VWVortex.com - Anyone else like crazy front end conversions?
    The Car Lounge
    Page 4 of 10 FirstFirst 12345678 ... LastLast
    Results 76 to 100 of 232
    Thread: Anyone else like crazy front end conversions?
    1. Member PizzaCat!'s Avatar
      Dec 2nd, 2006
      Near McBanagon
      I used to drive a Rabbit5GTI or something. May also own a NATO Sand Jeep.
      12-20-2010 04:08 PM #76
      Quote Originally Posted by Chris_V View Post
      So we can blame all the MkIV guys on you
      Seriously, though - that looked good
      Own a Chevrolet SS? Join the Official TCL Registry!
      It's me, Rabbit, I promise.
      Quote Originally Posted by Vee-Dubber-GLI View Post
      NATORabbitCat5PizzaSand
    2. Member Chris_V's Avatar
      Jun 18th, 2009
      Pikesville, MD
      '01 BMW 740i Sport, '05 330ci ZHP, '02 Suburban 2500LT
      12-20-2010 04:37 PM #77
      Quote Originally Posted by Rabbit5GTI View Post
      Hahaha! yeah, I was doing it way before they were. Best part was that since teh rabbit I got the fenders and core support from was silver, I didn't have to paint it after welding and re-assembly, so it really was a weekend project. Wouldn't mind another one of those, but they are harder to find over here.
      "Like a fine Detroit wine, this vehicle has aged to budgetary perfection"
    3. Member PizzaCat!'s Avatar
      Dec 2nd, 2006
      Near McBanagon
      12-20-2010 04:39 PM #78
      Harder to find is an understatement. I can't remember the last time I saw a MkI Jetta in decent condition.
    4. Member Burnitwithfire's Avatar
      May 14th, 2005
      Quebec, Canada
      2005 Legacy GT LTD 1992 Miata sunburst yellow
      12-20-2010 04:42 PM #79
      Quote Originally Posted by digiddy View Post
      That is sweet!! What kit is it?
      Quote Originally Posted by SAV912 View Post
      Going to church is bland. Eating vanilla ice cream is bland. Dating somebody from your local Ayn Rand book club is bland. This car makes all of those things seem as exciting as doing 12 lines of cocaine. With Katie Perry. While she's on fire...in Times Square. And you're naked.
    5. Member Der Roboter's Avatar
      Mar 9th, 2010
      Portland, Or.
      '88 GTI 12v + '85 GTI 8v + '04 Passat Wagon 1.8T + '03 Escort ZX2
      12-20-2010 04:53 PM #80
      Quote Originally Posted by Noisyninja View Post
      I guess as long as you made sure you had the same rolling diameter on the front and rear tires? Isn't it possible to damage your diffs otherwise? I can't really recall seeing any staggered Subarus that hadn't been converted to RWD.
      I know most manufacturers say to always use the same size wheels and tires on all 4 corners.
      Quote Originally Posted by BattleRabbit View Post
      I meant like wider out back than in front, not different diameters.
      No, I know. But a wider tire with same aspect ratio as a thinner tire will have a larger rolling diameter and circumference.
      Using this calculator: http://www.miata.net/garage/tirecalc.html
      235/40-18: 25.4/79.8
      245/40-18: 25.7/80.8
      Now, if you went instead with a 245/35-18 in the rear you have 24.8/77.8.
      I don't know what the acceptable threshold is, but the difference may put unnecessary strain on the diffs especially with a Subaru that has a 50/50 front/rear power split.
      Also, add in the fact that the fronts and rears won't wear evenly which could exacerbate the problem and you wouldn't be able to rotate the tires regularly which you would normally do with an AWD car to address uneven wear.
      You could go much simpler then that and just run different offset wheels with the same size wheel barrels and tires. Gives the same appearance as a true staggered setup without the fear of blowing up drive train components. no lip for the front wheels and lots for the rears
      Bonneville 130mph club - PIR perfect(0.00) light club
    6. Member Cort's Avatar
      Aug 18th, 2004
      Austin, TX
      1985 GTi VR6'ed 1973 Mercedes Benz 280 SEL 1990 16v GLi
      12-20-2010 05:00 PM #81
      RS4 front end swap.
    7. Member CSFiend's Avatar
      Jan 13th, 2007
      Minneapolis, MN
      02 Passat, 1/3 of a 2.5rs rally car
      12-20-2010 05:13 PM #82
      Quote Originally Posted by Cort View Post
      RS4 front end swap.
      sexy.
    8. Member Der Roboter's Avatar
      Mar 9th, 2010
      Portland, Or.
      12-20-2010 05:56 PM #83
      RS4 front end swap.
      and a good example of staggered offset wheels with the same width on an awd car
      Aug 25th, 2005
      Praha
      2004 RX-8
      12-21-2010 03:39 AM #84
      MK4 JTIs loo the best with votex kit:
      and this really makes me think mk6 jetta:
      Quote Originally Posted by wolfcastle View Post
      Who cares if im wrong, its the internet.
