VWVortex.com - 49-00 - No Communications alarm system transporter t5
    Results 1 to 3 of 3
    Thread: 49-00 - No Communications alarm system transporter t5
    1. 12-14-2010 05:17 PM #1
      Hi i'm having a few problems with my transporter t5, the alarm everytime you lock the van, the doors are all locking. I've performed a scan with the following info:
      Tuesday,14,December,2010,20:37:06:28495
      VCDS Version: Release 10.6.3
      Data version: 20101206
      Chassis Type: 7H - VW Transporter
      Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
      57 6E 76 77 78 7D
      VIN: WV1ZZZ7HZ4H085824 Mileage: 99860km/62050miles
      Address 01: Engine Labels: Redir Fail!
      Part No SW: 070 906 016 HW: 028 101 073 2
      Component: R5 2,5L EDC 0000SG 5947
      Revision: 12345678 Serial number: VWZ7Z0D8883307
      Coding: 0000032
      Shop #: WSC 02756 785 00200
      VCID: CD9AF7DE2D57
      3 Faults Found:
      18263 - Powertrain Data Bus: Software Version Monitoring
      P1855 - 000 - -
      Freeze Frame:
      RPM: 0 /min
      Torque: 240.0 Nm
      Speed: 0.0 km/h
      Load: 0.0 %
      Voltage: 12.08 V
      Temperature: 9.9°C
      Temperature: 21.6°C
      Temperature: 9.0°C
      16683 - Boost Pressure Regulation: Control Range Not Reached
      P0299 - 000 - - - Intermittent
      Freeze Frame:
      RPM: 2268 /min
      Torque: 336.0 Nm
      Speed: 119.0 km/h
      Load: 73.3 %
      Voltage: 14.29 V
      Bin. Bits: 00000000
      Absolute Pres.: 2080.8 mbar
      Absolute Pres.: 1632.0 mbar
      17911 - Load Signal from Alternator Term. DF: Implausible Signal
      P1503 - 000 - - - Intermittent
      Freeze Frame:
      RPM: 777 /min
      Torque: 30.0 Nm
      Speed: 0.0 km/h
      Load: 0.0 %
      Voltage: 12.01 V
      Bin. Bits: 00000000
      Load: 0.0 %
      (no units): 0.0
      Readiness: 0 0 X X X
      Address 03: ABS Brakes Labels: 7H0-907-37x-ASR-F.lbl
      Part No: 7H0 907 379 E
      Component: ASR FRONT MK25 0103
      Coding: 0007205
      VCID: 377635363FCB
      No fault code found.
      Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
      Part No: 7H0 937 049 H
      Component: BORDNETZ SGVER 1.0 0901
      Coding: 0000004
      VCID: 377635363FCB
      4 Faults Found:
      01598 - Drive Battery Voltage
      002 - Lower Limit Exceeded
      001 - Upper Limit Exceeded
      00077 - Windshield Wiper Stop Switch (F229)
      004 - No Signal/Communication
      00966 - Fuse for Blinkers (S151)
      014 - Defective - Intermittent
      Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 1C0 909 605 A
      Component: 3B AIRBAG VW51 0008
      Coding: 13122
      Shop #: WSC 02756
      VCID: 2240F4628449
      1 Fault Found:
      00532 - Supply Voltage B+
      07-10 - Signal too Low - Intermittent
      Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
      Part No: 7H0 920 950 G
      Component: KOMBI+WEGFAHRSP VDO V01
      Coding: 03412
      Shop #: WSC 00447
      VCID: 2F660D56C79B
      WV1ZZZ7HZ4H085824 VWZ7Z0D8883307
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway KCAN 0001
      Coding: 00006
      Shop #: WSC 02737
      VCID: F0E44E2A9A25
      Address 46: Central Conv. Labels: 7H0-959-433.lbl
      Part No: 7H0 959 433 B
      Component: Komfortgerát 0004
      Coding: 00021
      Shop #: WSC 02756
      VCID: 32600422D4A9
      2 Faults Found:
      01134 - Alarm Horn (H12)
      77-10 - Internal Supply Voltage - Intermittent
      Address 56: Radio Labels: 1J0-035-15x-56.lbl
      Part No: 6X0 035 152 C
      Component: Radio BNO 0006
      Coding: 00001
      Shop #: WSC 02737
      VCID: 31620B2ED1AF
      End ---------------------------------------------------------------------
      I cleared the alarm fault codes, relocked the van (which made the alarm come on again) re read the codes and got the following:
      Tuesday,14,December,2010,20:44:43:28495
      Control Module Part Number: 7H0 959 433 B
      Component and/or Version: Komfortgerát 0004
      Software Coding: 00021
      Work Shop Code: WSC 02756
      VCID: 32600422D4A9
      1 Fault Found:
      Anyone got any idea's?
      Thanks
    2. 03-29-2011 12:52 PM #2
      sound like your alarm siren packed up
    3. Member jetta ,97's Avatar
      Jul 25th, 2009
      Dallas (Plano),TX
      Jetta TDI 2006 with MK6 cluster & Golf TDI 2004 with MFA cluster
      03-29-2011 08:55 PM #3
      Yap , you need new siren.Most common problem on cars with siren.
      My Jetta TDI MK5 with MK6 Color cluster
