Page 1 of 146 1 2 3 4 5 11 51 101 ... LastLast
Results 1 to 35 of 5084
Thread: OEM+ (My Progress Thread)
  1. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    11-20-2010 09:52 PM #1
    I've moved the build here:
    Build Part II
    Welcome to the OEM+ GLI Build
    Zach!
    19 y/o
    Santa Clara University Business Student
    Yogurt Swirler and Carpenter's Apprentice and Part Sales@HardParkerGarage
    SF Bay Area
    Hella4
    Index Below!
    2005 Jetta GLI
    1.8t AWP Engine with a 09A Tiptronic Transmission
    Black Magic Pearl
    ~103,000 miles
    Modifications:
    Interior:
    OEM .:R32 Steering Wheel
    OEM Climatronic Swap
    CheckTemp II
    GTI Dash Board Swap (Shaved Airbag Door)
    New South Boost Gauge in 42DD A-Pillar Pod
    COGA-PA Public Adress and Musical Horn
    C-Pillar Brace with Camera Mount
    Hardwood Flooring in Trunk
    Audi TT Automatic Leather Shift Knob
    OEM MFD Version D Navigaiton
    -Aux-Input Harness
    OEM .:R-Line Floormats
    OEM Seat Arosa Headlight Switch W/ Rear Fog
    Custom Brushed Aluminum B-Pillar Seat Belt Sliders
    Wheels:
    18 x 8.5 BBS RSIIs et38
    -5x120 Bolt Pattern
    -Full Polished Stainless Steel Lips
    -Gold Centers
    -Titanium Finished Assembly Bolts
    42DD 15mm Adapters Front, Final ET: 23
    25mm Adapters Rear, Final ET: 13
    Suspension:
    KW Variant 1 Coilovers
    26mm H&R Front Sway Bar
    28mm H&R Rear Sway Bar
    ECS Urethane Rear Coil Spring Isolators
    Audi TT Spindles
    Audi TT Control Arms (-1.9* Front Camber)
    --Polyflex Front Position Bushings
    --OEM High Density Rear Position Bushings
    Audi TT Ball Joints
    Moog Tie Rod Ends w/ Grease Nipple
    OEM Polo Strut Mounts and Bearings with Chromed Caps
    SPC Camber Shims (-1.5* per side, for a final of -3.2*)
    SPC Toe Shims (-.5 per side, for camber correction)
    ECS Tuning Rear Beam Centering Plates
    Brakes:
    Painted with G2 USA Paint Kit
    Front:
    .:R32 Front Brakes
    -OEM 13.1" Rotors
    -Akebono Euro Ceramic Pads
    Rear:
    Zimmerman Cross Drilled and Slotted Rotors
    Engine:
    APR Stage 1 Tune
    -Stock, Valet, 91, and 100 Octane Tunes
    -AntiTheft
    -TBA and Fault Code Erase
    -Security Lock-Out
    2.0T Ignition Upgrade
    -Red Top Coil Packs
    -IE Raw Finish Adapter Plates
    -NGK Iridium Plugs (.4" Gap)
    Polished Intake Manifold
    Polished Alternator
    Polished Valve Cover
    Polished Throttle Body
    Polished Fuel Rail
    Custom "By Savko" Dipstick w/ R32 Tube
    Custom "By Savko" Oil Cap
    NewSouth Power Gasket
    Short Air Intake
    OEM Downpipe into stock piping with Flowmaster 40 Series Muffler
    Fuel Rail Wire Tuck
    EVAP/N249/N112 Deleted
    Secondary Air Injection Delete w/ Integrated Engineering Block-Off Plate
    PostReleased OEM-Style Resistors for All Deletes
    034 Silicon PCV Breather Hose Set
    Forge Turbo Inlet Pipe
    Exterior:
    Helix OEM HID Replica Headlights
    -6K HID Projectors
    -H7 Sylvania High Beams
    -BA9 Blinker Bulbs
    -White LED City Lights
    Slightly Tinted GLI Tails
    OEM Shark-Fin Antenna
    Red Rear Tow Hook
    .:R32 Aero Wipers
    FixMyVW Key-Fob Gas Door Popper
    OEM Euro Rub Strip With Euro Cut Out and No Side Markers
    OEM Passenger and Driverside Stubby Mirrors
    Now onto some pictures:
    Please give me any input, ideas, questions, whatever you wants!
