VWVortex.com - Oil 5w-30 ok instead of 5w-40?????
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 38
    Thread: Oil 5w-30 ok instead of 5w-40?????
    1. Member Jettn1's Avatar
      Jun 9th, 2010
      Western Kentucky
      2014 CC R-Line
      12-16-2010 11:06 AM #1
      Here we go and I have searched like crazy and read on the oil and lube forum the recommended oils for 502.00........I could not get anywhere 5w-40 Castrol, so I got 5w-30 Castrol Edge, the car seems to perform better than it did before, after changing to this oil. The stealership changed it the last time (after they had installed new camshaft, follower, and HPFP) and I didn't ask what they used. My 2.0t FSI motor has 71k miles on it, and the temps this time of year are anywhere from 10 degrees (seldom) to 50 degrees, safe to say 30-35. TIA for any help.
      1999 Jetta GL - 1998 to 2003 my first VW
      2002 Nissan Altima - 2003 to 2006 JUNK!! went back to VW
      2006 Jetta 2.5 - 2006 to 2010
      2007 Passat 2.0t Sport Pkg. II 6MT - 2010 to 2012
      2010 CC Sport DSG - current
    2. 12-16-2010 03:32 PM #2
      It's not just the oil viscosity that's important, it's also the oil chemistry. As long as the oil you use is VW 502 certified, a 5W-30, 0W-30, 5W-40 or 0W-40 will work just fine. FWIW, there are numeorus online suppliers of VW approved 5W-40 oils such as ECS Tuning. Mobil 1 0W-40 is a Euro formula and excellent VW approved oil that is available at numerous retailers.
      Nov 10th, 2010
      mid hudson valley
      2002 jetta 2.0tx, 2003 passatx, 2006 jetta 2.0tx, 2014 tiguan se awd, 2015 gti
      12-16-2010 05:38 PM #3
    4. Banned
      Jun 19th, 2009
      12-17-2010 12:57 AM #4
      Yep, well I put Edge 5w-30 in my 2.0 TSI a few days ago. Drained fresh dealer Syntec 5w-40 to do so. 5w-40 is very thick in cold, which is bad for turbo apps. This is the reason for the evolution of 0w-30 and 0w-40 oils, however 5w-30 synth is thinner than all in the cold, near zero F, about 1/2 as thick as 5w-40.
      Edge is likely the same formula as the VW spec SLX Pro OE anyway. All the new VW 504 oils ARE 5w-30s, ftr. A consensus is forming around Edge being the best of the thin 30 weight synthetics.
      It worked great in my friend's 1.8t, at a decent interval.
      5w-30 synth is a great choice for winter, and seems fine in hot weather too. Thinner oils simply protect better now because of their improved additives.
      I'm sure you're aware of the issues w/FSI, so I won't get into it. I'm doing a UOA in april that'll I'll be sharing.
      In the meantime, if you want another oil to try that isn't expensive and is as good as anything if not better, Mobil 1 High Miles, all the weights have the premium generic Euro specs, A5 and A3, like Edge does.
      BTW- my engine is running great now and was good on Quaker State Synth 10w-30, another sleeper oil.
    5. Banned
      Jun 19th, 2009
      12-19-2010 09:25 PM #5
      Doing awesome in single digit F weather.
    6. Member slowbluVW's Avatar
      Oct 15th, 2002
      Hickory Hills, IL
      Shadow Blue 2004 Jetta Wagon GLS 2.0/01M with 68K miles.
      12-31-2010 02:49 AM #6
      Try to find Valvoline SYN Power 5W40, Mobil 1 0W40 or do what most do, just run Shell Rotella T6 5W40. The Valvoline 5W40 is kinda hard to find but the Mobil 1 can be found at any Autozone and the Shell can be found at any Walmart. Autozone also carries the Castrol Syntec 5W40 too.
    7. Banned
      Jun 19th, 2009
      12-31-2010 03:24 PM #7
      Shell Rotella T Synth 5w-40 is def the easiest 5w-40 to find, you just need to look in the truck oil section with the 15w-40 HD oils.
      If you see below 0f temps, I suggest you first test some 5w-40 in the freezer next to any 5w-30 and compare how thick the 5w-40 really is.
    8. Member sbachmeier's Avatar
      Mar 2nd, 1999
      Middleton, Wisconsin
      2010 Passat Variant
      12-31-2010 07:50 PM #8
      Quote Originally Posted by AudiJunkie View Post
      You're scaring me -- I live in Wisconsin.
