VWVortex.com - Just got code P2279
    Results 1 to 4 of 4
    Thread: Just got code P2279
      Dec 11th, 2009
      Clifton Park, NY
      2006 VW BT Passat
      12-19-2010 12:24 AM #1
      okay so i just got the code P2279 -
      VAG says lower limit exceeded mil on!!!
      checked the code in the bentley and got this
      Volkswagen > B6 > Diagnostic Codes > BPY > P2279 > Overview
      SAE VAG Description
      P2279 18711 Intake Air System Leak
      Intake system
      Intake Manifold Runner Position Sensor, checking
      Intake system for leaks (false air), checking
      Motor for intake flap,
      so any help to go from here is an 06 passat.
      Unitronic Stage III w/ PT5558BB Turbo Unitronic.ca, IE HPFP, 3in B&B TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC/Forge SS, 42Draft Design CNC Shifter bushings, BFI stage 2 motor/tranny mounts, 034 Dogbone, KW V2 coilovers, Nuespeed 25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
      Dec 11th, 2009
      Clifton Park, NY
      2006 VW BT Passat
      12-19-2010 07:39 AM #2
      okay so i cleared the code and drove for about 20 miles on the highway was 12 degrees out so didnt want to not have enough time to fully warm up. so after the 20 miles i still had a few miles to get home in 5th gear wot it would boost to about 19-21 psi then drop anywhere from 10-15 psi and bounce between there but never exceeding 16 psi.
      i dont even know where to start to look. i have no pcv, oil cap came off easy while engine was running so vac in crank case isn't higher due to a pcv (block off plate in my case) issue, cam follower was checked less then 3k ago and looked perfect
      the car surged horrible but the mil never came back on?
      stage 2 apr file, 3 in turbo back exhaust, bsh true-seal intake, bsh pcv block off plate, car idles around 800rpm. oil did look a tiny bit creamy but it had done tht the past two winters ive owned the car. last oil change was around 2k ago used m1 oil 5w-30(was just trying something new to see how much of it i burnt up)
      thanks for looking any help will be awesome
    3. Member jbyronr's Avatar
      Jul 27th, 2001
      RI, USA
      2006 GTI 2.0T, 2006 A6 3.2 quattro
      12-19-2010 09:15 AM #3
      That code and others indicate intake flap problems. First step is a software update, but if that's already done, then the intake flap motor has to be replaced.
    4. Member
      Dec 11th, 2009
      Clifton Park, NY
      2006 VW BT Passat
      12-19-2010 09:51 AM #4
      Quote Originally Posted by jbyronr View Post
      tht is not the issue this time wen i open the hood i could hear a hissing i believe its called the non return valve
      crappy cell pic but tht part in my hand is suppose to be attached, now i need to find a part number of course it happens the only day vw is closed
