VWVortex.com - HowTo: OEM Bi-Xenon/OEM Fog Lights/CECM Upgrade/LED Euro Tails in a 2010 Jetta Sedan
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 31
    Thread: HowTo: OEM Bi-Xenon/OEM Fog Lights/CECM Upgrade/LED Euro Tails in a 2010 Jetta Sedan
    1. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      '15 S3, '91 200 20v, '91 200 20v Avant
      12-29-2010 12:59 AM #1
      For those who may be interested in what is involved in upgrading their 2010 Jetta TDI Sedan (DSG in my case) to OEM Bi-Xenons, OEM Fog lights (controlled by the CECM), CECM Upgrade, and European Hella LED Tail lights with rear fog light this is my write up. Please let me know if you find anything out of place and I'll modify it.
      Link to PDF: http://njsphoto.com/doctemp/Bi-Xenon%20Upgrade.pdf
      Hope this helps!
      Nick
      2015 S3 - Sepang/MAG/Advanced Tech
      1991 200 20v
      1991 200 20v Avant
      YouTube
      MQB Audi S3 Facebook Group
    2. Member TXRanger83's Avatar
      Nov 8th, 2009
      Midland, TX
      2016 MKVII Golf GTI
      12-29-2010 03:41 AM #2
      Nice write up! I look forward to doing this in the future
      2016 GTI Pure White | Autobahn | PP | DAP | LP | 6 Speed | LED Tails | EU Siren | EU Power Side Mirrors | VCDS |
    3. Member StreamlineGT's Avatar
      Nov 5th, 2008
      Central CT
      Some Fords, a GMC, and a ???????.
      12-29-2010 08:55 AM #3
      I look forward to this as well. No chance my 2010 TDI has a high line CECM already, huh? I guess I don't really understand the differences.
    4. Member b0mb3r's Avatar
      Nov 9th, 2006
      Bear DE
      2012 A4; 2010 TDI
      12-29-2010 09:13 AM #4
      awesome thanks...i thought that the 2010 TDI already came with the highline CECM
    5. Member wolfsburg__gli's Avatar
      Feb 24th, 2009
      Orlando, FL
      2009 Jetta Wolfsburg 2.0T - 84' Mercedes 300SD - 87' BMW 535iS - 1967 Chevrolet C10 - 1992 GLI
      12-29-2010 10:19 AM #5
      question....i didnt read the whole thing and i probably would have , but the oem hid retrofit was w/ or w/o the auto levelers...
      Double Down Garage
      IG @dirty.mikee
      I VAG-COM IN ORLANDO PM ME
    6. Member
      Feb 17th, 2010
      Columbus, Ohio
      2010 Wolfsburg
      12-29-2010 12:48 PM #6
      This is awesome - It was always a pain to find info on the Bi-Xenon swap. The MKVI electronics in the 2010 Jetta throws a wrench in everything...
      Question - Do you are anyone else have any idea if the Wolfsburg's require a CECM swap as well?
      Feb 17th, 2010
      Columbus, Ohio
      2010 Wolfsburg
      12-29-2010 12:56 PM #7
      For step 15.b.ii the byte to change is not defined, there is just a yellow highlight, like maybe you meant to fill that in later. Is that right?
      Feb 17th, 2010
      Columbus, Ohio
      2010 Wolfsburg
      12-29-2010 01:02 PM #8
      Also - how did you locate the proper CECM?
      I guess what I'm mainly wondering is if the CECM is exclusive to the MKVI electronics, or if a MKV will work as well (are they the same?)
    9. Member TXRanger83's Avatar
      Nov 8th, 2009
      Midland, TX
      2016 MKVII Golf GTI
      12-29-2010 03:05 PM #9
      Quote Originally Posted by Comatose View Post
      You can either go down and pull out the CECM to find the part # or do an auto scan with VCDS which will also give you the part number. I have yet to come across any 2010 sedan with a highline CECM, due to no GLI being built, so its a good guess you have a low line. If your CECM ends in 085 its lowline, what you need is the part # that ends in 087.
      Also a mkV CECM will not work because we have an integrated CECM/CCU while all other mkV had two separate controllers.
    10. Member
      Feb 17th, 2010
      Columbus, Ohio
      2010 Wolfsburg
      12-29-2010 03:16 PM #10
      Quote Originally Posted by TXRanger83 View Post
      Dang it - Mine ends in 085, so looks like mine isnt special.
      Thanks for your info - Very helpful!
    11. Member
      Feb 17th, 2010
      Columbus, Ohio
      2010 Wolfsburg
      12-29-2010 04:26 PM #11
      That CECM seems to be pretty difficult to find - not too many MKVI Highline CECM's floating around...
      OP - how did you find yours?
    12. Member StreamlineGT's Avatar
      Nov 5th, 2008
      Central CT
      12-29-2010 04:31 PM #12
      Balls, mine is a lowline also.
