VWVortex.com - Audi Unveils 340 HP RS 3 Sportback
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 94
    Thread: Audi Unveils 340 HP RS 3 Sportback
    1. Member Phunkshon's Avatar
      Nov 16th, 2005
      11-22-2010 05:04 AM #1
      Audi has added a new model to its dynamic RS series: the RS 3 Sportback. In the great tradition of the brand, its engine boasts five cylinders and turbocharging technology. From a displacement of 2.5 liters come 250 kW (340 hp) of power and 450 Nm (331.90 lb-ft) of torque, with an average fuel consumption of just 9.1 liters of fuel per 100 km (25.85 US mpg).
      Power is transmitted to the road via a seven-speed S tronic and quattro permanent all-wheel drive. 19-inch wheels and fenders made of carbon‑fiber‑reinforced plastic (CFRP) underscore the Audi RS 3 Sportback’s position of distinction.
      Power and sound: the engine
      Each Audi RS model represents the pinnacle of its model line – the RS 3 Sportback, developed by quattro GmbH, now brings this dynamic philosophy to the compact category. It rockets from a dead stop to 100 km/h (62.14 mph) in 4.6 seconds – a performance figure unrivaled by the competition. Top speed is electronically limited to 250 km/h (155.34 mph). Even so the compact car, weighing in at only 1,575 kilograms (3,472.28 pounds), uses on average just 9.1 liters of fuel per 100 km (25.85 US mpg) and emits 212 g CO2 per km (341.18 g/mile). This efficiency is due in large part to a delivery-on-demand oil pump and a regenerative system that recovers energy as the car decelerates.
      The 2.5-liter engine in the RS 3 Sportback will thrill passengers thanks to its tremendous pulling power and its voracious revving up to 6,800 rpm. The guttural roaring and growling, backed by the signature rhythm of the five-cylinder firing order make up the classic Audi soundtrack. A sound flap in the exhaust branch intensifies the sound even further. The flap is controlled via the standard Sport button, which also varies the engine response.
      Powerful five-cylinder engines have a long legacy at Audi. In the 1980s, racing cars and production cars used them to edge out the competition. Even the first Audi RS model, the 1994 RS 2, had a five-cylinder engine. The 2.5-liter unit, already part of the TT RS specifications, now redefines the state of the art, having recently been named “International Engine of the Year” by a high-ranking jury of automotive journalists.
      The 2.5 TFSI delivers 250 kW (340 hp) from a displacement of 2,480 cc: a specific power output of 100.8 kW (137.1 hp) per liter. The maximum torque of 450 Nm (331.90 lb-ft) is readily available at the low end of the rev range, around 1,600 rpm, and remains constant up to 5,300 revolutions. These general parameters yield excellent acceleration and elasticity values.
      Just 49 centimeters (19.29 inches) in length, the five-cylinder unit is ultra-compact, tipping the scales at a mere 183 kilograms (403.45 pounds). The crankcase is made of vermicular-graphite cast iron, a high-strength yet lightweight material. Audi is the first car maker to use this material in a gasoline engine. Perfectly placed reinforcements further enhance the block’s loadability. The lightweight-design concept keeps the Audi RS 3 Sportback’s weight in check and pays off big in terms of axle‑load distribution and, ultimately, handling.
      The large turbocharger generates up to 1.2 bar of boost pressure. The intercooler downstream achieves an efficiency rate of over 80 percent. Like all Audi gasoline turbos, the 2.5 TFSI combines turbocharging technology with FSI direct injection. The marriage of these two technologies facilitates a high compression ratio (10.0:1) along with a correspondingly high efficiency ratio. Flaps in the intake tract mix the air as it flows in. The two camshafts, each adjustable by 42 degrees of crankshaft rotation, also enhance the efficiency of the mixture formation.
      Speed and grip: the drivetrain
      The compact seven-speed S tronic transmits power from the five-cylinder engine via three shafts: one drive shaft and two output shafts. Like all dual-clutch transmissions, it comprises two transmission structures. The shifting process is extremely smooth, taking place in hundredths of a second as the clutches switch, with no perceptible interruption of pulling power. Seventh gear is very tall – a measure that reduces fuel consumption.
      The driver can operate the seven-gear S tronic in two automatic modes and one manual mode. Gears are shifted using the paddles on the steering wheel or the selector lever. The launch control system manages the sprint from a dead stop, furnishing explosive turbo power with minimal tire slip.
      Delivering power to the road with effortless ease, the quattro permanent all-wheel drive grants the RS 3 Sportback traction, dynamics, and stability. Its central component is an electronically controlled multi-plate clutch, mounted at the end of the propeller shaft to achieve a favorable axle load distribution. Located in its interior is a plate package bathed in oil.
      Thanks to quattro, the propulsive power can be distributed to each axle as needed. Whenever slip occurs at one of the axles, an electric pump intervenes at lightning speed to increase the oil pressure. The pump presses the clutch plates together in a continuous fashion, thereby permitting the torque to be redirected accordingly. Thanks to a powerful accumulator, this process takes just a few milliseconds.
