VWVortex.com - coolant temp sender vs. oil temp sender
    Results 1 to 10 of 10
    Thread: coolant temp sender vs. oil temp sender
      Sep 12th, 2010
      RI
      84 GTI, 83 caddy, 13'CC, 87 cabby
      12-10-2010 04:43 PM #1
      Does anybody know if the small one spade sending unit used for the coolant temp is PHYSICALLY the same as the one for the oil temp gauge?
      Meaning if I have an extra one in a coolant flange I pulled, can it be used as the sender for the oil gauge? Theoretically they are both thermoresistors to ground and "look" identical... just not sure if the range would be the same.
      Thanks!
      Piss poor preparation promotes problems!!
    2. Member -teknien-'s Avatar
      Sep 7th, 2004
      Long Island NY
      83 GTI, 03 GOLF
      12-10-2010 05:13 PM #2
      They are different!
      Quote Originally Posted by g60vw View Post
      If I thought like that I would have gotten out of mk1's back when they were still A1's
      Quote Originally Posted by goosler View Post
      screw all of you & your stupid cars.........see you at madness!
      I'm a 1%er
      Feb 8th, 2010
      Portage Lakes OH, Thulcandra
      2000 Passat Wagon, 2015 Tiguan S, 84 Scirocco and Fritz the '82 Caddy
      12-10-2010 06:40 PM #3
      I had the same question as my Caddy has both senders. They register the same on the gauge. I'd like to use one for oil temp if it is the proper resistance range.
    4. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      83 TD Jetta, 68 Bus, 83 2dr Jetta 16V, 1971 Kawasaki H1 500
      12-10-2010 08:39 PM #4
      Originally one has black insulator & one has white. Aftermarket suppliers only sell one replacement, white, for both applications.
      I also think that VW supersceded to one replacement part number. I don't feel like changing my screen resolution to open up ETKA to check.
    5. Geriatric Member JUS_GT_EYEZ's Avatar
      Nov 12th, 2001
      NY/NJ
      Green MK1, White Rocco, Red Mk2,Yellow Mk4,Grey Wagon
      12-10-2010 08:41 PM #5
      Etka lists them both as the same..
      "Its cool to spool, but I'd rather be blown.." - JUS_GT_EYEZ
      My FLickr <-- DUKEDLF
      Digital.Life.Form
    6. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      12-10-2010 08:48 PM #6
      Sorry the one available is Black...
      http://www.autohausaz.com/search/pro... Sender Switch
    7. Member -teknien-'s Avatar
      Sep 7th, 2004
      Long Island NY
      83 GTI, 03 GOLF
      12-10-2010 09:43 PM #7
      Rock auto list them as different part numbers!
      I'm a 1%er
    8. Geriatric Member JUS_GT_EYEZ's Avatar
      Nov 12th, 2001
      NY/NJ
      12-10-2010 10:07 PM #8
      ETKA > Rock
      Digital.Life.Form
    9. Member 8382's Avatar
      Feb 18th, 2006
      NL
      its got a cop motor!
      12-11-2010 09:45 AM #9
      As far as I know YES!
    10. Member
      Sep 12th, 2010
      RI
      12-11-2010 12:39 PM #10
      ahh what the hell I will try it today and see what happens. What is the worst the can happen? That reminds me, I really should get a fire extinguisher out there soon!