    13. 12-30-2010 10:43 AM #13
      wow that is a pretty big project, thanks very much for going through the time to provide the write-up
    14. Member 83Caddy16v's Avatar
      Jul 31st, 2000
      NoVA
      '13 JKU Sahara
      12-30-2010 11:39 AM #14
      Would the TDI Cup Jetta have the highline CECM?
      chris@swedespeed.com
      2012 XC90 R-Design | Ice White | 20" Cratus wheels | RSE
      2015.5 V60 R-Design | Rebel Blue | Platinum | BLIS | Climate | KW V3s | KPAX exhaust
      Previous: '10 Touraeg TDI : '07 GTI : '98 Jetta TDI : '83 Caddy 16v : '84 GTI 16v : '91 GLI : '01 S4 Avant : '00 S4
    15. Member
      Feb 17th, 2010
      Columbus, Ohio
      2010 Wolfsburg
      12-30-2010 11:58 AM #15
      Quote Originally Posted by 83Caddy16v View Post
      Hopefully someone has posted a scan of theirs in the forums somewhere to confirm, but I would think not
    16. Junior Member
      Feb 10th, 2011
      South Jersey
      2010 Jetta WE 2.0T FSI DSG; 2015 Sportwagen TDI/DSG
      02-16-2011 09:27 PM #16
      Great write up.
      Just one advice. As far as setting up TPMS. 24 psi this threshold is way too low. For example my Jetta WE requires 35 psi front and rear so you want to keep tire pressure within 10% margin of error which is 3.5 psi. So in this example low pressure threshold should be set to 31 psi. 24-30 psi will cause an excessive tire wear!
    17. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      02-16-2011 09:56 PM #17
      Quote Originally Posted by WhiteWolfie10 View Post
      Great write up.
      It's in bar... 2.4 bar = 34.8psi. Thanks for looking out though.
      1991 200 20v
      1991 200 20v Avant
      YouTube
    18. Junior Member
      Feb 10th, 2011
      South Jersey
      02-17-2011 06:05 PM #18
      My bet sorry. Didn't pay attention.
    19. Member keving's Avatar
      Jun 25th, 2005
      Spring Hill, FL
      '95 Golf GL, '99 Golf Wolfburg, '10 Jetta TDI
      04-20-2011 07:13 PM #19
      You are my hero!
      So glad I finally found this. I've been pulling my hair out trying to figure out how to add front & rear fogs to my mkV with mkvi electronics!
      If I make it New York, I'm buying you a beer! Hell, how about the entire bar?
    20. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      04-22-2011 11:39 PM #20
      Quote Originally Posted by keving View Post
      You are my hero!
      Haha, sounds good man! Glad it helped you out!
      1991 200 20v
      1991 200 20v Avant
      YouTube
    21. Member keving's Avatar
      Jun 25th, 2005
      Spring Hill, FL
      04-28-2011 05:34 PM #21
      Epic fail.
      Fogs don't work. I followed everything verbatim.
      Supposedly I didn't need to switch out the CECM.
      Part number from VCDS - 5K0 937 085 G
      I was told that if the computer accepts the codes, then I'm okay.
      It accepts fog lights in the computer and throws a light bulb out for both front and left fogs. I counted and thought the pins were missing from the CECM. I'm probably right about that.
      I'll recheck the pins for the right numbers, recheck the ground, and recheck the trigger wire.
      The dealership has no idea what I want. The part number you have for the highline supersedes the system four times over. And they don't believe me that my mkv has the mkvi wire harness.
      This is madness. I'm completely lost! Any ideas? Can you help?
    22. Member keving's Avatar
      Jun 25th, 2005
      Spring Hill, FL
      04-28-2011 05:36 PM #22
      Is this true?
      "Asked ross tech about it today, 084 is base, 085 is low 086 mid and 087 is highline, according, quite funny, I just asked ross tech about it today, 084 is base, 085 is low 086 mid and 087."
    23. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      04-28-2011 07:06 PM #23
      Your 085 module is a low line and is NOT capable of running fog lights. The pins are not present (they weren't in my L anyway) yet the CECM can accept the coding which will also create the faults. Double check and make sure there are actually pins there and also that you are on the correct ones.
      Your car certainly has a MK6 CECM (part number matches mine) and it is 100% low line. The part number that I used in my car has been superseded several times but I know that mine works and I really can't comment on if the newer ones will (although I would believe that they should). Try to get a hold of the one I have but even so, I think so far I am the only one who has successful got EVERYTHING to work without errors even with the same exact setup.
      084 - never heard of it...
      085 - low
      086 - mid
      087 - high
      1991 200 20v
      1991 200 20v Avant
      YouTube
    24. Member keving's Avatar
      Jun 25th, 2005
      Spring Hill, FL
      04-28-2011 08:57 PM #24
      Okay, so it's confirmed I am lowline. That's a start.
      I'll double check everything tomorrow when I have light. We'll see from there.
      Next question, where did you pick up the highline? The parts guy at the dealership practically had a panic attack when I asked for the part number. He gave me a bunch of units all ranging from $100 -$500. I work around a body shop, so it would be convenient to go through them. But I'd rather just order it straight.
      1stvwparts.com has a partial part number match. Not sure how much the last three matter. (5K0937087C000)
      BoraParts doesn't list anything anymore.
      Couldn't find anyone else.
      What do you think? I'll track one down after I double check my parts.
      Hopefully this will solve my euro tail parking light issue, too.
    25. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      04-28-2011 09:02 PM #25
      I got mine from Paul a Keffer VW on here. He had no problem getting it and to me in less then a week.
      1991 200 20v
      1991 200 20v Avant
      YouTube
