VWVortex.com - 1996 jetta crank no start
    Results 1 to 4 of 4
    Thread: 1996 jetta crank no start
    1. Member TURBOCADDY's Avatar
      Jan 17th, 2002
      COVINGTON, WASHINGTON
      VW
      12-21-2010 04:10 PM #1
      i have a 1996 2.0 aba 8v
      the vag com codes
      0075 warning lamp
      16795 secondary injection pump
      16684 random cyl misfire
      16685 cyl 1 misfire detected
      16687 cyl 3 misfire detected
      the car was running fine went into the store came out and no start issue.
      i have checked the coil and it will crank and deliver 1 spark and nothing else
      the injectors and fuel pump check out ok
      i have also used a spare coil and a spare distributor to help diagnose the spark issue with the same 1 spark then nothing else
      where else should i look ?
    2. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      1992 Corrado ABA-T and MS3-Pro powered, 84 Honda V65 Sabre
      12-21-2010 04:23 PM #2
      Try the search function next time, but look at your crank position sensor.
      The Professor
      Melbourne, FL
      92 Corrado OBD2 ABA-T (BW EFR 6258) Powered by MS3Pro
      Linfert Performance: The Megasquirt guy in central Florida Like my Facebook page....
      Sandy Linfert 11/4/1991 - 5/13/2013
    3. Member TURBOCADDY's Avatar
      Jan 17th, 2002
      VW
      12-21-2010 04:37 PM #3
      i don't have money to throw parts at the car ..
      would vag-com throw a code for the crank sensor if that was the issue ?
      i searched and did not see any post showing my symptoms
      i see 1 spark from the straight off the coil but no signal to the spark plug
      when a crank position sensor is bad would it die over a long time or die immediately ?
    4. Member TURBOCADDY's Avatar
      Jan 17th, 2002
      VW
      12-22-2010 09:03 PM #4
      i threw in a new crank position sensor and still the same issue
      i did check power at the coil connector and the multimeter read 12.8v key on power and 5v during cranking
      anyone else have the same issue?
