VWVortex.com - Glow Plug Fuse Help mk2
    Results 1 to 9 of 9
    Thread: Glow Plug Fuse Help mk2
    1. Member VolkswagenJon's Avatar
      Nov 30th, 2010
      Ocean View, De
      1985 VW Golf
      12-21-2010 09:33 PM #1
      So I'm trying to trouble shoot why my 85 Golf and why it won't start. I'm having trouble finding the Glow Plug fuse. I've looked in the engine bay and I don't see it. I've also checked on the interior firewall. Will some point me in the right direction.
      Car in subject
      Southern Delaware Volkswagens
    2. 12-21-2010 09:41 PM #2
      Glow plug system troubleshooting info, with pictures of the glow plug fuse, here:
      http://vincewaldon.com/index.php?opt...d=41&Itemid=28
      Vince Waldon
      Edmonton Alberta Canada
      2001 silver TDI Jetta, .205s and Malone Stage 1.5
      2001 blue TDI Jetta, .216s, SB III, and Malone Stage 3. grrrr baby...very grrrrrrr ;-)
    3. Member VolkswagenJon's Avatar
      Nov 30th, 2010
      Ocean View, De
      1985 VW Golf
      12-21-2010 09:51 PM #3
      Quote Originally Posted by Vincent Waldon View Post
      There is no fuse on the firewall
    4. Member VolkswagenJon's Avatar
      Nov 30th, 2010
      Ocean View, De
      1985 VW Golf
      12-21-2010 09:57 PM #4
      And here is the fuse block
    5. 12-21-2010 10:55 PM #5
      Where does the thick red wire on the right end side of the copper glow plug buss bar lead to?
      Vince Waldon
    6. Member VolkswagenJon's Avatar
      Nov 30th, 2010
      Ocean View, De
      1985 VW Golf
      12-21-2010 11:12 PM #6
      The only thick red wires I have is to the starter and from the alt. to the battery.
    7. 12-21-2010 11:48 PM #7
      The buss bar has to be getting power from somewhere... there will be one or more wires, usually red with a white strip, at the end of the buss bar. Where do they go?
      While you're at it... regardless of the fuse you can start troubleshooting by checking for power at the buss bar itself.
      Vince Waldon
    8. Member VolkswagenJon's Avatar
      Nov 30th, 2010
      Ocean View, De
      1985 VW Golf
      12-22-2010 10:32 PM #8
      so is this the GP fuse?
      Jan 2nd, 2005
      Alabama
      85 Golf, 89 Jetta
      12-23-2010 12:09 AM #9
      That is the glow plug fuse in with the relays. Be sure to check/clean the connections and fuse for corrosion. I had corrosion prevent voltage getting to glow plugs with a good fuse on my 85 Golf.
    « Back
