Page 122 of 146 FirstFirst ... 22 72 112 118 119 120 121 122 123 124 125 126 132 ... LastLast
Results 4,236 to 4,270 of 5084
Thread: OEM+ (My Progress Thread)
  1. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-27-2012 04:28 AM #4236
    Quote Originally Posted by OrangeDUB View Post
    So you start a whore thread for the most recent photoshoot, and also update your build thread with the same exact photos...
    ...reminds me of why I left the mk4 forums so long ago :jerkit:
    The List
    General Items:
    Matigg Trunk Blend (Need to go get paint and clear)
    Emissions Delete (Last PR Resistor in the mail)
    Akebono Euro Ceramic Rear Pads (Ready for Install)
    Forge Turbo Inlet Pipe (Need to buy a few hose clamps)
    034 Silicon Breather Kit (En Route from UroTuning)
    Billet Dipstick Tube (En Route from UroTuning)
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  2. Member HxC_KID's Avatar
    Nov 6th, 2005
    SoFlo
    2k3 IY 20th/ RIP 2K3 Jetta 1.8T
    04-29-2012 02:12 PM #4237
    Hey Zach!
    So did you decide if your going to run your CC recirculated or atmospheric with a filter?
    Iv had my PCV valve deleted out of the TIP blocked off and at the moment I dont run a CC, mine just dumps str8 to the ground. I plan to get a catch can and just run it atmospheric (that is if you dont mind the smell of a little oil, if you happen to turn the air on) that is what i hear from others tho i dont have that problem thank god.
    This is how my car is set up, just str8 off the valve cover to a 90* elbow str8 down to a T where the stock elbow of the oil filter housing hose meets the T and then i just have a long hose ran to the ground "the line circled in yellow" in the future if i decide to i just hook that line up to a CC.
    eng
    Now something else i am going to bring up only bc there are so many different opinions on this matter. Some people say you need the system to be Re-circulated back into the TIP and or need a catch can (recirculated or not) to create some kind of back pressure in the system I dont know im throwing this out there to see what others have to say on the subject. This is in reference to the way my set up is atm being that it just dumps str8 to the ground no can at all.
    Cheers
    -Matt
  3. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-29-2012 11:38 PM #4238
    I will be running it with no PCV valve and venting to atmosphere. It is a simple set up and doesn't allow any recirculation. It will be just like yours but I will have it collect in a can, I don't want to drip oil on the ground
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  4. Member Qais's Avatar
    Nov 27th, 2011
    London, UK
    Golf Mk4 Hybrid PD
    04-30-2012 01:06 AM #4239
    Great looking dub buddy
  5. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-30-2012 03:07 AM #4240
    Quote Originally Posted by Qais View Post
    Thanks dude!
    Edit: After a bit more thinking, I am really not comfortable with the coolant ball delete yet. I may get a smaller unit or something like that, but the system is outside my understanding still and I don't want to create a problem by messing with it.
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  6. Member JettaGetUpandGo's Avatar
    Mar 1st, 2005
    Brookfield, WI
    2005 Jetta GLI, 2011 Xterra Pro-4X
    04-30-2012 03:20 AM #4241
    It says for racing use only.
    So... Kufatec's site says their Climatronic harness is for 16-pin units (http://www.kufatec.com/index.php?mai...products_id=82). I'm assuming that's the same harness that you used and that's required for the 17-pin boxes. I've never heard of a 16-pin one.
    I'm doing work. (Build Thread) | VCDS Scans / Tweaks in the Waukesha / Milwaukee area for $5 or a 12-pk of Mountain Dew | MK4 Remote Window Control for $20
  7. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-30-2012 03:23 AM #4242
    Quote Originally Posted by JettaGetUpandGo View Post
    Weird, seems like they changed it since I got mine, but yeah that looks right.
    However, I had been talking about how my car doesn't have a radiator drain under the car, solution found:
    Will probably install one next time I service my cooling system
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  8. Member JettaGetUpandGo's Avatar
    Mar 1st, 2005
    Brookfield, WI
    04-30-2012 03:33 AM #4243
    Quote Originally Posted by Zach! View Post
    Interesting.
