Page 5 of 5 FirstFirst 1 2 3 4 5
Results 141 to 156 of 156
Thread: Forge Transverse TSI Oil Catch Tank Initial Group Buy
  1. Member VWRedux's Avatar
    Jun 3rd, 2009
    Potomac Maryland
    Started NHTSA DSG Campaign/'09WolfieDSG died@623mi. VW took it back.Bought MkVI/GTI Blk 6spMT/SR/Xen
    06-07-2011 05:47 PM #141
    Quote Originally Posted by Angel@forgemotorsport.com View Post
    Mantech has an axe to grind. He's angry because he doesn't understand how catch cans work and is lashing out at anyone that sells them and is willing to give him an audience.
    No axe to grind. Don't spin this! It's too late Angel. Mike stepped in doodoo. You and Mike have misled everyone on this thread and website from the beginning. Mike said that his product removes "all" the oil and vapor from the pcv system (which it doesn't) and in turn will "keep the system clean from depositing on the intake valves." How many sales did you get from TSi and TFSi owners based on those lies? Then he says on another thread that he never said such a thing. Well what is it? No axe, the TRUTH!
    "There's nothing like a well tuned car on an open road". Paul Newman
    *The New 2011 VW Jetta... At Least You Pay Less To Get Less!*
  2. Banner Advertiser Forge US's Avatar
    Jul 31st, 2002
    Orlando FL
    '09 TTS / '12 Golf R
    06-07-2011 05:53 PM #142
    Quote Originally Posted by VWRedux View Post
    My statements are 100% factual.
    The catch tank does remove the aerated oil vapors from the PCV system.
    You continue to overlook/ignore the other contributing factors that lead to carbon buildup on the intake valves. Seepage from the valve guides being the secondary cause. No one ever claimed a catch tank system would eliminate seepage from the valve guides.
    I wish you luck and look forward to your campaign for a valve guide recall from VW.
  3. Member VWRedux's Avatar
    Jun 3rd, 2009
    Potomac Maryland
    06-07-2011 05:53 PM #143
    Quote Originally Posted by HYDE16 View Post
    No audience on this thread for that hatred....
    It's not hatred. You've been had.
  4. Member VWRedux's Avatar
    Jun 3rd, 2009
    Potomac Maryland
    06-07-2011 06:03 PM #144
    Quote Originally Posted by Mike@ForgeMotorsport View Post
    No, you SAID that your catch-tank "will capture ALL the blow-by gases and vapors that would otherwise lead to deposits on the intake valves and will keep the system clean and performing optimally long term" did you not?
    The kit is recirculating in design so as to maintain emissions compliance, however, it will capture all of the blow-by gasses and vapors that would otherwise lead to deposits on the intake valves, thereby keeping the system clean and the engine performing optimally long-term.
    And then you said on the "Hoedown" thread:
    I'll chime in. Absolutely nowhere have we ever stated that a catch tank kit, ours specifically, is guaranteed to prevented carbon buildup on your intake valves. If you purchased one of our kits under the assumption that the potential for carbon buildup was going to be completely eliminated immediately upon installation, either someone else led you to believe that, or you came to that conclusion on your own, because no one here would ever had stated as much to anyone.
    Well you did. You are on notice.
  5. Banner Advertiser Forge US's Avatar
    Jul 31st, 2002
    Orlando FL
    06-07-2011 06:09 PM #145
    My reading level is pretty high. I know what I said, and I stand by it. You continuing to quote me repeatedly doesn't change anything.
    I never stated that clean valves were guaranteed via the use of our catch tank kit alone.
    Your interpretation of my statements has only served to cause you to expect a different result than you should have from the use of this product, through your inadvertent or perhaps deliberate ignorance to the other causes of valve deposits.
  6. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    MkVI GTI/2Dr Manual Trans / Future Golf-R Owner
    06-07-2011 06:24 PM #146
    I think a court of law will change your "reading level" a bit. Have you been taking speech lessons from Anthony Weiner or something? Otherwise you must be delusional since you refuse to see that your comments misled your customers. The fact is not whether your statements are greased to your advantage, but whether your customers interpreted your slick comments to mean what most would think they mean. Knowingly making intentional misrepresentations for monetary gain is prosecutable.
    Gott ist immer auf der Seite des stronest Armee. - Voltaire
    Future Golf-R Owner
    "Those who defend corruption, are often practicing corruption." VWRedux
  7. Banner Advertiser Forge US's Avatar
    Jul 31st, 2002
    Orlando FL
    06-07-2011 07:00 PM #147
    Quote Originally Posted by ManTech View Post
    I think a court of law will change your "reading level" a bit. Have you been taking speech lessons from Anthony Wiener or something? Otherwise you must be delusional since you refuse to see that your comments misled your customers. The fact is not whether your statements are greased to your advantage, but whether your customers interpreted your slick comments to mean what most would think they mean. Knowingly making intentional misrepresentations for monetary gain is prosecutable.
