Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 36 to 70 of 196
Thread: Shaved caddy project...
  1. Senior Member IronTrap's Avatar
    Jun 14th, 2001
    Gilbertsville, PA
    '50 Dodge Pilot-House, '52 DKW 125W, '76 Rabbit Ocean Bleu X2,EA Cabriolet,'77 Scirocco
    01-06-2011 09:51 AM #36
    Quote Originally Posted by BadassLilGolf View Post
    I think I have decided to just clean up and replace gaskets in the bottom end. Supposedly it is low mileage and aba's are pretty bulletproof. I will be rebuilding the head though.
    In all seriousness. If you aren't trying to build an all-out show car, or a crazy race-machine.. that idea is the best bet. ABA's are pretty much bullet proof, plentiful, and cheap to replace. Clean the engine up, throw it in, have fun, and get another $100 ABA if this one ever gives up the ghost.
    keep up the good work, always glad to see another mk1 saved
  2. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    '10 TDI JSW, '01 Passat wagon, '81 Polo, '81 Caddy
    01-06-2011 01:59 PM #37
    Quote Originally Posted by saddest6day66 View Post
    That is my thoughts exactly.
    For the head I already have the cam, light weight lifters, valve stem seals, and the obd1 springs should be good. I am just going to do a little diy porting and probably have the machine shop deck the head. I understand the stock valves are already a 3 angle design? So I will just lap those. Then just freshen up all the gaskets and have fun with it.
  3. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-08-2011 04:27 PM #38
    Started getting the bottom end cleaned up today. Got all the carbon build up out of the cylinders, and the pistons and walls look nice and smooth. Block sanded the top of the block to remove all the old gasket material. Cleaned up all the gasket surfaces on the sides of the block, and started grinding all the rust and gunk off the outside. I had to use a chisel and hammer to break some of the flaking rust off the block.
    The only loss of the day is the damn woodruff key from the intermediate shaft pulley. It fell and vanished into thin air. I looked on my hands and knees with no luck. Just something else to come up with.
  4. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-11-2011 05:01 PM #39
    Nothing too exciting lately.
    The Recaros I got didn't have the motors on the base. So instead of finding them, then wiring them only to never actually adjust the seat I just ran a bolt through and tightened them down so they are all the way down. I can also set them to whatever height I want then leave it.
  5. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-14-2011 08:57 AM #40
    Fuel pump came thismorning.
  6. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-15-2011 02:44 PM #41
    Dropped the wheels off at the machine shop today to price out center caps.
    Hopefully bringing the truck to my garage on Monday so some real work can begin.
    A few more parts I dug out of storage.
  7. Junior Member VwRoLLiNg's Avatar
    Nov 21st, 2010
    binghamton ny
    b5 passat 1.8t, mk1 diesel rabbit,mk4 golf, mk3 jetta and gti
    01-16-2011 02:04 PM #42
    Projects looking good
    kirt
  8. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-17-2011 04:07 PM #43
    Got the truck moved to my house today.
    Takes up more room than the polo in my little 1 car garage.
    Engine bay that previous owner started shaving. I guess I will be running no HVAC.
    Interior pretty much stripped
    Spare parts in the bed. Nice if I decide to narrow the axle I have a spare.
    Next is to get all the stuff out of it and strip it the rest of the way down.
  9. Member Big CADDY's Avatar
    Aug 28th, 2001
    Mt. Holly Springs, PA
    01-17-2011 04:12 PM #44
    good work. I'm just over the mountains from ya. I'm sure I'll see this soon enough.
  10. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-17-2011 05:56 PM #45
    Quote Originally Posted by Big CADDY View Post
    Yup, you are not far. I hope to have it on the road by summer.
  11. Member FLATBLACKMK2's Avatar
    Oct 10th, 2003
    Mickey Mouse's Trouwzah'z Dude.Guy
    92 Monstah 4Lugz6Slugz,84 GLI fo'door
    01-18-2011 08:41 AM #46
    ABA on r1 Carbs.
    Broke.Status.N.E.K<3F6squared<3GetLow<3VwFiends<3Fifteen52<3Ban chWerks<3sdobbinsphotography<3CreEp CuStOmZR.I.P.ALEXIR.I.P.Scott TaylorR.I.P. Moses
    DrivenApparelGengstout#SLAW#
  12. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-18-2011 01:28 PM #47
    Bed all cleaned out and very pleased with the condition. Only a couple little things to address.
    Interior looks solid as well. gotta strip all the crap off the floors and clean it up.
  13. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    01-18-2011 03:13 PM #48
    Looks like a solid little project for sure!
  14. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-18-2011 11:22 PM #49
    Quote Originally Posted by _WCHLVR_ View Post
    It being so solid is making me want to take the project further than I would if it were beat.
  15. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-20-2011 08:26 PM #50
    The beauty of buying a basket case.
    Sorting through the box of random parts to see what I don't have to buy.
    Have some seals, but not all. Have some interior parts, but not all. Have some of the glass, but not all (just need a windshield). Have all the wiring, but doesn't entirely match with the dash or motor I am running. To be expected and should be tons of fun. I need to keep myself organized so I don't go nuts.
  16. Member MicroCADDY's Avatar
    Jul 21st, 2008
    Louisville, KY
    VW Caddy, VW THING & Audi A4 Quattro
    01-20-2011 08:35 PM #51
    I have found that the best way to do this is in the freezing cold YEP super cold temp or the coldest temps in your state & a flat screw driver, putty knife & or paint scraper.