      But this seems counter-intuitive to me: shouldn't the 5W rating of each oil yield a very similar cold-temperature pumpability? Cold is the reason I started using Mobil-1 0W40 in my previous Passat 1.8T. I have thought long and hard about briefly using it again in my 2.0 TSI during the coldest months of winter, even though I know it's not the best oil for this motor. However, in winter the car is generally driven fairly gently in mostly urban driving situations (it's not like you can flog the car when it's snowy and icy a lot of the time).
      2010 Passat Variant Komfort :: Island Gray :: 2.0 TSI + DSG, FTW!
    9. 12-31-2010 09:37 PM #9
      AudiJunkie's post is incorrect again... He is technically clueless on oils and posts all sorts of complete nonsense. He does NOT understand that a 5W-30 and 5W-40 oil have the same 5W COLD temp pumping viscosity rating and that the "30" or "40" refers to the HOT viscosity @ 212 F. In addition if you look at the SAE hot viscosity requirements for a "30" or "40" weight oil they can both be 12.50 cSt according to SAE J300 oil viscosity grading thus a "30" and "40" oil could be "virtually" identical in viscosity.
      Just ignore AudiJunkie. He's doing a horrible disservice to people who want accurate technical information on engine oils. VW specifically recommends 5W-40 oil for all climates, year round. You should not believe any posts that AudiJunkie makes as they are technically baseless.
      http://www.ideas4ag-ed.com/uploads/3..._viscosity.pdf
    10. Junior Member 787B's Avatar
      Aug 20th, 2010
      Central IL
      2010 CC R-Line_Black
      01-01-2011 01:03 AM #10
      Why do the rest of us have to put up with this?
    11. Member
      Nov 10th, 2010
      mid hudson valley
      01-01-2011 07:59 AM #11
      Quote Originally Posted by 787B View Post
      according to audijunk he is the only correct source. he can paste a chart or a graph and quote oil specs. etc. unfortunately, he hasn't the sense the lord allowed a goose.
    12. Banned
      Jun 19th, 2009
      01-01-2011 11:35 AM #12
      Stupid doesn't need a reason.
      Quote Originally Posted by sbachmeier View Post
      Like I said, a home test is worth a thousand, umm, graphs.
      5w-30 can actually be thinner than 0w-30.
      Talking and knowing what you are talking about are two different things.
      Same with reading and understanding, two different things.
    13. Banned
      Jun 19th, 2009
      01-01-2011 11:47 AM #13
      Quote Originally Posted by TechMeister View Post
    14. Banned
      Jun 19th, 2009
      01-01-2011 08:18 PM #14
      I went ahead and did some calculations for my friends here.
      At -13f, a cold winter morning in the northern states....
      Mobil 1 5w-40 9630cSt
      Shell RTS 5w-40 6497cSt
      Pennzoil Platinum 5w-30 3739cSt
      Castrol Edge 5w-30 3312cSt
      Edge 0w-20 1287cSt
      http://widman.biz/English/Calculators/Graph.html
      10,000cSt is (imo) the definite floor for cold starting, esp a turbo.
      I shoot for 5000cSt. Remember, as you drive off and until the oil (not water) is fully warmed, like 10 miles /15 min, overly thick oil is a burden on the engine for fuel consumption and does create excess wear.
      The vastly reduced FLOW is not good for the turbo bearings at all, they hot spot and fry right away because there isn't enough oil flowing over them to carry away the heat. Same thing goes for journal bearings. Even though pressure reads high, flow is what an engine requires. Overly thick oil builds great pressure, so dopey mechanics think it's great, but it's not. Too bad we don't have flow gauges for engines because that's a better indicator of the physical property of the lube. We don't even get oil temp gauges anymore, go figure.
      I do a lot of short trip driving, so correcting the visc I use for winter duty is a good move. My wife drives 2-3 miles to work every day. Her oil likely doesn't make it past +125f, guesstimated 3-4x thicker than normal operating temp. Her Astra specs 5w-40 in Europe, dino 5w-30 in USA...she's using Havoline DS 5w-20. No doubt it's a good choice, it works great. Just came off German Syntec 0w-30...her summer oil.
    15. 01-02-2011 04:08 PM #15
      5w40 + Canadian winter = NASTY valve tick upon start up. 5w30 cured this. I run 5w30 through the summer and its fine, even on the 30+ degree days. Now if I was in Mexico or southern Texas in the summer, maybe a 40 weight is a good choice.