    Quite the contrary in fact.
    It is actually your reading comprehension that needs to be examined here.
    The only individuals claiming to have purportedly been misled are a sad pair of wannabe e-crusaders who have never actually purchased the product in question, but apparently desperately want to be convinced to spend their money on a catch tank, however, they subjectively no longer see the benefit upon the joint realization that they didn't understand that other factors lead to valve deposits.
    None of the actual customers of the product in question have come forward making such claims of feeling misled. In fact, the exact opposite has occurred. Multiple customers have repeatedly stated that they still find value in the proven function of the product, and secondarily do not feel as though they were misled to expect a miracle cure to the problem.
    Additionally, I have spoken in person with numerous potential future customers who still plan to purchase the product based on their own assessment of the situation having read and fully understood the point you two are trying to make. Those individuals still find value in the benefit of the product, in spite of the fact that the deposits will still occur to some degree.
    Instead of wasting everyone's time with this pointless drivel, perhaps you should be applauding myself, Forge, and the other manufacturer's of catch tank kits for proactively putting forth time, energy, and resources to attempting to address a known problem, even if the benefits only partially remedy the situation. Attacking us for our efforts to address a problem with another "product" as it were (the engine in question), put out by another manufacturer (VW), does nothing to solve the problem.
    We have done nothing different than has been done by countless other aftermarket companies before us, which is to, even partially, improve the work of the OEM manufacturers. To that end, we have succeeded, and we have deliberately misled no one in the process.
  8. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    06-07-2011 07:04 PM #148
    Whatever you say boss. We'll soon see.
    Future Golf-R Owner
  9. Banner Advertiser Forge US's Avatar
    Jul 31st, 2002
    Orlando FL
    06-07-2011 07:05 PM #149
    You will be quite hard pressed to substantiate these claims, because nothing of the sort ever occured.
  10. Member dsm1983's Avatar
    Aug 8th, 2009
    Birmingham, AL
    '10 GTI, '09 JSW TDI
    06-07-2011 07:10 PM #150
    My Forge/BSH catch can setup is keeping my charge piping clean and efficient.
  11. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    06-07-2011 11:48 PM #151
    It's so clear that you've been lying about this for so long you cannot see past your own
    Future Golf-R Owner
    Nov 7th, 2008
    Stamford, CT
    2001 (AWD engine) GTI :: 2011 Shadow Blue GTI
    06-08-2011 04:56 PM #152
    I still believe that it works to an extent. I also am not sure how many other people have seen that one thread of the before and after pictures of the guys valves that had them cleaned with and without a catch can (now I cant find the link) but that is the ONLY ONE I have seen.
    Frankly, from the looks of that one review it is enough to turn me off for around 500 bucks (I rather xpel/chip my car).
    I would LOVE to see more BEFORE/AFTER pictures of valves using catch cans and those not using catch cans. I think I'll make a thread just for that unless there is one already? Also, I plan NOT to aim it at one company like Forge/BSH or anyone in specific. I just want more proof of if its really worth 500 or should I just build a cheapo one and get the same minimal effects.
    Before and afters
    V/r
  13. Member HYDE16's Avatar
    Aug 20th, 2010
    Morris County, NJ
    2011/VW/GTI MK6
    08-12-2011 06:51 PM #153
    Finally got around to emptying my Forge Transverse Catch Can after having it installed in February of this year. After 6 months of driving this is what accumulated. I know there will still be some carbon build up inside of my engine but I'm so glad none of this stuff passed through my engine. I know it's part water / part oil / part whatever else but it has to play some role in keeping the engine cleaner. I also performed a Seafoam treatment on my car which had some neat results. I plan I doing the seafoam treatment every 10K miles, then Amsoil Euroblend oil every 5K and empyting this catch can as needed.
    http://forums.vwvortex.com/showthrea...8#post73027288
  14. Member HYDE16's Avatar
    Aug 20th, 2010
    Morris County, NJ
    2011/VW/GTI MK6
    09-09-2011 10:46 AM #154
    Just as an update for believers or non-believers, my car is on a lift at a shop now. Twincooler hoses were removed, not one drop of oil, the inside of the hoses are bone dry. As I said before, I installed the Forge Catch Can on my car to keep oil from building up in the intake tubing (intake / tubing / intercoolers).
    So far so good, well worth getting this kit to see that the tubing is dry unlike when I took the stock hoses apart when installing the Twincooler and Catch can originally (oil all over).
  15. Member Java^Tiggy's Avatar
    Jan 18th, 2012
    Huntington Station, NY
    '12 Tiguan SE 4Motion
    10-11-2012 12:56 AM #155
    anyway another gb can be set up for this??
  16. Member HYDE16's Avatar
    Aug 20th, 2010
    Morris County, NJ
    2011/VW/GTI MK6
    10-11-2012 07:32 AM #156
    Quote Originally Posted by Java^Tiggy View Post
    I'll find out.