    Index:
    Page 1: Into + Compression Test
    Page 2: Inner Axle Joint Rebuild + Wiring Work + MAF and TB Clean + PhatNoise
    Page 3: Huge Parts Ordering
    Page 4: Miscellaneous
    Page 5: Christmas GTG Cruise + 034 Strut Mounts and Coil Cover + Gary's Jetta + 10mm Front Spacers + Lip Skid Plates
    Page 6: Axle Rebuilding
    Page 7: Alignment + Painting Brakes
    Page 8: Blue Mirror Glass and TT Shifter Ordered
    Page 9: Random Shoot at House
    Page 10: Miscellaneous
    Page 11: Installed TT Shifter + Random Shoot at Adrians
    Page 12: Cut Out OEM Sway + Reinstalled Engine Cover + Polished Lights + Repaired Bumper Clips
    Page 13: Random Garage Shoot + 4Motion lip + BBS EI Caps
    Page 14: Water Pump Failure + Ordered Control Arm and Strut Mount Rebuild Kit + Timing Belt Change
    Page 15: Passenger Side Motor Mount Replaced + Car Goes to Streetwerkes + Mike's GTI + Front Sway Bar and New Coils Ordered + 240D Shoot
    Page 16: Fighting with ECS + Ordering Full New FK Streetline Kit
    Page 17: Mike's Car w/ Wheels + Rolling Luis' Fenders + Car on Stock Wheels
    Page 18: Huge Order Arrived (Sway Bar and Coils) + RCs Dismounted + RC Refinishing Begins + Car at Streetwerkes
    Page 19: Axle Issues at Streetwerke + 3k Fogs in OEM Headlights + Tire Bubble + TT Work and Pics
    Page 20: Painted Intake and Removed Battery Box + Hit and Run
    Page 21: Ordered Euro Front Rub + Intake Clean + New Tool
    Page 22: Wheels at Wheel Techniques for Refinishing + BBS Valve Caps + TT Spindles Ordered + Race Fuel + RCs Refinished
    Page 23: Finished RC Shots
    Page 24: TT Spindles Arrive + TT Spindle Install + EuroSwitch LED Mod + New DP Nuts
    Page 25: TT Spindle Issues + Camber Plates + Detail Day + Quarter Repair Begins
    Page 26: Helix Headlights + OEM Lexan Shields + Camber Plate Cleaning + Camber Plate Install
    Page 27: Ian's TT + Ball Joint Plans + Modded Ball Joint + Exhaust Hangers + RCs Mounted Pictures
    Page 28: Strut Nut Tool Purchased + Daly City Shoot + Back to OEM DownPipe
    Page 29: RC Meets Curb
    Page 30: Headlight Wiring Mod + Euro Rub In
    Page 31: Mazda Wash + Quarter Panel Primering + OEM Navi Arrives + Ordered Clear
    Page 32: Primered Mirror Cap + Navi Install Attempt 1
    Page 33: Primer Life
    Page 34: Painting Mirror, Quarter, and Rub Strip
    Page 35: New CAI Filter + Painted Rub On
    Page 36: Brake Booster Simplification + Broken Coolant Junction
    Page 37: Miscellaneous
    Page 38: Calvin's Mazda Spoiler and Shoot + Navi Working + Wisdom Teeth
    Page 39: Calvin Being a Whore
    Page 40: Cluster Planning + Porsche Brake and Other Item Order + Stubby Mirror Order + KufaTec Navi Harness
    Page 41: APR Trial + Aaron's R32
    Page 42: Cluster Modding
    Page 43: Porsche Brake Idea
    Page 44: Car in Storage for School + RLine Mats
    Page 45: Miscellaneous
    Page 46: Climatronic Swap Ordered + Seat Switch Ordered + Chrome Edge Grill Idea
    Page 47: Exhaust Hanger and Shock Mounts Ordered + Climatronic Parts Arrive
    Page 48: Original KW Set Cleaning + Climatronic Pics + Paint + Camber Plate Bearings + Exhaust Mounts Arrive
    Page 49: Clear Side Markers + Seat Switch + R-Line Mats Installed + GLI Lip Back On + Personal Plate Ordered
    Page 50: OEM Trim Removal Tools
    Page 51: Miscellaneous
    Page 52: Building Driverside Stubby + Install
    Page 53: Terminal Removal Kit Ordered
    Page 54: Brandon's Car + Kufatec Navi Harness + Exhaust Hangers + H&R Endlink Broken + Smog + Sister's Car Brake Pads
    Page 55: Mikado Garage Door Opener + Random Gas Station Shoot
    Page 56: Mike's Cluster Swap + R32 Front Brakes Obtained + Mikado Garage Door Opener Installed + Camber Plate Bearings
    Page 57: Miscellaneous
    Page 58: Miscellaneous
    Page 59: Ordered H&R Sway Bar Links + Random Pictures
    Page 60: Miscellaneous
    Page 61: Oakland Cruise and Meet + H&R Sway Bar Links Replaced + Remove OEM Lower Rear Spring Pad + Cleaned R32 Brakes + Clima Sun Sensor Install
    Page 62: NEW KWS!!!
