VWVortex.com - Has anyone replaced their Routan rear brake pads???
    Results 1 to 12 of 12
    Thread: Has anyone replaced their Routan rear brake pads???
    1. 12-15-2010 09:02 PM #1
      I was looking for a DIY, but search didn't return anything.
    2. 12-17-2010 07:15 PM #2
      I was hoping someone who has replaced Routan pads would have resopnded. I don't want to leave you hanging, so I can tell you about the Dodge Journey, which apparently has the same brakes as the Caravan, which are apparently the same as the Routan. So, for what its worth, here is my input as to the Journey:
      1. First, the rear brake caliper requires a special tool to push back in the piston. This is very important so you don't break it. It actually screws in. I got the tool from a local parts store as a lender. You should be able to find a local parts store with a loaner set to borrow.
      2. If your rotors are warped at all, you must replace them. No turning them, it is only throwing good money after bad. The rear rotors are already too thin, if you turn them they will only warp sooner, much sooner, due to a lack of material to better dispurse the heat. Don't turn them at all if they are not warped. Just clean them up a little and put on new pads. But I am guessing the rotors are bad. Get a good upgrade. A local NAPA had an upgraded version, so they claim.
      3. They are otherwise identical to replacing the front pads. If you know how to do front disc brakes, it's identical other than the special tool to turn in the piston. Easy and fast job, not worth paying someone to do.
      Now, you should complain to the local dealer. It seems like VW is aware of the problem with the pads/brakes and may do it all for you for free.
      Good luck. I am hoping the Routan doesn't have the same brake problems as my old Journey did.
    3. Member haunted reality's Avatar
      Apr 18th, 2001
      Delton, MI
      '15 Jeep Cherokee, '16 Jetta Sport
      12-18-2010 03:47 PM #3
      Just had mine in for 18k and they said the brakes look good. I got them replaced by VW at the 12k, I'll cross my fingers!
    4. 12-26-2010 01:34 PM #4
      steveaut.... did u have any probs pushing the actual piston back?
    5. 12-28-2010 06:50 PM #5
      Quote Originally Posted by dub_this View Post
      You have to use the special tool that screws the piston back in. It will not push back in like the fronts. The rear brakes have a threaded piston. It was kind of pain, but with the loaner kit from Auto Zone, it threaded back in.
    6. 01-07-2011 08:54 AM #6
      yup... this twas the disk brake piston tool i ended up using.
    7. Member 2008cc's Avatar
      Apr 16th, 2001
      Charlotte, NC
      82 VW Caddy, 01 Audi Avant, 14 VW Passat, 75 Dodge Dart "Hang Ten"
      01-15-2011 08:06 PM #7
      just had my rear brakes done on my cRoutan at 42000 miles.
      Chapter 11 Dubs - 054
    8. 01-17-2011 12:51 PM #8
      Quote Originally Posted by 2008cc View Post
      Is this your first replacement? What has your brake experience been so far? Since you have a fair amount of miles, I am curious about your experience with the van thus far. Is yours a 2009?
    9. 10-05-2013 12:53 PM #9
      do i have to do any thing with the parking break
    10. Member
      Jun 14th, 2009
      Northport, ME
      Nocturne Black 2009 VW Routan SEL/RSE, Cinnamon 2010 Lincoln MKX AWD
      10-05-2013 08:25 PM #10
      I replaced mine at 60K, just a few months ago. I used Raybestos rotors and pads. So far, so good, but the fronts need replacing now due to warped rotors [not a surprise as they were replaced at 8K and 30K under warranty].
      When I replaced the rears, I could not keep the rubber boot from turning with the piston on the right caliper - ended up tearing it and replacing the caliper with a rebuilt unit - bummer. Left side was a breeze.
    11. 03-25-2014 02:20 AM #11
      Just replaced my brakes with R1 Concepts rotors (premium, slotted) and Posi Quiet Ceramic pads all around.
      Thank you for the info on the rear rotors.
      Jun 14th, 2009
      Northport, ME
      03-25-2014 01:35 PM #12
      One more thing - If you do the job yourself - clean everything thoroughly with Brake Parts Cleaner before using the tool to reseat the caliper piston. And, when turning the tool, be careful that the rubber boot is free and does not turn with the piston. If it does, it will stretch and tear and you'll need to replace the caliper.
      Be sure and remove as much fluid from the master cylinder as possible with a suction tool to prevent overflow when reseating the caliper pistons. Replace with fresh fluid after the job is done.
      The rotors and pads I used were Bosch and I'd use them again.
