VWVortex.com - 2.5 Intake Timing Chain Issues
    Page 4 of 6 FirstFirst 123456 LastLast
    Results 76 to 100 of 146
    Thread: 2.5 Intake Timing Chain Issues
    1. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      01-28-2012 07:35 PM #76
      From what I have read on vortex it is the upper guides that go first. I'm wondering if the issue was engineered out with newer parts.
    2. 01-29-2012 02:05 AM #77
      Is this only a 05.5 - 06 Jetta issue? What about the 2006 Rabbit? Has anyone had problems with this model? Just wondering because I have an aging 2006 Rabbit and would like to avoid something like this. Thanks!
    3. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      01-29-2012 07:40 AM #78
      Quote Originally Posted by VAGMeister View Post
      From what I have read it is an issue with the first 2.5l engine and was engineered out in 07 I believe. I am in the same boat as you, I want to fix it before something happens.
      I do beleive it affects the rabbit too, but I am really not sure.
    4. Member mhjett's Avatar
      Oct 16th, 2000
      Northern Virginia
      '08 VW Jetta SE 2.5
      01-29-2012 09:24 AM #79
      Quote Originally Posted by stupakjim View Post
      Are you sure? The upper guides are what goes first on VR6s, especially early VRs, but I thought it was a sprocket that wears on the 2.5L, causing chain stretch.
      2008 VW Jetta SE 2.5
      1995 VW Jetta GLX VR6 [07.2003 - 03.2012]
    5. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      01-29-2012 11:22 AM #80
      I am not to sure, I hope a 2.5l guru will find this post.
    6. Member
      Apr 19th, 2007
      CT
      01-29-2012 11:22 AM #81
      Quote Originally Posted by indybuell View Post
      Definitely call VW of America and report the issue. The more of us that report it, the better chance of a recall or a TSB or some slim chance we can get our money back.
      Reporting to VW is the best chance of getting some immediate help with your car. The best thing that could happen for 2.5 owners is for everyone with a timing chain issue is to report it to NHSTA.
      vortex member VW Redux had a DSG transmission fail at just over 600 miles. Search for his posts to read about what he did. His reporting to NHSTA resulted in a government campaign as well as one by VW resulting in hundreds of people (if not more) getting repair reimbursements and causing VW warranty the DSG to 100k miles.
    7. Member alwaysdutch's Avatar
      Oct 19th, 2011
      Marietta, GA
      2005.5 Jetta 2.5 Package 2
      01-29-2012 12:18 PM #82
      I have gotten the famous problem with my 2.5-05 engine at 93K. However, when the CEL came on, I was already too late.
      The transmission needs to come off to replace everything, so that is something you need to consider paying for. In most cases, if not all, the engine needs to come out to replace the chains. I ended up buying a new motor and replace it myself due to the cost involved.
      I agree that the timing problem should have been a warranty issue, but VW knows it cost a lot of money to replace that.
      **- 2005.5 VW Jetta Package 2 with 2008 2.5L -**
      BFI stage 2 transmission mounts
    8. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      01-29-2012 09:16 PM #83
      Is there something I can do before its too late??? Will replacing both tensioners, guides, and chain solve the issue? Should I replace the gears too?
      Sep 30th, 2009
      GA
      Jetta
      01-29-2012 11:35 PM #84
      Like it was said earlier... it is a pretty big job... drop the trans etc. I don't know if that will solve everything but it is a shot lol.
      Hopefully this doesn't happen to me. But I will be changing out my clutch, so while i'm doing that I may spend the extra afternoon changing that stuff out.
      C2 tune, Peloquin LSD, .717 TDI 5TH gear swap, AWE exhaust, BSH CAI, H&R street sport coilover + 25mm RSB, neuspeed short shifter, 17x8 BBS RGR.
    10. Member alwaysdutch's Avatar
      Oct 19th, 2011
      Marietta, GA
      01-30-2012 12:26 AM #85
      From what I have heard and read, the gears or sprockets are not set at the right torque, which eventually creates the jump of the chain. A dealership as well as those like myself had to take the engine out to either replace the parts so yes, it is a big job.
      Find out from your mechanic how far he has to go to replace the waterpump and go from there.
    11. Member
      Sep 30th, 2009
      GA
      Jetta
      01-30-2012 08:33 AM #86
      Yeah, if this ever happens to me I would just swap an 08+ engine.
    12. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      01-30-2012 10:20 PM #87
      http://www.reesphotos.com/VW/ This is the story of another guy...
      Lot of good info.
      "Since the only real problem was that the worn timing chain sprocket allowed the timing chain to "slip 3 teeth", replacement of the worn sprocket, timing chain, and timing chain tensioner and guide components should have been all that was required."