    Page 63: Unboxing Climatronic Harness + Unboxing KWs + Bay Bridge Shoot
    Page 64: KW Install + Axle Boot Repairs + Removed Strut Brace
    Page 65: R32 Front Brake Install
    Page 66: LED City Lights + MoCool + Four Rings GTG
    Page 67: Christmas Cruise + TT Arms Ordered
    Page 68: Miscellaneous
    Page 69: TT Control Arm Bushings Ordered + Climatronic Swap Start
    Page 70: Climatronic Swap Concluson + Rob Farry Shoot + GTI Dash + TT Arms Arived + Poly TT Arms Ordered + Custom Plate Installed
    Page 71: Climatronic Swap Finished
    Page 72: A/C Valve Repair + TT Bushings Arrive
    Page 73: Polished Bay Parts from Kevin@ EI + Painting Brakes with G2 Red + Power Gasket + Alternator Failure
    Page 74: Valentine V1 Ordered (Turned out to be faulty)
    Page 75: Stubby Mirros Painted by Ian + IE Beam Plates Rejected
    Page 76: Silicon Coupler (Didn't Fit) + Power Steering Sensor Replaced
    Page 77: Stubbies Painted and Cleared
    Page 78: Miscellaneous
    Page 79: Miscellaneous + Birthday
    Page 80: Miscellaenous
    Page 81: Replacement Interior Trim
    Page 82: Considering LM Reps or MAEs
    Page 83: Beauty Shots of Ian's Wheels
    Page 84: Brushed Aluminum Boost Gauge Surround Ordered
    Page 85: Axle Joint Replacement Arrives + Auto Trans Fluid + Matigg Trunk Blend +
    Page 86: Stubbies Cleared More
    Page 87: Miscellaneous
    Page 88: Stubbies Painted and Installed + Hella4 Monterey Cruise + Polo Strut Mount Talk
    Page 89: Strut Mount Pics from Ian + Bay Shot
    Page 90: VF End Links Ordered (Never Shipped)
    Page 91: 2.0T Ignition Upgrade Ordered + SAI Block Off Plate + Injector O-Rings
    Page 92: TT Arm Bushing Removal + Miscellaneous
    Page 93: Extra GLI Badges Arrive + 2.0T Ignition Parts Arrive + Trunk Blend Arrives + Shots of IDWurk's Jetta
    Page 94: Passenger Bay Wiring Cleaned Up + 2.0T Ignition Installed + Trunk Blend Test Fit + Hood Bra On + Headlight Trim Added + Relay Box Deleted + Nues Bought! + Paper Clip Lip Holder
    Page 95: Nues Picked Up by Ian + TT Arms Stripped Down
    Page 96: Wheel Fitment Discussion
    Page 97: Miscellaneous
    Page 98: Miscellaneous
    Page 99: Hype
    Page 100: Nue Pics!!! + Rear Brake Pads Arrive
    Page 101: Dalmations
    Page 102: Miscellaneous
    Page 103: Grand Axle Realization + Ordering Joint Kit
    Page 104: 32G Promo Material + Plate LEDs Ordered + Short Ram Intake
    Page 105: Nues Dismounted + TT Arms Sand Blasted + TT Arms Painted and Bushings Added
    Page 106: Plate LEDs Arrive + Ball Joint Nuts Ordered
    Page 107: 225/40/18s Arrived + CV Joint and Grease Ordered
    Page 108: Intake Arrives + Miscellaneous
    Page 109: EVAP Delete + Nue Test Fit + Trans Skid Plate Clean-Up + Bay Shots + Intake Painted + Adrian's Accident
    Page 110: Coolant and Junction Arrive
    Page 111: SAI, N249, N112 Delete + Trade for CHs and Nues to Mike
    Page 112: Stud Conversion
    Page 113: Hood Latch Repair + Fuel Rail Wire Tuck + Injector O-Rings + TT Arm, Polo Mount, Axle Rebuild, and Alignment Epic Work Day
    Page 114: RCs Sold
    Page 115: Emissions Resistors Ordered
    Page 116: APR Tuned!