  9. Member MNShortBus's Avatar
    Mar 13th, 2008
    Maple Grove, MN
    2003 IY GTI
    04-30-2012 03:58 PM #4244
    I just picked up a Climatronic HVAC unit. Draining the freon should be fun
    Where is this 16/17 pin connector? On the box itself or on the wiring to the control unit?
  10. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    04-30-2012 05:22 PM #4245
    UROTUNING__The SteveGangBang 11.21__TheHazeBang_2012_TheGreatCatTakeover2012_
  11. Member 04 2.slow's Avatar
    Feb 19th, 2011
    Pittsburgh
    Jetta
    04-30-2012 06:25 PM #4246
    I just did the ecs plates. I'm similar in height and wheel setup I think if you want a pic for reference
  12. Banned jettaaddictionII's Avatar
    Sep 3rd, 2011
    MI
    2.0 twin turbo 9 speed jetta
    04-30-2012 06:28 PM #4247
  13. Member Volkswagen Terp's Avatar
    Nov 1st, 2007
    Silver Spring/Portugal
    2004 BMP GLI, 1993 DB2 GS-R
    04-30-2012 06:34 PM #4248
    There is only a 10 or a 17 pin one, anyway thats the one you need because they only sell the adapter for the newer boxes. Just be prepared to wait along time for the harness it took almost 8 weeks for mine to arrive.
    Quote Originally Posted by MNShortBus View Post
    its on the box itself
  14. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-30-2012 07:08 PM #4249
    Interesting.
    Quote Originally Posted by Volkswagen Terp View Post
    Quote Originally Posted by Billburt View Post
    Quote Originally Posted by 04 2.slow View Post
    Yes please!
    Quote Originally Posted by jettaaddictionII View Post
    Went on Ebay.Co.Uk today and found "blanking plugs" to fill in the holes on my TIP, 25mm and 8mm. Should fit perfectly and look very clean
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  15. Member 04 2.slow's Avatar
    Feb 19th, 2011
    Pittsburgh
    Jetta
    04-30-2012 08:26 PM #4250
    Height: 23.75
    Wheel: 18x8
    Tire: 225/40 512's
    Yes my fender is jacked up I bought it like that I'll fix it someday. Hope this helps.
  16. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-30-2012 10:42 PM #4251
    ^ Thanks man, looks like I will be going that route, ECS also has a very nice video for the install:
    http://www.ecstuning.com/Volkswagen-...8/Video116-HD/
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  17. Member JettaGetUpandGo's Avatar
    Mar 1st, 2005
    Brookfield, WI
    05-01-2012 01:13 AM #4252
    They make that look stupid simple. Ask squire. Installing our Mason-Tech plates sucked donkey balls without a lift.
  18. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    05-01-2012 01:16 AM #4253
    I have a lift
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  19. Member JettaGetUpandGo's Avatar
    Mar 1st, 2005
    Brookfield, WI
    05-01-2012 01:20 AM #4254
    I have a lift
    I know. You suck.
  20. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    05-01-2012 02:50 AM #4255
    I know. You suck.
    The List
    General Items:
    Forge Turbo Inlet Pipe (Need to buy a few hose clamps, plugs on the way from the UK)
    034 Silicon Breather Kit (Arriving tomorrow)
    Billet Dipstick Tube (Arriving tomorrow)
    J-Caps Coolant Cap (Should be coming from _plush_)
    On a random topic related to the TIP, me and Ian found amazing hose clamps at a local West Marine , they sell very very high end boating and sailing equipment.
    Available in nearly any size, they act like normal hose clamps, with three advantages:
    1-The insides are totally smooth, with no notches that would cut into your hose.
    2-The fact that is has no notches means it has ridges in stead, and the clamp feeds into itself, leaving no "dangling" band outside the clamp.
    3-The quality is superb, and they are built to resist corrosion on a boat, so they will last forever in my engine bay (they are also shiny)
    This is the best picture I can find of one:
    So I already have one for the TIP that will attach it to the turbo, but Ian needed the others back. So I will need one for the N249, one for the PCV, and one for the DV. Also two for my brake booster line.
