VWVortex.com - jetta sunroof drain exits
    Results 1 to 5 of 5
    Thread: jetta sunroof drain exits
    1. Member 4G63Turbo's Avatar
      Dec 15th, 2004
      A4 avant gt2871r, Cabrio vr6 sc, 90 METRO
      12-19-2010 09:58 AM #1
      I can't locate the front 2 exits for my 2006 jetta.
      can anyone point me in the right direction, i dont have any exits in my doorjambs.
    2. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      2008 Cayman S, 2006 GLI, 2008 Rabbit
      12-19-2010 10:54 AM #2
      Quote Originally Posted by 4G63Turbo View Post
      Pretty sure you've got to pull the front wheel well lining...
      Ride In: 2008 Signal Green Cayman S Sport 378/700 .:. 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
      Ride On: 2010 Trek 2.1 .:. 2011 Fisher Cobia
    3. Member 4G63Turbo's Avatar
      Dec 15th, 2004
      12-19-2010 12:07 PM #3
      thanks.can anyone confirm this before i start ripping it apart in -10c.
    4. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      12-19-2010 02:30 PM #4
      Bentley states:
      Route water drain hoses at front on A-pillar and end at facing wall crossmember. Cleaning is performed from the sliding/tilting roof cur-out.
      The recommended cleaning apparatus is a speedometer drive shaft inner cable with a length of at least 90.5".
      The diagram in the Bentley shows the drain exit being at just about the bottom of the windshield in the A-pillar.
      Hope this helps...
    5. Member 4G63Turbo's Avatar
      Dec 15th, 2004
      12-19-2010 11:03 PM #5
      thank you, i will check it out
