VWVortex.com - vr6 header that actually makes power?
    Results 1 to 24 of 24
    Thread: vr6 header that actually makes power?
    1. 12-01-2010 01:41 AM #1
      Im looking for a header for my 98 12 valve vr6 that actually makes power, what are yours guys opinions, i like the raceland vr6 header but not sure need your guys opinons
    2. Member 12veeRsix's Avatar
      Dec 14th, 2007
      Rockville, MD
      2001 Jetta VR6
      12-01-2010 01:52 AM #2
      estyles makes one for a little more than a grand...so far pretty much the only header to make proven gains.
    3. Member no vtec 4me's Avatar
      Aug 1st, 2006
      610 PA
      '11 WRX
      12-01-2010 07:56 AM #3
      if you want power youre better off porting your stock one out a little bit. THeres a thread in here somewhere that exlplains it a little better
      Instagram: Kevin_Brennan_Jr
    4. Member EuroSportChicago's Avatar
      Jun 9th, 2010
      Chicago
      GTI VR6 MK3
      12-01-2010 03:02 PM #4
      Quote Originally Posted by no vtec 4me View Post
      +1
      Quote Originally Posted by aphythiate View Post
      I don't understand what you said. I'm guessing you did a "dump'n'go" minus the go.
      Quote Originally Posted by RayMkIIIvdub View Post
      where are the muffler bearings and is that something i can change myself
    5. Member ricardo's Avatar
      Feb 19th, 1999
      CA Bay Area
      1995 mulberry GTi VR6 RIP, 1988 BMW E30 SETA, 2004 A4 B6
      12-01-2010 03:11 PM #5
      Headers would be the last thing I would do for power... there is a thread about how to make power.. search for it
      "Public transportation......because you're poor"
      done everything that's cheap....broke the most expensive parts....
      having cooling problems? check this out http://the-corrado.net/forum/viewtopic.php?f=1&t=68720
    6. Member vw1320's Avatar
      Jul 11th, 2000
      Can't catch gone
      All Motor 12v
      12-01-2010 05:16 PM #6
      I am still waiting for third party proof that the estyles header actually makes power. The graphs the provided as proof were suspect at best. Show me a header for any other car that shifts the entire curve up the same amount like the graph they posted.
      As others have said porting your stock manifolds is the best bang for the buck solution for most.
      10.90@126 World's Quickest Supercharged VR6
      11.82@113 First and only All Motor 12v Street Car in the 11' s
    7. Member EuroSportChicago's Avatar
      Jun 9th, 2010
      Chicago
      GTI VR6 MK3
      12-01-2010 08:23 PM #7
      Quote Originally Posted by ricardo View Post
      That was the first thing I realized about European cars such as VW and BMW. I used to be into american cars, and adding headers and full exhaust would bring out some BIG power, for like 600 bucks. With the European cars headers are expensive and provide very minimal gains.
      The money spent on headers would be more well spent somewhere else in order to build power.
    8. Member !!Wild Man!!'s Avatar
      Feb 17th, 2009
      CHILE Pepper KIrQue
      VRTits 01 metallic beige
      12-06-2010 02:46 AM #8
      s2 metal works
    9. Member URIN 2ND's Avatar
      Oct 29th, 2001
      PNW
      '92 GTI 1.8T
      12-06-2010 04:38 AM #9
      Quote Originally Posted by EuroSportChicago View Post
      I think that's quite the gigantic generalization...16V headers do quite a bit.
      Interesting to see that everyone hops on the "headers lose HP on a VR6" bandwagon, when I can't seem to find a single post where someone put up dyno results before and after a header swap and lost power. Not to say it hasn't happened, but there's no proof out there to support it.
      Quote Originally Posted by SGLoki View Post
      I believe rupaul is the tallest trans.
    10. Member URIN 2ND's Avatar
      Oct 29th, 2001
      PNW
      '92 GTI 1.8T
      12-06-2010 04:40 AM #10
      Quote Originally Posted by URIN 2ND View Post
      And the only 2 dynos I happened to glance at today showed a 10whp and 12whp gain, respectively, with an S2 header and a modded Bosal Brospeed header.
