bump it
#1
ok guys i really need some help for the past few weeks ive had this code and my EPC light would come on when i make sharp left or right hand turns (getting on/off highways or turning into my driveway) it basically makes the car have no boost capabilities at all! so i would just turn the car off/on again and it would be fine! I have replaced the following and just need some help with stuff!
Replace:
Throttle Body
Gas Pedal (it was a 02 vr6 pedal) would this make a diff if my car is a 1.8t??
ever since i replaced the pedal the other day the epc light stays on and i cant drive the car. I did some scanning with my Eurodyne software on the blocks sections like vag com has and im using the measuring blocks now to look at something im on the 60-69 blocks
http://www.ross-tech.com/vag-com/m_blocks/060-069.html
can anyone tell me what the % should be on 62 across the board and on measuring block 63 i get error on 3 of them on block 63 and im not sure what else to do any help would be great and below are car specs
2001 1.8t
5speed
Big turbo Maffless witch means the maff is not there nore plugged in!!!
#3
Please post an Auto-Scan from this vehicle and the part number from the used accelerator pedal.
#4
Thursday,03,February,2011,12:13:06:22328
VCDS Version: Release 10.6.3
Data version: 20101206
Mode 03: Emission related fault codes
Address 10 (Engine): 1 Fault Found:
P2138 - Accelerator Position Sensors (G79) / (G185): Implausible Correlation
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 224360km/139410miles
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Part No: 06A 906 032 HR
Component: 1.8L R4/5VT G 0007
Coding: 07500
Shop #: WSC 79667
VCID: 75FF31EA6547
XXXXXXXXXXXXXXXXX XXXXXXXXXXXXXX
1 Fault Found:
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13204
Shop #: WSC 00066
VCID: 75FF31EA6547
3 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-00 - -
16-10 - Signal Outside Specifications - Intermittent
04-10 - Mechanical Malfunction - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 15 AIRBAG VW5 02 0004
Coding: 12597
Shop #: WSC 00066
VCID: 357FF1EA25C7
3 Faults Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-00 - Resistance too High
01218 - Side Airbag Igniter; Passenger Side (N200)
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 900 J
Component: A4-KOMBIINSTR. VDO V63
Coding: 07242
Shop #: WSC 09016
VCID: 29472D9AF97F
Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2680557
IMMO-IDENTNR: VWZ7Z0Y2680557
No fault code found.
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: F0F180FE9A25
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
VCID: 861DC62688A1
Part No: 1J1959801C
Component: 61 Tõrsteuerger. FS0002r
Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002B
Part No: 1J4959811C
Component: 61 Tõrsteuerger. HL0002r
Part No: 1J4959812C
Component: 61 Tõrsteuerger. HR0002r
2 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
End ---------------------------------------------------------------------
Specializing in Powder Coating and VW/Audi Performance and Maintenance
VAGWERKS PERFORMANCE AND COATING
-Powder Coating -Air Ride Installs - Frame Notches - Coilover Installs - Engine Performance- You name it we will do it, From full swaps to oil changes
#5
#6
Look in Measuring Block 062, not 063. The values in fields 3 and 4 should move inversely to each other as you move the pedal.
The 18047 can only be due to one of three things: 1) Bad or incompatible pedal assembly. 2) Wiring problem between pedal and ECU. 3) Bad ECU.
-Uwe-
VCDS® -- Satisfaction guaranteed or double your fault codes back!
I reserve the right to be a prick if people make unreasonable demands.
#7
#8
If you find no issues with the throttle pedal and it's wiring, then humor me and VERY CAREFULLY inspect the O2 sensors and their wiring harness.
It seems that O2 sensors share a circuit inside the ECM that the throttle pedal also uses. I've seen where screwy (or burnt) O2 sensors cause all kinds of problems but not flag a fault for the O2 sensors.
A failed throttle pedal is very rare... not impossible, but rare.
#9
I agree and was thinking the same thing with the "sharp left or right hand turns" description. If wiring is shorting in the o2s area that may explain the initial comment/concern.
If that's the case it needs resolved ASAP so the Ecm isn't damaged.
#10
Thanks to the both of you for your response and as soon as i get on this i will get back with an update!
#11
ok ive replaced 02 sensor deleted all my codes now im looking at block 62 fields 3 and 4
field 3 reads a constant 17.57813 and when i hit gas pedal it moves
field 4 reads a constant 10.9375 and when i hit the gas pedal it also moves
another thing that is weired is my idle is high and idles at like 1100 its been doing this ever since the light issue i also have a bad front abs sensor i just ordered a new one you think that could be a problem with something vaccum seams to be fine sit right at about 21-22 vaccum
#12
Hello
The ABS is most likely not related.
Open the harness distribution black box in drivers side hood cal area. Check all the connectors specifically the blue one.
let me know what you find.
Best,
Jack
#13
#14
Okay, now that you have looked, verify each wire back to the ecu one at a time measuring the resistance at the halfway point as per the repair manual.
Look closer, I bet you over looked something, usually you can see something.
Verify the grounds real good too.
Jack
#15
#16
Do another inspection of the harness visual because most of the time you will see something.
Not hiding anything.
You may need an ecu. You sure don't wanna fry a new one, do ya?
Jack
#17
