2/mk3/corrado.
    http://forums.vwvortex.com/showthread.php?4507939
    -Dave
  21. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    11-07-2012 11:19 PM #126
    Quote Originally Posted by VRT View Post
    As of now I think I am good, but I do appreciate the offer. I'm sure once I get down to the actual swap I'll need to send you a couple PMs
    James,
    -Dave
    Thanks for the info. Will add it to the thread. Anyone looking to do a syncro/haldex swap should definitely check out your thread on the CCC- you did a great job of the write up and I appreciate the documentation you did.
  22. 12-17-2012 03:49 PM #127
    For JamesS:
    syncro install in mk3, bus fuel tank, scratch-built rear diff-hanger/crossmember.
    http://forums.vwvortex.com/showthrea...yncro-to-a-MK3
    I wouldn't want to install a fuel tank in the trunk like that, definately wouldn't in the hatch of a Corrado, but it is food for thought.
    -Dave
  23. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    12-17-2012 06:37 PM #128
    For JamesS:
    -Dave
    Thanks! I love the way that setup was done minus the fuel tank. Makes sense... don't really need the crossmember and there is no need to fab the points to bolt it in when you can just weld it. I am thinking 2"x1" chromoly would do the job perfectly and stiffen the chassis considerably.
  24. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    12-23-2012 11:10 PM #129
    Quick update with the difference between a 4 cylinder 02a axle and an 02m axle:
    This is why if you are staying with 4 bolt hubs you need to have them machined:
    And... should have some more progress in a couple weeks.
  25. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    12-27-2012 10:13 PM #130
    Looks like the transfer case is going to have clearance issues.
    Likely need to source a syncro downpipe... anyone have any insight?
  26. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    91 Corrado 2.0l 16v on MS3X, Parked like Jurassic... 83 Cabby 1.8l 16v... 88 Powerplay XLT-185
    12-27-2012 11:14 PM #131
    Make one.
    Quote Originally Posted by crazynorweegian View Post
    Good luck, might want to get vaccinated for "while-I-am-in-there" syndrome.
    tek-euro.com SpoonFedTuning
    my Corrado's specs on corrado-database / My Corrado Build Thread / My Cabby Build Thread / My Boat Build: 18' Powerplay w/5.7l V8
  27. Member
    Mar 20th, 2009
    Rochester, NY
    12-28-2012 08:17 AM #132
    i have one for $200 shipped
  28. Member 1956dub's Avatar
    Jun 12th, 2010
    Castle Rock, WA
    I own the SLC driving experience
    12-28-2012 12:29 PM #133
    And the rest of my haul:
    You know your sick when a picture like this gets you excited!!
    Quote Originally Posted by Rento_VW View Post
    Needs a real Zender wing.... lower it.
  29. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    01-10-2013 08:47 PM #134
    Have a question if anyone has insight...
    First, I am looking at the internal slave cylinder of the 02m and my clutch line from USP. It has one female fitting and one banjo fitting... Im not sure how this is compatible even though it was specified for Corrado to 02m slave. It looks like I need a piece which fits between the 02m male slave and the male line
    But, as far as I can see the Corrado master does not use a banjo fitting.
    I would look up the part # but my pirated etka has been giving me troubles.
    As far as an update I am very happy to get a syncro downpipe! Thanks to Dave for shipping it out to me quickly, really appreciate it.
    Blurry pic but shows how it goes around the transfer case.
  30. Member dasbeast3.0's Avatar
    Aug 14th, 2007
    Grizzly bear
    01-10-2013 10:19 PM #135
    My usp line had a female end and the clip-in male end. I'd send it back and get the old style, especially if it didint come with the banjo bolt u need. That piece you need is called a breather btw, just buy it new w/ new o rings, clips and bleeder, its cheap. They always leak, new wont give ya trouble.
  31. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    01-10-2013 11:27 PM #136
    Thanks for the info. I do have the bango bolt, I wonder whether I can thread that into my master....
    The bleeder block is PN 1J0 721 468 C if anyone comes across this in the future.
  32. 01-12-2013 06:47 AM #137
    Hi. first of all Im from Europe, car is 94 vr6 , so I think I don't have too much trouble finding euro parts.
    I would like to stay as OEM as possible.
    When going the Rallye floorpan way, what cross member and what fueltank can I mount?
    If the only OEM fueltank option is the rallye one and I cant find it , I will use the 70 liter ( please say which one ) and after I pass MOT I will fabricate a fuelcell , BUT other parts must be OEM.
    Is there a difference between syncro rearaxle assemblys from different models mentioned here?
    also, what is the p/n for the 3 bolt brackets that is a straight fit?
    My plan is to gather most of the parts for the haldex swap, then do a documented/detailed plan, and ask for a permission from where we register our cars, and then start building it, taking photos of every step so when I go to get it registered as AWD I dont have any troubles, the laws are really strict here.
    please copy paste this, so its understandable in one way
    rallye floor pan OEM way:
    crossmember from .......... /........
    fueltank options : ........../........
    syncro rear assembly: ........./.........
    part number for 3 bolt brakcets :
    and the spoonlike looking parts that bolt onto :
    thanks.
  33. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    01-13-2013 09:39 PM #138
    Quote Originally Posted by hendrikbmx View Post
    crossmember from .......... /.......Rallye or other mk2
    fueltank options : ........../........ syncro 50l MK2
    syncro rear assembly: ........./......... Passat, All mk2 syncro
    part number for 3 bolt brakcets : c191 505 129
    and the spoonlike looking parts that bolt onto :c191 505 119
    thanks.
  34. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    01-13-2013 09:51 PM #139
    Did some more work this weekend. Mk3 subframe is in for test fitting.
    This is where the mk3 subframe has to be modified to match up to the Corrado:
    USP conversion line did work... just worried me initially since it uses a banjo bolt compared to the factory threaded hard line
    Lottsa room for the driveshaft....eventually
    Also began working on the rear output shaft which was damaged when the transmission was removed. I think whoever took it out took an air hammer to it or something Certainly has caused me some grief.
    Luckily I was able to source a new cast piece for 70 bucks as opposed to the $500 my local VW dealer wanted for it But the radial seal is still stupid expensive at $80 for a piece of rubber
    Finally, some people might be interested in my powder coating setup. Pretty ghetto but it gets the job done.
  35. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    '90 Corrado | '62 Harley Panhead
    01-13-2013 11:06 PM #140
    What I usually do with that rear Kframe strut is cut out a section and then weld it up. A little more work, but prevents you from having to use washers, etc.
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