    11. Member JohnStamos's Avatar
      Feb 3rd, 2010
      A4, A6, Mk3, Shelby, 650x
      12-06-2010 10:41 AM #11
      This is the vortex motto. If more then one person says its true, spread it around like its gospel. Don't worry about hard data, just heresay. Hence why these cars are in the dark age when it comes to non factory performance compared to other manufaturers.
      I have a header on my Daily. It is some knockoff, probably OBX, don't really care as it was free. All stainless construction, VERY good welds and finish. The "ball and socket" style collector it has is garbage though. Cutt it off and weld on a proper flex joint and it is a very good deal for the money.
      It is on a VERY mild build: cams, C2 cam chip, 2.5 inch back with only a resonator, intake, ported manifold and tb. It pulls very hard, but nothing amazing. Definitely feels MUCH more powerful then comparative VR's I've driven. Pulls cleanly to 7200, no "brick wall" like the stock VR's, definitely making peak power well before 7200 still though. They also increased the exhaust note considerably, but also made it more "tinny"
      Will be dynoing in the spring, just for entertainment. I have a set of ported stockers as well, but noway it would be worth it for me to swap them around. I can say, they definitely wouldn't be that high on my list of priorities on a mild VR though.
    12. Member URIN 2ND's Avatar
      Oct 29th, 2001
      PNW
      '92 GTI 1.8T
      12-06-2010 01:09 PM #12
      Yep, I know what you're saying.
      I've personally seen 2 all-motor bolt-on 12V VR's making over 200whp, and neither of them were using the stock exhaust manifold.
    13. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      12-06-2010 04:15 PM #13
      I'm one of 'those people' that has tested different headers personally, or knew other racers that tested them and was privvy to the results. I have posted this several times but it's probably lost in the noise here...
      My Mk2 VR6 - 2.9L/BVH/276s
      Genie Header - consistent 13.6 car
      Stock/Ported manifolds - consistent 13.4 car
      Joe's euro 2.9/race shop head/268s
      Brospeed vs same stock/ported as I used
      dont' remember times but no et change at all
      Dowd's Mk3 race car, still on stock intake manifold
      Brospeed vs stock/ported
      Billy's car stock 2.8/race shop head/268s
      Supersprint vs stock/ported
      We didn't dyno a lot then as track was easier/quicker to do but the cars were dead consistent at the track .. we were all racing/testing a TON.
      I do remember Turn2 had a $$ header in development that made a few hp on one car but it was too much to bother making more of.
      I think Evan had a good shot with his header, just needs more testing and optimization.
      I don't see any of the ebay knockoffs of the nicer headers doing any more then nothing, if not worse. I ported an ebay header and had almost 5 hrs into it just making it not suck.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project
      1995 GTI VR6 - Retired - 12.90@106 R32 power - 12.833@106 12v power
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    14. Member
      May 8th, 2000
      Race car
      12-06-2010 05:55 PM #14
      Quote Originally Posted by need_a_VR6 View Post
      It was Supersprint vs. stock un-ported (I never ran ported stock!!!). The Supersprint made my car slower at the track, by a lot too. I do have time slips and would have to dig for the exact details (2003?!). IIRC, that header was just as bad as the old CAT 272 cams...
    15. Member URIN 2ND's Avatar
      Oct 29th, 2001
      PNW
      '92 GTI 1.8T
      12-06-2010 08:07 PM #15
      Entirely too many variables at a drag strip to assume that because an old version of one company's header may have contributed to a marginally slower ET, that every set of headers available for a 12V VR6 decreases horsepower. Some people decide their religion on a more slippery slope than this, but I'm a bit of a skeptic and I like facts.
    16. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      12-07-2010 11:26 AM #16
      Bull****. These are cars that were run before/after the installation of these parts and were dead consistent (taking into account weather/density effect). I can make a dyno show whatever number I choose, change the power curve, etc the track is about the only thing that can't lie.
      -Paul
    17. Member
      May 8th, 2000
      Race car
      12-07-2010 11:54 AM #17
      I am all about facts too, and this is why I actually bought a header and tried it out for myself.