      Dynamics and safety: the chassis
      The stiff body lays the cornerstone for the RS 3 Sportback’s precise handling; the chassis is what makes it happen. The four-link rear suspension – with a track measuring 1,528 millimeters (60.16 inches) – is anchored to a subframe and features high-strength-steel control arms that allow it to handle longitudinal and lateral forces separately.
      Widened to a 1,564-millimeter (61.57-inch) track, the front suspension is a McPherson strut construction, also with a separate subframe. Key components of the construction are made of aluminum. Thanks to its electromechanical drive, the rack-and-pinion steering is highly efficient, with a sporty-direct gear ratio of 16.2:1.
      Coil springs and redesigned shock absorbers provide the vertical support. The sports suspension lowers the body of the RS 3 Sportback by 25 millimeters (0.98 inch) compared with the A3. The new range-topping model in the A3 series boasts 19-inch cast aluminum wheels fitted with 235/35 series tires at the front and 225/35 at the rear. The wheels come standard with machine-polished titanium-look styling, but are optionally available in black with a red rim flange.
      The internally ventilated disks measure 370 millimeters (14.57 inches) in diameter at the front and 310 millimeters (12.20 inches) at the rear. The front friction rings are perforated for maximum heat dissipation. They are connected by hollow pins to the aluminum brake disk covers, which are encircled by four-piston fixed calipers painted a high-gloss black and bearing RS logos. The electronic stabilization program (ESP) features a Sport mode and can be switched off entirely.
      Precisely guided by its responsive steering, the RS 3 Sportback eagerly takes to curves and exits them with agility, stability, and serenity. The stability limit is extremely high, an effortless mastery that rounds off the character of this powerful compact car.
      Interior and exterior: dynamic styling
      The new top-of-the-line model in the A3 series hints at its explosive potential from the very first glimpse. Together with the xenon plus headlights, the front apron, the anthracite single-frame grill with diamond-patterned styling and the air intakes cut a distinctive figure.
      The side view is dominated by the flared front fenders made of carbon‑fiber‑reinforced plastic (CFRP), prominent sill panels, exterior-mirror casings in matt aluminum look and a large roof spoiler. A high-gloss black diffusor insert and two elliptical exhaust tailpipes on the left accentuate the styling at the rear. RS 3 badges adorn the single-frame grill and the rear hatch.
      The dynamic style is matched in the interior, entirely black and sporting a number of RS 3 logos. The sports seats are upholstered in Fine Nappa leather with silver contrasting stitching; the inlays gleam in Piano finish black or the new Aluminum Race look; the leather multifunction sports steering wheel is flat-bottomed. The selector lever and instruments are specially designed. The driver information system can display the boost pressure and oil temperature as well as a lap timer.
      The RS 3 Sportback comes with an array of standard equipment including the Sport button, rear parking system, climate control, chorus radio system, and xenon plus headlights with LED daytime running lights. Audi offers customers a range of optional features: front bucket seats, roof rails in matt aluminum look, and styling packages in black or matt aluminum. Five exterior colors are available, plus an unlimited selection of custom paint finishes.
      The new top-of-the-line model in the A3 series is already the fourth Audi model to be built at Audi Hungaria in Győr, where it is rolling off the assembly line alongside the TT Coupé, the TT Roadster and the A3 Cabriolet.
      Deliveries of the RS 3 Sportback will begin in early 2011. The base price in Germany will be 49,900 euros.
    2. Member eddiefury's Avatar
      Aug 5th, 2007
      Venice, CA
      07 A3 2.0T APR Stage II+, 07 RS4 Phantom Black
      11-22-2010 05:40 AM #2
      is it weird that the front has wider tires than the rear??
      B7 RS4 | 6MT | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
      May 15th, 2010
      Dallas, TX
      2006 2.0T A3
      11-22-2010 08:34 AM #3
      At least most of us will have the same tail lights!
    4. Member dmorrow's Avatar
      Jun 9th, 2000
      Cincinnati, OH
      '06 BMW Z4M Coupe, '13 Cadillac ATS 3.6 RWD
      11-22-2010 09:46 AM #4
      Quote Originally Posted by eddiefury View Post
      I have never seen this on any car but it would help get rid of the understeer that is common in this platform.
    5. Member BalloFruit's Avatar
      Sep 25th, 2006
      Severn, MD
      2008 A3 3.2Q and 2008 Corvette
      11-22-2010 11:10 AM #5
      49,900 Euro!!! That's $68,000!!!!
      I guess that's off my list. I guess I'll have to go to plan B -- now where did I put that link to the plans for the Audi RS4 powered DeLorean?
    6. 11-22-2010 11:23 AM #6
      I want it. probably won't see it here which is a shame, and I really don't belong buying a car that would run, $60-70k
      the $38k sticker was about my limit.