    16. Member
      Nov 3rd, 2003
      ottawa, on
      98 golf 2.0, 97 golf 1.8
      01-02-2011 07:41 PM #16
      vastly reduced flow? BTW i live in canada. the best oil is definitely a 5W40 castrol. it is way more important what the oil will do at hotter temperatures if you are talking about turbos. how can there be a hot spot when the engine is cold and the turbo hasnt heated up. you are probably one of those people who get in fire it up and drive away without letting it warm up. oil is not going to compensate for stupidity. if its turbo you HAVE to let it warm up when its really cold. just common sense and physics. lol
    17. 01-02-2011 08:57 PM #17
      AudiJunkie-
      Your statements and conclusions are so baseless as to be complete nonsense. Your conclusions are based on your opinion - NOT facts. The data you posted does not even support your conclusions.
      The SAE determines oil pumpablity based on J300 test not by placing oil in the freezer. What oil to use has nothing to do with if you have a turbo or not. Your nonsense about "hot spots" and other foolishness shows you have no clue on the subject and you're trying to B.S. people.
    18. Member
      Nov 10th, 2010
      mid hudson valley
      01-02-2011 09:04 PM #18
      Edge 0w-20 1287cSt
    19. Member
      Nov 10th, 2010
      mid hudson valley
      01-03-2011 06:11 AM #19
      first, the best way to warm an engine up is drive off under moderate load and moderate rpm.
      second, the turbo's are water cooled, the oil may carry away some heat, but the coolant does the bulk of the cooling. most damage occures because the bearings can coke the oil after shutdown when there is no coolant flow on some models, although some have electric water pumps to circulate the water after shutdown to prevent cokeing.
      third, the oil in a vw is cooled by a coolant to oil heat exchanger. if the coolant is warmed up to operating temperature the oil will be also. the coolant operates off the hot side of flow and is 195f year round as long as the thermostat works.
      finally, you make everything way to complicated
    20. Member
      Nov 3rd, 2003
      ottawa, on
      01-03-2011 01:13 PM #20
      Quote Originally Posted by gmikel View Post
      i respectfully agree with all of this EXCEPT the best way to warm up an engine is not to drive off under moderate load. ok.... think of it this way, if the snow is not melting off your car it means that the car is still cold... right? other parts like accessories alternator a/c pump and other metal parts of the car will still be cold and if you are trying to get the ENGINE warm quickly you risk breaking something because with two parts at different temperatures you have different expansion rates and well especially plastic parts like to break in canadian winters haha. oh, and there is increased idle when the car is cold so that is moderate load. let it run 5-10 minutes when it is really cold. side benefit is you have time to clean the car off if necessary. safer for everyone. my 2 cents anyways.
    21. 01-03-2011 01:25 PM #21
      Agree with gmikel on this. Letting your car warm up at idle is the slowest way to warm it up and contributes significantly to fuel dilution in the oil.
    22. Banned
      Jun 19th, 2009
      01-03-2011 01:55 PM #22
      harmankardon35 A
      gmikel C
      TechMeister F
      VeeDoubleYouGuy D
    23. Member
      Nov 3rd, 2003
      ottawa, on
      01-03-2011 02:34 PM #23
      Quote Originally Posted by saaber2 View Post
      1- may be slower but it is better. ever heard that 90% of the wear on an engine is on startup? turn the pistons faster when the oil hasn't fully circulated to the top of the cams and increased wear is what you get (proportional to increased RPM).
      2- there is no way around fuel dilution in oil that is why you have to change oil more frequently in winter. cars run rich in the cold. thats obvious.
    24. Member
      Nov 3rd, 2003
      ottawa, on
      01-03-2011 02:45 PM #24
      1- the opposite is true turbos get very hot you need a heavy oil that won't break down.
      2- wasn't 0w30 created for energy conserving and hybrid applications?
    25. Member
      Nov 3rd, 2003
      ottawa, on
      01-03-2011 02:52 PM #25
      turbos get red hot. they are without a doubt the hottest thing attached to the engine. they need a thicker oil! what does synthetic oil do better than conventional oil? it resists chemical breakdown. from what? heat. turbos spin 2-3 times the RPM of the pistons and maybe more. that friction causes heat. that is why if you read your owners manual a vw engineer has said to use 5w40. if that is not available and only in cold weather you CAN use 5w30. vw engineers have engineered that car for 5w40.