    Tried the heat gun route & it sucked & was f n messy. ( why reactivate the glue )
  17. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-20-2011 08:44 PM #52
    Quote Originally Posted by VWcaddy_LouEville View Post
    Well my garage is only heated with a small propane heater, so cold isn't a problem. I was also going to give the dry ice method a shot.
  18. 01-20-2011 09:18 PM #53
    Heat guns suck.
    Never tried freezing it, I may try that too.
    I just heated with a torch until it bubbled all over then it came off in big pieces.
    Took about 20 min.
    Love the carbs
  19. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-20-2011 10:23 PM #54
    Quote Originally Posted by The Python View Post
    Heat guns suck.
    Took about 20 min.
    Love the carbs
    Well I have done heat before and it was a sticky mess. So I think the cold may be a better route.
  20. Member
    Apr 22nd, 2002
    NJ 08002
    2 clunkers & a nicer clunker
    01-21-2011 12:18 AM #55
    Are you referring to the asphalt mat or glue?
    For the glue, wait for the coldest days/nights and scrape it out, as mentioned. I did it Monday night with wood chisels. It still takes a bit of effort; I was bundled up and broke a sweat.
    For the asphalt mat, some was already brittle, and already dislodged. The really tough stuff I torched from the other side of the panel, waited for a bit of smoke, then used a narrow putty knife, and most of it just peeled away.
    -Todd
  21. Member mk1daily's Avatar
    Jan 7th, 2010
    Tacoma, WA
    '81 2.0 Rabbit, '87 1.8 carbed Cabby, '80 350 Rat Rod Caddy
    01-21-2011 12:24 AM #56
    Dry ice works wonders.
  22. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-21-2011 08:28 AM #57
    Well tomorrow it is supposed to be a high of 20. I may try to grab some dry ice as well. The combination should work well.
  23. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    01-21-2011 10:56 AM #58
    If you use dry ice there's no reason to put the truck outside.
    Dry ice is something like -100˚F.
  24. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-21-2011 01:20 PM #59
    Quote Originally Posted by deathhare. View Post
    I can just not turn my heater on right away. I am going to pick up some dry ice tomorrow though. And they sell it in pellets so it should work great for spreading out on the floor.
  25. Member 2mAn's Avatar
    Oct 15th, 2006
    Seattleish
    E30 Daily & Mk1 Jetta Coupe Project
    01-21-2011 02:14 PM #60
    im liking the direction this project is going
  26. Member taymk2's Avatar
    Oct 21st, 2001
    Middleburg Va
    95 cabrio 08 jetta 01 mb 320 12 yukon xl
    01-21-2011 03:59 PM #61
    Dev this is awesome bro I want to start a project now even thou I really need to finish the mulberry first lol matter of fact get started .... Where's the bike and polo at
  27. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-21-2011 04:10 PM #62
    Quote Originally Posted by taymk2 View Post
    Hey Conte! The bike is in my shed behind the house. It's home has been down graded. The polo is over at my in-laws in one of their barns.
    The mulberry seems to be an ongoing thing. You have way more "projects" around than I do.
  28. Member taymk2's Avatar
    Oct 21st, 2001
    Middleburg Va
    01-22-2011 09:34 AM #63
    Dev it's pretty sad that your going to have your caddy done before Cory has his done. ...lol I'm pumped to see whats going to come out of that garage Btw what are you doing with that cream man/valve cover are you going to do a vr swap in the cabby
  29. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-22-2011 01:06 PM #64
    I hope I can have it done before Cory's. Not racing, I just hope my project doesn't drag out as long.
    The manifolds/valve cover were on my passat wagon. They are for sale. I started to cut into the bottom of the manifold to do a 2.9 clone though. Never finished it.
  30. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-22-2011 02:54 PM #65
    Got a few hours of work in.
    Dry ice worked excellent. Only took about an hour to do the entire floor. Then decided to start stripping the inner fenders. That didn't take nearly as long as I though either.
    So far this truly is a rust free caddy. Keeping my fingers crossed.
  31. Member
    Mar 23rd, 2004
    Leavenworth, KS
    98 Cabrio
    01-22-2011 03:18 PM #66
    The dry ice looks like the key to removing the glue.
    I know this is about the car but where's pics of the 3 year old beard (RIP)?
  32. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-22-2011 04:41 PM #67
    Quote Originally Posted by revbjeff View Post
    The other thing with the dry ice is to get the pellets. Nice even coverage. And 10lbs seemed to be the perfect amount.
    There are pictures of the beard on the first page. It's not like I grew it out for 3 years. I kept it trimmed. Trust me, I would be cool with growing it out. I think I would have to sleep in the bed of the truck in the garage though.
  33. Member
    Aug 6th, 2007
    82 mk1 Caddy, 03 E39 325iT
    01-22-2011 09:40 PM #68
    i used the drill bit method to remove the carpet glue, aka devil's snot, worked great for me. scroll down this thread to see pics:
    http://forums.vwvortex.com/showthread.php?3883028
  34. Member BadassLilGolf's Avatar
    Mar 21st, 2001
    York, PA
    01-23-2011 12:21 AM #69
    Quote Originally Posted by sriracha View Post
    I have seen that thread. It seems like the devil's snot need to be kinda warm for that to work. Right now my snot is very hard and I don't think it will stretch much.
  35. Member taymk2's Avatar
    Oct 21st, 2001
    Middleburg Va
    01-23-2011 10:18 AM #70
    See devin we have nice rust free car in va not those death rot cars in pa