    Page 117: Trunk Blend Work + Park GTG
    Page 118: Trunk Blend Details
    Page 119: Random Warehouse and Wash Pictures
    Page 120: Hoodless Photo Shoot + Lots of Planning
    Page 121: TIP Clean-Up + Catch Can + Hoodless Shoot Final Edits
    Page 122: Planning + 034 Silicon Hose Kit + Billet Dipstick Tube
    Page 123: PCV Kit and Dipstick Install + Alignment Concerns + EuroWerks Ticket Booked
    Page 124: Blanking Plugs Arrive from UK + Adrian's OEM HIDs + TIP Install
    Page 125: Climatronic Wiring Info + Treasure Island Pics + Camber Shims Ordered
    Page 126: Rear Camber Shim Install + Pictures
    Page 127: Nues Back On + Giant Wrench Day + Index Started + List of Build I Follow
    Page 128: Rain Tray Treated + Ghetto Short Ram Intake
    Page 129: More Nue Shots + Trunk Pic + Back on CHs
    Page 130: Front Plate Ticket + Battery Terminal ABS Issue + GoMiniGo Plate Bracket + 100,000 Mile Oil Change + Audi RS4 Reps On
    Page 131: Travy's Car + StanceWars + Misc.
    Page 132: New Wheel Hype + German Parts Hype + Electrical Fire + FCM Wiring
    Page 133: Axle Clamps + Special Axle Greasing Solution + Axle Repair + Toe Shims + Temp Wheels + Interior Items
    Page 134: Teasing + Misc.
    Page 135: Wheel Teasers + Stud Conversion Removal + RSII Reveal
    Page 136: RSIIs Mounted + Tie Rod Ends + Alignment at Caleb's Shop + Treasure Island Shots
    Page 137: Bought R Wheel + Split RSIIs + Blasted to Raw + Suit and Car Shots + Wheel Paint Purchased
    Page 138: More Wheel Stripping + Disassembly + ECS Beam Plates + Wheel Teasing
    Page 139: Wheel Reveal + Chit Chat
    Page 140: SoCal Trip + Shop BBQ + WaterWerks + Crafted Fitment + R Wheel Install + New Driverside Door Trim + Misc Interior Shots
    Page 141: Chit Chat + Photos with the BADubs Guys + Random Pics
  2. Member swagger rob's Avatar
    Aug 13th, 2009
    Virginia Beach, VA
    2000 Jetta VRT / 2003 Jeep Liberty
    11-20-2010 09:54 PM #2
  3. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    11-20-2010 09:55 PM #3
    It looks super clean
    At this stage, I would start shaving things up, that's all I could think of
    BIODiesel Powered | MKx Channel VW/Audi Videos United
    MKIV Forum User Guide | Forum Rules
    Quote Originally Posted by dele
    The guys on coils can pull off their own Airless pride thread cos they clearly are the underdogs in the air/static debate, kinda like the equality movement for women.
  4. Member engineman98's Avatar
    May 30th, 2008
    Moyock
    2004 24v GLI, 2007 Fahrenheit GTI #975, 1984 rabbit GTI
    11-20-2010 10:02 PM #4
    Nice ride for 17!
  5. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    11-20-2010 10:03 PM #5
    Quote Originally Posted by engineman98 View Post
    Nice ride for 17!
    Hey who needs a savings account anyway But seriously, I am so lucky to have such a great car, lots of work and saving
  6. Member bobbyk94's Avatar
    Aug 15th, 2010
    Souderton, PA
    A Swedish POS + LBZ Duramax
    11-20-2010 10:05 PM #6
    What are your streetlines set up right now? Thread wise?