    It will set me back a pretty penny, but they are very nice and well worth it.
    For those with A.D.D.: Cool hose clamps that I will be getting for the TIP
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  21. Member 04 2.slow's Avatar
    Feb 19th, 2011
    Pittsburgh
    Jetta
    05-01-2012 01:08 PM #4256
    didn't watch instructions are for quiters
    I fcuked up a brake hose/line on the rear passenger side because i couldnt fit a wrench or anything
    I have a lift
    I know. You suck.
    ^this
  22. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    05-01-2012 02:01 PM #4257
    UroTuning order has landed
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  23. Member jimothy cricket's Avatar
    Jul 9th, 2008
    NIU / CHI-TOWN
    Carb'd 16V
    05-01-2012 02:51 PM #4258
    ^^^ pretty
    "complaining is silly, either act or forget."
    MKII GTI build:
    http://forums.vwvortex.com/showthrea...-GTI-build!...
  24. Member zero_x_soul's Avatar
    Feb 21st, 2009
    San Jose
    emkaye IV 2.slow
    05-01-2012 03:24 PM #4259
    i love how they always give you beer coozies, but yet you arent old enough to drink yet...legally
    8v society-#220
  25. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    05-01-2012 03:37 PM #4260
    Quote Originally Posted by zero_x_soul View Post
    it works for sodas too
  26. 05-01-2012 03:42 PM #4261
    Quote Originally Posted by sponcar View Post
    wow bro your car looks clean, I wish my first car was a sexy GLI like yours when I was 16 but i was more into have something fast than luxury, so I ended up getting an Eclipse gst.!
    now that im 21 and after a couple of tickets I changed my mind>!
    Eclipse
  27. Member JettaGetUpandGo's Avatar
    Mar 1st, 2005
    Brookfield, WI
    05-01-2012 09:10 PM #4262
    What's the Forge hose for? Catch can routing?
  28. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    05-01-2012 09:19 PM #4263
    Quote Originally Posted by jimothy cricket View Post
    ^^^ pretty
    This!
    Quote Originally Posted by notoriousjetta View Post
    Eclipse
    Haha
    Brake booster hose to the IM, I am doing silicon all over so I might as well add that one
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  29. Member sobe_zuki's Avatar
    Jun 27th, 2011
    Slinger, WI
    '04 Jetta GLI
    05-01-2012 09:56 PM #4264
    Just so you know, they do not feed into themselves, look at the picture... they work just like regular ole hose clamps. But yes, I too agree they are superb and look so much cleaner than the other ones. The stamped/rolled thread is bomb
  30. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    05-01-2012 09:59 PM #4265
    Quote Originally Posted by sobe_zuki View Post
    Yep, they also stay very tightly bent so it doesn't hang out like most clamps.
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  31. Member zero_x_soul's Avatar
    Feb 21st, 2009
    San Jose
    emkaye IV 2.slow
    05-02-2012 12:11 AM #4266
    what size do you need? my uncle has these in bulk because he repairs marine engines.
    8v society-#220
  32. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    05-02-2012 01:20 AM #4267
    3cm I.D.
    3.5cm I.D.
    1.5cm I.D.
    2cm I.D.
    8.5cm I.D.
    2 x 2.25 cm I.D.
    That is more a list for myself
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  33. Senior Member idwurks's Avatar
    Oct 25th, 2003
    Hill Valley Skyway
    Time Machine
    05-02-2012 11:48 AM #4268
    Zach sucks for flaking on my bday.
    Hella4 | GermanPlates | ADstudio Custom Banner Ads | Audi TT Bild | Need Retargeting or Display Advertising?
  34. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    05-02-2012 12:10 PM #4269
    Quote Originally Posted by idwurks View Post
    I do, I get to go attend a Sunday mass instead and write a 4-5 page paper on it
    Sent from my Desire HD using Tapatalk 2
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  35. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    05-02-2012 04:26 PM #4270
    Gonna go work on the car, plans are to install the 034 kit and the dipstick tube, maybe the TIP if time allows
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
