Page 2 of 7 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 36 to 70 of 232
Thread: Anyone else like crazy front end conversions?
  1. Member Tuneman7's Avatar
    Jan 12th, 2010
    New York, NY
    '93 Audi 80 (B4)
    12-19-2010 10:35 PM #36
    I actually really like these.
  2. Member AHFlynn's Avatar
    Apr 6th, 2008
    UConn Country
    12-19-2010 10:38 PM #37
    Quote Originally Posted by Tuneman7 View Post
    plan on doing that when i get out of college. maybe techart gt rear? cant decide if its too ridiculous...
    Quote Originally Posted by redsoxreturns View Post
    Also, you're writing could use some work.
  3. Member Mosbius Designs's Avatar
    Dec 2nd, 2006
    2012 Honda HRX217, 2 Golfs, and a 944.
    12-19-2010 10:39 PM #38
    Quote Originally Posted by czykvw View Post
    I guesss these came stock like this in europe?
    Yes.
    I love all cars, I just happen to own a few pieces of german crap at the moment.
  4. Member Bryan S's Avatar
    Aug 28th, 2000
    EWR ORH
    2004 R32 | 2007 Frontier
    12-19-2010 10:44 PM #39
    Quote Originally Posted by josh_did_what View Post
    Can someone name those wheels?
    Borbet Type E
  5. Member josh_did_what's Avatar
    Apr 16th, 2009
    poughkeepsie ny
    03 civic si
    12-19-2010 10:45 PM #40
    Thankee sir
  6. Member under the radar's Avatar
    Mar 5th, 2007
    NOR-CAL COASTSIDE
    disco, new wave, rave era german iron...and a Japanese V8 with a tailgate
    12-19-2010 10:48 PM #41
    this thread is filled with poop.
    Quote Originally Posted by spoon! View Post
    I'll go if Paul goes.
    Rod Blagojevich - Team My Little Pony
  7. Member BattleRabbit's Avatar
    Jun 28th, 2007
    Albany, NY
    DKW Munga
    12-19-2010 10:50 PM #42
    Quote Originally Posted by Noisyninja View Post
    I like it, but it's unfortunate the 92-X's front fenders don't match the WRX/Impreza Sedan's rear fenders.
    All GD sedans have the larger boxed front and rear fenders, but all GD wagons (and the wagon-only 92-X) have narrow ones.
    Dare I say that could look really cool with a mildly staggered wheel set?
    1998 VW Golf Mk.III 5dr/1960 Porsche 356B T5/1980 Honda CM400E
    "I drive an '81 Jetta with a Scirocco engine, Rabbit front fenders and multi-colored doors. There's a spiderweb fracture in the driver's side windshield, and a dented bumper sticker that says 'praised are the lowered'"
  8. Member SgtArky's Avatar
    Aug 19th, 2009
    Benton, Arkansas
    12-19-2010 10:57 PM #43
    Quote Originally Posted by freedomperiod View Post
    1973 Carrera front end on a Porsche 964 Carrera 4 (AWD)
    http://bringatrailer.com/2007/08/05/...sr-conversion/
    you know I wouldnt know the difference.
  9. Member SgtArky's Avatar
    Aug 19th, 2009
    Benton, Arkansas
    12-19-2010 11:03 PM #44
    I cant find any pics of it but I think it was in Road and track. 1980 Mustang with a 280 Mercedes front end and I think think it had the Mercedes turbo diesel in it.
  10. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    12-19-2010 11:09 PM #45
    Yes they did, and yes I'd love to build an SRT version
  11. 12-19-2010 11:10 PM #46
    Mmmm lsx
  12. Member Biff Beltsander's Avatar
    Jul 14th, 2010
    Winnipeg Manitoba Canada
    Satanizer
    12-19-2010 11:28 PM #47
    the qx56 frontend looks alot better on the titan, already posted but this is much better.[/QUOTE]
    That does look good, get some QX rims and that would really round out the look.