  7. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    11-20-2010 11:10 PM #7
    Quote Originally Posted by bobbyk94 View Post
    Not sure, i'll count for you next time
  8. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    11-20-2010 11:15 PM #8
    Doing now:
  9. Member !LL3ST's Avatar
    Oct 12th, 2010
    Central NJ (732)
    E36 & MKV
    11-20-2010 11:17 PM #9
    Clean, very clean
  10. Member ogvr6's Avatar
    Nov 3rd, 2004
    fl
    a gas guzzler and a econobox
    11-20-2010 11:22 PM #10
    boy how I would have been at 17 having a car like that,
    indoctrinate through academia and media.
    why is that the ones that seek tolerance are the most intolerant.
    They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety. -Benjamin Franklin
  11. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    11-20-2010 11:42 PM #11
    Compression checked out healthy
  12. Member Davey_Auers's Avatar
    Jun 9th, 2010
    Norwalk, Ct
    Bagged GLI
    11-21-2010 12:08 AM #12
    clean
  13. Member Mikey Pants's Avatar
    May 12th, 2010
    Norwalk, CT
    MkIV on RS's, 92 GTI VR6
    11-21-2010 01:38 AM #13
    So so clean. Looks good rolling
    I was part of the Illeststance gangbang |IBaumgartner Brand Schiltach|My Mk2 GTI VR6 Build
  14. Member orau22's Avatar
    Oct 15th, 2008
    NJ 08085
    SLAWbuilt MKIV & MKII Jetta Diesel
    11-21-2010 01:53 AM #14
    lucky ass, 17 with a GLI, your car is super clean and OEM+ is the only way to go
    can you detail my car, please and thank you
    SLAW [Straightline Autowerks]
    PM for fender rolling and coilover installs in South Jersey
  15. Member nchapman's Avatar
    Nov 4th, 2010
    319 Iowa
    2001 GTI VR6
    11-21-2010 02:19 AM #15
    Very nice build on a budget. Wish i could have had something like that at 17. Im 21 and my GTI isnt even that nice. :hide:
    '01 GTI VR6
    Quote Originally Posted by AntParmenter View Post
    Many are bagged so they don't actually ride around at that height. For the statics, their balls are so big it weighs down their car.
    The only way to make a 2.0 faster is to drive down hill.
    VR Society #252
  16. Member eastcoaststeeze's Avatar
    Jul 20th, 2009
    Ridgefield,CT
    bagged B7 S4 DTM Edition
    11-21-2010 02:47 AM #16
    Floss Filthy x Team Big Shark x Gengstout x VIP Modular
    I am the east coast dealer for VIP MODULAR Wheels, PM me with all wheel questions pricing, powder coating, chroming, polishing and any other type of finish your little hearts can come up with.
  17. Member
    Feb 15th, 2006
    Hawley, PA
    01 vr6, jazz blue 20th, 78 diesel rabbit, bagged gli, vr6 corrado, R32
    11-21-2010 08:22 AM #17
    are you even old enough to shave?
  18. Member T.D.B.'s Avatar
    Aug 11th, 2009
    Driving
    A couple OEM+ turbo GTIs
    11-21-2010 08:37 AM #18
    get a hi flow cat
    STFU Cort.
  19. Member
    Dec 29th, 2008
    Erie, Pa / Motown
    ..a Volkswagen
    11-21-2010 09:06 AM #19
    the only thing id consider is un-blacking the rear emblem
    otherwise...
    ..and the tails are money too
    How my car sits right meow
    RonBurgundy
  20. Member vdubsunday's Avatar
    Jan 13th, 2008
    Houston
    24v Gti, 1996 Harlequin
    11-21-2010 09:11 AM #20
    Lower it
    Cleaner than mine for sure
  21. 11-21-2010 09:58 AM #21
    Looks real clean, props to you (@ 17)
  22. Member bkby69's Avatar
    Feb 22nd, 2010
    NYC
    20V,Unlimited Metrocard(Lifetime),my sneakers
    11-21-2010 10:06 AM #22
    Quote Originally Posted by sick hatchem View Post
    I agree
  23. Member GaugeDoisher's Avatar
    Oct 24th, 2009
    Dallas, Tx
    1964 vw bug, 2003 24v vr6 GTI
    11-21-2010 10:34 AM #23
    Glad there's other people my age that like cars haha. No one at my highschool understands why I spend money on my car
    Car looks good, Lower the front
  24. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    11-21-2010 11:02 AM #24
    Quote Originally Posted by Beilman View Post
    Quote Originally Posted by JivETTA 1.8Turkey View Post
    Going to today hopefully
    [IMG]
    Quote Originally Posted by GaugeDoisher View Post
    [/IMG]
    Waiting on borrowing an angle grinder!