    13. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      01-31-2012 04:42 PM #88
      Thank you to Ecs Tuning,
      You will need a timing chain kit, ES285903 (adjuster), ES285925 (gear) in order to correct the issue BEFORE it beomes a major problem.
    14. Member
      Jul 31st, 2011
      Brampton, Ontario
      2007 Volkswagen Jetta Wolfsberg Edition
      02-03-2012 11:54 PM #89
      Just wondering if anyone actually had their timing chains, guides, tensioner pre-emptively replaced! If so how much did it cost you? I'm also thinking of replacing my timing chain etc before i fall victim to this manufacturer defect. Another difficult thing i've encountered is finding someone who is willing todo the work. Any reputable vw mechanic i go to tell me that i shouldn't worry about the timing chain til i get closer to 200,000kms which i think is about 160-180 miles but in my opinion i think they're guaging this based on their experiences with MKV VR6 dual chain set up. Anyways if you've gotten the work done pre-emptively then please post how much you paid all in all for us who are interested in going that route as well.
    15. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      02-04-2012 08:06 AM #90
      Quote Originally Posted by Schwarz_Jetta View Post
      I am in the same boat as you. I priced the parts at ecstuning, looking at a little over $700 in parts. I have 83,000 miles on my motor, I am going to send out a sample of my oil to get checked out and take it from there. I am just going to go the route of driving my car till the pistons kiss the valves, then find an newer motor/ecu and get that installed.
    16. Member alwaysdutch's Avatar
      Oct 19th, 2011
      Marietta, GA
      02-04-2012 01:03 PM #91
      $700 in new parts eh? I got my 17K '08 engine for $1,000. I guess it depends a lot on how long you want to drive your car or trade it in when that happens.
      VW of America is aware of this problem (although they don't claim that), and will give you a $1,500 voucher towards a new Jetta.
    17. Member mhjett's Avatar
      Oct 16th, 2000
      Northern Virginia
      '08 VW Jetta SE 2.5
      02-04-2012 02:25 PM #92
      If you have a 2007, why would you do this? From all I've seen, the issue only affects certain '05.5-'06 cars.
    18. Member mhjett's Avatar
      Oct 16th, 2000
      Northern Virginia
      '08 VW Jetta SE 2.5
      02-04-2012 02:27 PM #93
      Lot of good info.
      Btw, the guy who made this website fails to mention what car and engine this is, but that is a 24v VR6, not a 2.5l five-cylinder.
    19. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      02-05-2012 07:15 AM #94
      I was on the phone with vwoa for 45 mins, got absolutely nowhere, not even a voucher. I talked to the supervisor who informed me that there is no known issue and there was nothing they could do.
    20. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      02-05-2012 07:19 AM #95
      Quote Originally Posted by mhjett View Post
      "Check carefully before purchasing a Volkswagen with a chain driven overhead camshaft engine - and this includes almost all VW engines, and some Audi engines. I am relating my experience here to alert others to the problem."
      This guys situation in very similar to the 2.5l issue, good catch on the picture.
      I'm just going to drive my 2.5 till it goes, then put a newer 2.5 in it, cheaper than buying a new car or buying a used one, I like the mk5 jetta over the mk6, although I havent driven or been inside one. By that time I may have extra money and possibly put a turbo kit on
    21. Member mhjett's Avatar
      Oct 16th, 2000
      Northern Virginia
      '08 VW Jetta SE 2.5
      02-05-2012 10:43 AM #96
      The bolded part is not true. All the four-cylinder engines, except for the TSI, have belt-driven overhead cams. Not to mention that the non-hardened sprocket issue seems to have only affected a small batch of parts on certain engines.
    22. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      02-05-2012 11:55 AM #97
      I'm not going to argue with you over some article that I posted to inform others with this issue. You are right... I'm going for a long walk over a tall cliff.
    23. Member
      Jul 31st, 2011
      Brampton, Ontario
      02-05-2012 11:56 AM #98
      I would be extremely relieved if it truly affected only the 2005.5-06, but unfortunately i've got nothing but mixed reviews. Some say that it only affects those model years, then some say it affects the BGP/BGQ motors, and then others say that it affects the 2005.5-early 07 models. But so far, knock on wood, i've only seen this happen to the 05.5-06 models.
    24. Member mhjett's Avatar
      Oct 16th, 2000
      Northern Virginia
      '08 VW Jetta SE 2.5
      02-05-2012 03:48 PM #99
      I was just pointing out some facts. Not every article you stumble across on the Intarnetwebz is gospel.
    25. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      1k-m-cbta-02q-PTE5858
      02-05-2012 05:30 PM #100
      based on what we have seen, the issue only affects the early engines (05.5 and 06s)