  13. Member Noisyninja's Avatar
    Nov 19th, 2003
    Wilton, CT
    2013 Jeep Wrangler Rubicon
    12-19-2010 11:32 PM #48
    Quote Originally Posted by BattleRabbit View Post
    I guess as long as you made sure you had the same rolling diameter on the front and rear tires? Isn't it possible to damage your diffs otherwise? I can't really recall seeing any staggered Subarus that hadn't been converted to RWD.
    I know most manufacturers say to always use the same size wheels and tires on all 4 corners.
  14. Member Noisyninja's Avatar
    Nov 19th, 2003
    Wilton, CT
    12-19-2010 11:35 PM #49
    Quote Originally Posted by Mixican View Post
    I wanted to post one of these but I forgot the company that did them. Dream Factory Blow.
    http://www.blow-net.co.jp/
  15. 12-19-2010 11:36 PM #50
    Dream Factory Blow
  16. Member Noisyninja's Avatar
    Nov 19th, 2003
    Wilton, CT
    12-19-2010 11:42 PM #51
    Dream Factory Blow
    I wish they had a front end conversion for the Cube. I don't think I saw any vehicles on the site that are actually for sale in the US.
    Actually, after looking at the Cube again I don't think it could pull it off. The rear end has the round protrusion. I think part of the reason it works on those Suzukis are because the rear ends are squared off.
  17. Member BattleRabbit's Avatar
    Jun 28th, 2007
    Albany, NY
    DKW Munga
    12-19-2010 11:59 PM #52
    I meant like wider out back than in front, not different diameters.
  18. Member Noisyninja's Avatar
    Nov 19th, 2003
    Wilton, CT
    12-20-2010 12:43 AM #53
    No, I know. But a wider tire with same aspect ratio as a thinner tire will have a larger rolling diameter and circumference.
    Using this calculator: http://www.miata.net/garage/tirecalc.html
    235/40-18: 25.4/79.8
    245/40-18: 25.7/80.8
    Now, if you went instead with a 245/35-18 in the rear you have 24.8/77.8.
    I don't know what the acceptable threshold is, but the difference may put unnecessary strain on the diffs especially with a Subaru that has a 50/50 front/rear power split.
    Also, add in the fact that the fronts and rears won't wear evenly which could exacerbate the problem and you wouldn't be able to rotate the tires regularly which you would normally do with an AWD car to address uneven wear.
  19. Member GrkPranksta69's Avatar
    Jan 10th, 2009
    North Carolina
    2007 VW Jetta, 1973 Pontiac Trans Am 455 SD
    12-20-2010 01:10 AM #54
    Here's one; MKV front on MKIII Cabrio
    Quote Originally Posted by Mr Miyagi View Post
    And, if the situation calls for it, you could break out some drumsticks and play the xylophone on her ribs
    God dammit Miyagi, go to school. Who the f**k plays the xylophone with drumsticks?
    You use mallets. Idiot.
  20. Member saranynsandiego's Avatar
    Jan 3rd, 2007
    San Diego, CA
    94 Supercar
    12-20-2010 01:47 AM #55
    i would totally rock this all day
    Quote Originally Posted by Turbiodiesel! View Post
    Would that be under the "three chirps and you're out" policy?
  21. Member josh_did_what's Avatar
    Apr 16th, 2009
    poughkeepsie ny
    03 civic si
    12-20-2010 01:49 AM #56
    Quote Originally Posted by GrkPranksta69 View Post
    God damn thats ugly... but very impressive.
  22. Member Dieselstation's Avatar
    May 15th, 2001
    Southern California
    2006 Acura TSX
    12-20-2010 03:24 AM #57
  23. Member mellbergVWfan's Avatar
    Jan 31st, 2008
    Los Angeles, CA
    81 Scirocco S
    12-20-2010 04:35 AM #58
    Buy my Type A's Or sell me your exhaust
  24. Member nm+'s Avatar
    Jan 6th, 2006
    Land of Bro-Dozer Ya Yas
    12-20-2010 04:41 AM #59
    Ok, I like this.