  25. Member JDBVR6's Avatar
    Dec 28th, 2006
    Denton/Houston, Tx
    2006 Audi A3 2.0T DSG
    11-21-2010 11:10 AM #25
    Very clean car bro, props.
    I remember when I got my Jetta at 17 (Which I'm still driving). I still love it as much now as I did when I fist got it and I'm now 21.
    However, mine is a VR6.
  26. Member xcrunnr93's Avatar
    Sep 6th, 2009
    Fredericksburg, VA (UMW)
    a mark4
    11-21-2010 11:18 AM #26
    for someone my own age!
  27. Member boostd12v's Avatar
    Jan 26th, 2009
    Indianapolis
    2.9 big turbo vr6 jetta never going to be finished race car on wide bbs rs/BMW X5
    11-21-2010 11:26 AM #27
    very nice pictures and car
    formerly b2 aka euroflash real name Chantha but you can call me Mr. Thach
    I survived the Illeststance gangbang of 2011
  28. Member spkn^GRMN's Avatar
    Jul 24th, 2002
    Charlotte, NC
    Segway turbo
    11-21-2010 11:45 AM #28
    -Wes
    2013
  29. Member ohjay's Avatar
    Mar 1st, 2010
    Ohigho
    2001 jetta don
    11-21-2010 12:47 PM #29
    clean
  30. Member Jeremy!'s Avatar
    Jan 29th, 2008
    Menlo Park, CA
    2000 BMW 740iL
    11-21-2010 01:02 PM #30
    Oh you did make a thread....
    Flickr.|Tumblr.| WTF IS HELLA IV.
    Quote Originally Posted by vr6pilot View Post
    I'm high. It'll pass.
  31. Member Doctor Meat Does Housecalls's Avatar
    Aug 27th, 2010
    Boston
    Silver MK4 On Orange Rims
    11-21-2010 01:22 PM #31
    Sweet ride!
    At 17, I was driving a 1993 Dodge Spirit.
    20 now, and my GLS is a ****box.
    IlleststanceGangBang2011|TheThirdReich|DoctorMeatDoesHousecalls|ATEP|WTH:VolkswagenGF2011Survivor|YourPriusIsNotGreen|My Build Thread
    Quote Originally Posted by MurryEB View Post
    Doctor Meat is doing a housecall right now
  32. Member
    Oct 26th, 2005
    MA
    I got fiiiiiiiives on it.
    11-21-2010 01:34 PM #32
    jealous, you're off to a good start. a clean/low GLI can't be disrespected.
  33. Member CubbyChowder's Avatar
    Jul 17th, 2009
    Central Coast, CA
    '73 BMW 2002
    11-21-2010 02:45 PM #33
    haha I remember posting up my old GTI when I was 18 and getting shredded to pieces for it, I definitely didnt know what I was doing. Good job on knowing whats right and whats wrong at 17, I had to learn the hard way eBay headlights and no-name multi-lug haggard wheels and stock height (i thought i was badass at the time)
    I'm glad that thing is out of my life forever and I'm 20 now and I've moved onto something much better.
    Keep it up, you have a very clean GLI, all the little highschool girls must get weak in the knee's when they see it.
    Oh and by the way, if you want me to delete this horrible picture off your build thread, I completely understand, just say the word.
  34. Member iTz JERSEY's Avatar
    Mar 2nd, 2010
    NJ: 908
    '02 GTI 1.8t
    11-21-2010 02:50 PM #34
    ( . Y . ) boost gets you boobies naaaa'meaan
    Instagram: itznj
    PSU GTG: http://forums.vwvortex.com/showthrea...rsity-Park-GTG
  35. Member Doctor Meat Does Housecalls's Avatar
    Aug 27th, 2010
    Boston
    11-21-2010 02:58 PM #35
    Quote Originally Posted by CubbyChowder View Post
    I was going to say the same thing!
    Thank you for not getting some "balla-ass rimz" and throwing a "super-dooper" 4" BROformance exhaust on it.
    Props to you man. I hate the stock ride height of my GLS, but don't slam it if you don't want to. I love being a part of this forum, but I don't agree with the slammage that most of these guys do. Lower, yes. Slammed, no.
