VWVortex.com - Battery Light On - Alternator Whine
    Results 1 to 6 of 6
    Thread: Battery Light On - Alternator Whine
    1. n00b
      Dec 5th, 2010
      Costa Rica
      Jetta Trek 1996
      12-13-2010 03:13 PM #1
      Hi there fellows!
      So this morning when I started my car, the battery (alt) light stayed on and I heard a whine coming from the alternator. What do you guys think will be the cause of this? Belt too tight? Alternator bearings?
      Under acceleration the battery light is dimmed (barely visible) but when I come to a full stop the light gets bright red.
      The alternator was rebuilt probably about 3 year ago... and the belt was replaced 8 months ago.
      Any and all help is appreciated!
    2. 12-13-2010 03:18 PM #2
      The belt normally whines when it is loose. Check the tensioner, then proceed to the belt and alternator. my money is on the tensioner.
      Garage Sale, lots of parts for sale
      GLX Tails for sale $50, PM me
    3. n00b
      Dec 5th, 2010
      Costa Rica
      Jetta Trek 1996
      12-13-2010 03:26 PM #3
      I checked the belt (with my hand tho) and it feels very tight...
    4. n00b
      Dec 5th, 2010
      Costa Rica
      Jetta Trek 1996
      12-13-2010 05:26 PM #4
      help!
    5. Member themagellan's Avatar
      Mar 30th, 2007
      East
      1991 Audi 200 20vt Quattro
      12-13-2010 06:41 PM #5
      If the belt is too tight it will squeal.
      But seriously,
      "My alternator is making noise and my dash light says that my battery isn't charging"
      Use your brain and do what you think you should do. Even better buy a new belt with it and call it maintenance. Checking grounds and adjusting the tensioner before posting helps as well.
      Or you can be a man and rebuild that alternator
    6. Banned
      May 15th, 2006
      PNW
      Jettas.. Dodge Cummins, 1985 Trans Am,
      12-13-2010 07:53 PM #6
      A loose belt would make a squealing noise. Your symptom sounds like alternator.
      Replace the reg, diode trio, flux capacitor, and maybe bearings.