    10. Banned
      Feb 22nd, 2010
      Orlando, FL
      2006 Rx-8
      12-21-2010 03:43 AM #85
      RS4 front end swap.
      Exhibit A: Hubris
    11. Member
      Nov 19th, 2003
      Fancy CT
      2016 4Runner SR5P
      12-21-2010 04:35 AM #86
      Quote Originally Posted by Der Roboter View Post
      That is much simpler. Now I feel stupid. Thanks.
    12. Member jettagli1991's Avatar
      Sep 4th, 2002
      Orchard Park, NY
      '91 Jetta GLI, '68 Beetle 'vert, '65 Rambler Classic, '08 Outback
      12-21-2010 05:11 AM #87
    13. Member LA7VJetta's Avatar
      Jul 21st, 2009
      1985 Mercedes 190D
      12-21-2010 08:41 AM #88
      I dont think that counts.
    14. Member PizzaCat!'s Avatar
      Dec 2nd, 2006
      Near McBanagon
      12-21-2010 08:48 AM #89
      Quote Originally Posted by LA7VJetta View Post
      If that doesn't count, then neither do all the MkIV conversions posted.
    15. Member LA7VJetta's Avatar
      Jul 21st, 2009
      1985 Mercedes 190D
      12-21-2010 08:57 AM #90
      it is just a Jeep pickup, no? other than the grill being chrome on the one, I see nothing different.
    16. Member PizzaCat!'s Avatar
      Dec 2nd, 2006
      Near McBanagon
      12-21-2010 08:58 AM #91
      It's the facelifted grille from the late 90's Cherokee on a mid-80's Comanche. I think it counts.
      The first one even converted the side mirrors and it looks like there was some interior conversion done from what I can tell in that picture.
    17. Member WiseDubbinVR's Avatar
      Jan 13th, 2006
      NoVa
      2008 Sprint Blue A3 S-line // 2004 Reflex Silver .:R32 (sold)
      12-21-2010 09:24 AM #92
      RS4 front end swap.
      This thing looks so mean in person
    18. Member yellow20th1804's Avatar
      Sep 27th, 2009
      New Tripoli PA
      20th AE JTI multi colored sh!tbox, 01 Bitch Basket, 06 Toaster, 09 Triumph Daytona 675
      12-21-2010 10:12 AM #93
      Theres a much nicer example i seen on vortex before but i cant find it edit: it was white im pretty sure, someone has to have it
      1804
      Quote Originally Posted by olltray View Post
      The 1.8T started to lose once, it got so mad it wiped out the dinosaurs.
      Seriously, don't **** with that engine.
    19. Member PizzaCat!'s Avatar
      Dec 2nd, 2006
      Near McBanagon
      12-21-2010 10:14 AM #94
      Quote Originally Posted by yellow20th1804 View Post
      What has been seen, cannot be unseen.
    20. Geriatric Member AKADriver's Avatar
      Nov 20th, 2001
      Unreal VA
      '12 Mazda2, '09 Forester
      12-21-2010 10:17 AM #95
      Quote Originally Posted by Burnitwithfire View Post
      Pitcrew. I believe it's way out of production.
      I don't practice llanteria
    21. Member Cort's Avatar
      Aug 18th, 2004
      Austin, TX
      12-21-2010 10:30 AM #96
      Quote Originally Posted by NeezDuts View Post
      Exhibit A: Hubris
      Some say I'm cocky, and I say what? It ain't braggin' if you do it and you back it up.
      Quote Originally Posted by CSFiend View Post
      sexy.
      Thank you. She's not mine anymore.
      Quote Originally Posted by WiseDubbinVR View Post
      Thanks.
      Thank you, it's all about your overall diameter. As long as you drop down in side profile when you go wider you're fine.
    22. 12-21-2010 10:47 AM #97
      Quote Originally Posted by mellbergVWfan View Post
      I know that. But it's based on the Toyota iQ which makes it a swap.
      Facepalm
      It's not a swap it's called rebadging. A Mercury Mountaineer is a Ford Explorer, it's not a different platform with swapped cosmetics
    23. Banned
      Jul 30th, 2004
      Fancy in the Not fancy, CT
      12-21-2010 10:52 AM #98
      I loved my RS4 Bumper on my Passat....unfortunately Figerglass and paint quality blew. What a nightmare.
    24. Member simon_C's Avatar
      Oct 4th, 2006
      SFBAY 95110
      1991 Golf GL (Retired), 1992 Mx-5
      12-21-2010 12:34 PM #99
      Quote Originally Posted by VdubChaos View Post
      i hardly think a body kit counts as a front end swap.
      How does a rotary work? This one's easy: the magic triangle spins in the peanut and then apex seals come out.
      Fresh Miata Convert
    25. Geriatric Member PSU's Avatar
      May 15th, 2004
      Pennsylvania
      '08 R32 | '15 GTI
      12-21-2010 12:43 PM #100
      Acura El.
      Not a huge fan of that car, per se, but the swap is nice.