      Here is the thing, I have nothing to gain from posting this, I'm not pushing a product and back then I needed a header to actually perform and do something. To this day I would welcome a header that actually makes a car quicker and proven to make power.
      Both Mthis1 and Drader here on the Vortex ran on the dyno, one with Brospeed the other w/ a SS, and they saw an average gain in the area of 5-7 whp (don't quote me on that number). Their results were achieved with cams, exhaust, no head work (I think), and both cars had catalytic converters in place (we all used race pipes). These results both came from the same dyno, one that was tagged as being customer friendly, and there were months between the runs, not done back to back. So, after all of that I could never put much faith in those results.
    18. Member URIN 2ND's Avatar
      Oct 29th, 2001
      PNW
      '92 GTI 1.8T
      12-07-2010 01:32 PM #18
      It's not the cars, necessarily...it's the drivers. Most Vortex users cannot come close to replicating the kind of consistency you see on ESPN by teams with millions of dollars behind them who are out racing year-round.
      Matter of fact, like Billy noted, people who take dynos for gospel are often mislead as well. Still, more often than not, it seems the headers either "don't do much of anything" or "add a little power but perhaps not enough to warrant the time or trouble".
      That's quite a bit different than "They will make you lose power." Just trying to debunk the "bandwagon" mentality that's all to prevalent on web forums.
    19. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      12-07-2010 09:55 PM #19
      Quite a bit of generalizing drivers huh? Believe me the cars/drivers above had enough passes to have good results.
      If you don't trust results, buy em all up and do some testing. I can tell you what the Genie/Supersprint/Brospeed and their ebay copies will show...
      The only header I'd even bother to run is one I design myself to actually work.
      -Paul
    20. Senior Member TBT-Syncro's Avatar
      Apr 28th, 2001
      Vancouver
      92 VR-T syncro GTI, 2011 husaberg FS570, 2014 Aprilia Tuono V4 APRC
      12-08-2010 01:58 AM #20
      lol
      pot meet kettle
    21. Awaiting Email Confirmation
      Jan 16th, 2010
      australia
      94 12v cams chip head work exhaust custom intake 3.9s peloquin
      12-08-2010 04:19 AM #21
      i thought the s2 header was proven to make power..
      you wouldnt run that?
    22. Member
      May 8th, 2000
      Race car
      12-08-2010 11:30 AM #22
      I kind of could though, and that's why I stand 110% behind everything I've ever said, posted and more importantly done back then.
      Now, people have seen that as being a 'know it all' over the years when the reality was just me being upfront, stating actual facts with results. You get backlash from those who just don't want to hear about it for one reason or another. Usually, it is from those who paid out $600-$1000 for something that does pretty much nothing aside from weighing 12 lbs. less. Sure, it's going to burn and chap some asses, but guess what? It burned me too, bad (I lost a race because of this!!!) and I think that fact gets lost in the wash.
      Just for the hell of it, here is a recent topic with some track results from years ago...
      http://forums.vwvortex.com/showthrea...1#post67119188
      Let's look at the variables that did change during that event:
      - 93 lbs. weight removed between runs 2 and 3
      - The track was re-sprayed between runs 3 and 4 (1st round eliminations)
      - The weather changed for all runs from morning to afternoon
      If you take all that into consideration and then look at the actual results there is just no way anyone could claim a lack of consistency; that's just one event too. If someone really wanted to poke holes at some .01 to .04 sec difference, by all means go right ahead, just keep in mind we're not talking about a car with an automatic transmission, stall converter, air shifter and a multi-stage throttle stop.
      None of the above is arrogance either so please don't take it that way. I knew this car inside and out, drove the hell out of it, and I honestly don't think anyone here really understood the extent and my approach on things with the car.
    23. Member EuroSportChicago's Avatar
      Jun 9th, 2010
      Chicago
      GTI VR6 MK3
      12-08-2010 01:55 PM #23
      I didnt say they lose power, if your trying to make power your money will go farther elsewhere.
      12v VR6 forum ; )
    24. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      12-08-2010 11:54 PM #24
      Quote Originally Posted by mk3pete View Post
      Good product, but not for any setup I'd run. Needs longer primaries and a size up on the primary diameter wouldn't hurt.
      -Paul