      Pontiac did it on the grand prix GXP. that big nose heavy pig still handles like crap.
      but this is a different beast all together so it might work.
      what I don't understand is, why does my 2.0t A3q understeer but the MKV R32 feel more neutral? stupid glass roof is all I can think
    7. Member Maitre Absolut's Avatar
      Aug 5th, 2009
      Montreal
      2014 S4, 2013 Q5
      11-22-2010 11:42 AM #7
      Quote Originally Posted by BalloFruit View Post
      thats not how pricing works between europe and US
      and add to that different options (no RS seats)....if you want an idea of the price, look at the price difference in germany between an RS3 and a regular A3
      14 S4 | IBIS / Chestnut | DSG | SD | AWE Touring | AWE S-flo | KW HAS
      13 Q5 | IBIS / Chestnut | S-Line
    8. 11-22-2010 11:50 AM #8
      Another cool Audi we'll never see in the US. Sigh.
      Jul 27th, 2005
      Ramona, CA
      '06, A3 2.0t, Sport
      11-22-2010 12:11 PM #9
      IMHO, the front bumper looks like an aftermarket kit from Japan.
    10. 11-22-2010 12:16 PM #10
      Someone please start importing the parts.
    11. 11-22-2010 12:52 PM #11
      damnit no RS4 style exhaust tips
      hirro
    12. 11-22-2010 01:05 PM #12
      wow 235 front and 225 rears
      hirro
    13. Member JRutter's Avatar
      Nov 25th, 2009
      Bellingham, WA
      07 A3 3.2 stormtrooper
      11-22-2010 01:47 PM #13
      Quote Originally Posted by tp.wannabe.s3 View Post
      Despite the "permanent" Quattro, it is still Haldex. So for best fwd bias performance, put more rubber up there where you need the extra traction for steering, braking, and power.
      A VR6 AWD w/ lots of goodies
    14. Member RedLineRob's Avatar
      Feb 8th, 2009
      San Francisco
      2012 A3 Quattro - APR K04
      11-22-2010 02:04 PM #14
      im loving that rear spoiler
    15. Global Moderator
      Apr 9th, 2004
      Hershey, PA (USA)
      Blog Entries
      965
      2013 Audi TT S line competition, 1984 Audi 4000S quattro, 2000 Chevrolet Silverado 1500
      11-22-2010 02:05 PM #15
      I just added all of the available PR and pics to the site. You can find them here.
      http://www.fourtitude.com/news/publi...cle_6412.shtml
    16. Member TroySico's Avatar
      Apr 19th, 2002
      Oakland, CA
      TT-RS APR Stg-II & B8.5 Allroad APR Stg-II-E85
      11-22-2010 02:23 PM #16
      Quote Originally Posted by dmorrow View Post
      Pontiac tried this most recently w/ the FWD Grand Prix GTP or GXP. It helps a front heavy car handle more neutrally. Strange...
      TroySico /// 2008 Ibis White Blk A3 3.2q S-line Ti-Pkg /// 2002 Satin Silver Allroad 2.7T 6MT Quattro
    17. Member TroySico's Avatar
      Apr 19th, 2002
      Oakland, CA
      11-22-2010 02:24 PM #17
      GROUP BUY on the rear spoiler and front brakes anyone? Damn...got to love that they did this on the last year of this body style no doubt.
    18. 11-22-2010 02:52 PM #18
      Quote Originally Posted by TroySico View Post
      you can get the TTRS brakes around $4000
      so i assume rs3 brakes same price lol
      hirro
    19. Member BalloFruit's Avatar
      Sep 25th, 2006
      Severn, MD
      11-22-2010 03:14 PM #19
      Quote Originally Posted by Maitre Absolut View Post
      Extrapolating based on equivalently equipped A3 sportback prices in Germany vs. US.
      Germany: €36,500
      US: $30,725
      So, if you're right, the RS3 should be available for $42,000 base.
      Edit: This was my 1,000th post? Lame. I was hoping to reserve it for something more insightful or life-changing.
    20. 11-22-2010 03:49 PM #20
      How much to just swap this out?
      Time to give up and buy a horse.
    21. Member ThatGuyRyan's Avatar
      Oct 20th, 2006
      Hyper Foreman Scar
      11-22-2010 04:06 PM #21
      "Power is transmitted to the road via a seven-speed S tronic"
      drop>drive>destroy>dispose | "You may be surprised to discover you're rich, especially if you're broke." ~ P. J. O'Rourke
      "I might get crucified for this but, I honestly believe that people who hate on other automotive sub-cultures are not real car fans." ~ Paddy McGrath
    22. Member oj1480's Avatar
      Jun 6th, 2006
      NYC
      2010/VW/GTI/CW
      11-22-2010 04:13 PM #22
      VERY BADASS
      BUT "The base price in Germany will be 49,900 euros. "
    23. Member Tcardio's Avatar
      Mar 19th, 2009
      75 Drayton Place, London
      11-22-2010 04:19 PM #23
      on an 8P platform...WTF? Audi can keep it
    24. Member Maitre Absolut's Avatar
      Aug 5th, 2009
      Montreal
      2014 S4, 2013 Q5
      11-22-2010 04:26 PM #24
      Quote Originally Posted by oj1480 View Post
      VERY BADASS
      you've missed 3 replies that adress this number which means nothing by itself in terms of the price for US markets
    25. Member
      Nov 23rd, 2003
      Nova Scotia, Canada
      77 Rabbit, 90' Jetta vr, 04 GTI
      11-22-2010 04:29 PM #25
      No 2 door, no care.
