VWVortex.com - can i bypass oil sensor
    Results 1 to 6 of 6
    Thread: can i bypass oil sensor
    1. 11-29-2010 12:19 PM #1
      is there a way to disable or bypass the loud beep and dash light i get cause i have a bad oil temp/level sensor (01' a4 1.8tq) ? $108 sensor is pretty low on the list of things my car needs..
    2. 11-29-2010 05:12 PM #2
      http://forums.vwvortex.com/showthrea...r-error-bypass
      anyone know if this is the same, guess its for a 00' 1.8t passat i think my sensor is failing for temp not level guess its a dual sensor?
    3. Member Suprem3's Avatar
      Sep 7th, 2009
      Long Island New York
      2001 Audi A4 1.8t QMT
      12-03-2010 12:34 AM #3
      Quote Originally Posted by 7808 View Post
      ecs has this for cheaper. if im correct i have an 01 as well mine is leaking. i think they have 3 diff options for it
    4. Member
      Feb 25th, 2010
      2000 Audi A4 1.8tqm
      12-03-2010 08:55 PM #5
      I was told that my (2000 1.8t ATW) oil level sensor was a dual sensor that does temp and level. The AEB has temp that connects near the oil cooler and a level sensor in the oil pan. I'm not sure if the level sensors for both are identical but the AEB doesnt have temp sensor wires run there or if they're different sensors. Seems kind of silly to do it that way so I doubt it.
    5. 12-04-2010 04:44 PM #6
      thats what the dealer told me too, he looked mine up and said it was a dual sensor.. i need to find a pinout so i can trick it cause i dont care enough to spend $108 on the sensor.
    « Back