    This was actually said
  25. Member
    Aug 25th, 2005
    Praha
    2004 RX-8
    12-20-2010 05:00 AM #60
    yea, this is pretty baller!
    Quote Originally Posted by SuperGroove View Post
    "...you see an RX-8 has a rotary engine! Do you know what a rotary engine is? Well, the reason why I'm filling oil into my engine is...hello? where'd you go? It's injected into the combustion chamber and it LUBRICATES THE SEALS! IT LUBRICATES THE SEAAAAAAAAAAAAAAAAAAAAAAAALS"
  26. Member Shifty's Avatar
    Mar 25th, 2004
    Oklahoma City Metro
    '01 Jetta 16v(!), '09 CC VR6, 1998 Suburban Command Center, '01 Triumph TT Warbird
    12-20-2010 08:45 AM #61
    This thread is like a visit to a laboratory for biological experiments on humans and cuddly animals... lots of terrible looking, sometimes sacrilegious, yet strangely compelling creations...
  27. Member McBanagon's Avatar
    Feb 24th, 2010
    Northern part of the Virginia
    Two Vanagons and some old British iron.
    12-20-2010 08:55 AM #62
  28. Member BluMagic's Avatar
    Apr 9th, 2008
    snohomish, WA
    2011 Genesis 3.8 R-spec
    12-20-2010 10:13 AM #63
    front end conversions give me flashbacks to 1999
    i kinda like the USDM integra bumper on the EG and Del Sol (when the panels actually line up though)... moreso the del sol.
    He did this at 22 old. He is world strongest man. President Obama ordered him to stop but truth must come out. Buy silver in middle of week.
  29. Member Chris_V's Avatar
    Jun 18th, 2009
    Pikesville, MD
    2013 Chevy Volt, 2011 Mini Cooper, '94 GM3500 dually
    12-20-2010 10:18 AM #64
    Wish I could find the pictures, but I used to have a Mk1 Jetta with a Mk1 cabrio round headlight nose conversion. Looked really good.
    Some other interesting nosejobs, these are all on El Caminos:
    I love cars, but the problem is they are like schroedinger's hobby. They're always in a quantum superstate of being both awesome and a huge waste of time and money... until observation momentarily forces them into one state or another.
  30. Member mellbergVWfan's Avatar
    Jan 31st, 2008
    Los Angeles, CA
    81 Scirocco S
    12-20-2010 10:26 AM #65
    Seeing those reminds me. I've seen an old guy around town driving an El Camino with a Third Gen Camaro Front and the Corvette light-style rear bumper. He's got some badges that say 'El Camaro' . I'll try to snap some pics next time I see it.
  31. Member grounded87's Avatar
    Nov 5th, 2002
    Grand Rapids, MI
    '99.5 TDI Golf 2dr / '08 Volvo V50 T5 / '81 Rabbit Truck
    12-20-2010 10:28 AM #66
    This trucks' not done yet, this is an older '01 Excursion with the newer Superduty front end on it. I think it looks pretty tough considering the size and lines of those trucks anyways.
    -Nick V
  32. Member WiseDubbinVR's Avatar
    Jan 13th, 2006
    Vienna, VA
    2008 A3 2.0T S-Line, RS .:R32 (sold)
    12-20-2010 10:44 AM #67
    for creativity
    for execution
  33. Member bizybyker's Avatar
    May 25th, 2005
    Steelcity, Pennsyltucky
    20th GTI, B3000 4x4, 06 Night Rod
    12-20-2010 10:54 AM #68
    Bob and frank...
    You Won't do it...
  34. Senior Member patrikman's Avatar
    May 10th, 2008
    La Baie des Puants
    beater with a heater
    12-20-2010 11:54 AM #69
    Quote Originally Posted by mellbergVWfan View Post
    That isn't a swap, it's OEM. Aston Martin Cygnet.
    Bring back BLB and ban BHB!
  35. Member mellbergVWfan's Avatar
    Jan 31st, 2008
    Los Angeles, CA
    81 Scirocco S
    12-20-2010 12:07 PM #70
    I know that. But it's based on the Toyota iQ which makes it a swap.
