Got my car back from the dealer last night with two issues corrected.
1) Initially, I brought the car in to address a squeal when I started the car. Many people thought it may be the belts, tensioner or water pump. It turns out my 2011 CCTA MKVI GTI already had the latest revised water pump (latest version includes metal fins instead of plastic fins in the pump). The startup squeal happened to be the starter. They replaced the old starter (part number 02M911023G) with a brand new starter (part number 02M911023GX). Now the car starts up like new, no squeals at all. I forgot how nice it was to hear the engine noise and not a squeal.
2) A few days before my appointment the temperatures dropped below 40 degrees and I experienced the well-known and dreaded "Clutch release noise/chirp/squeak/hooo" noise when engaging the car in 1st gear or reverse. Without a doubt I knew it was my slave cylinder & throw out bearing (TOB). A few months back I installed the latest South Bend Stage 2 Daily Driver Silent Design Clutch Kit and thought I should replace the TOB while the transmission was down. Turns out the TOB that was installed was the older version which came in the 2010 models and was prone to this noise (part number 0A5141671E). For some reason, ECS still to this day sells this outdated part number but under the manufacturer name TRW even though all VW / Audi TOB's are supposedly produced by LUK. I made sure that my VW dealership ordered the latest revised TOB (part number 0A5141671F) to fix this issue. I'm happy to report that even though the temperatures are in the mid 40's today, I have had not one peep from the TOB. I will circle back to confirm 100% as soon as the temperatures drop well below 40 degrees (when I first noticed the issue).
So note to self, avoid installing or replacing your TOB with this ECS part:
http://www.ecstuning.com/Volkswagen-...tch/ES1831913/
Install or replace your TOB with this ECS / Dealership part:
http://www.ecstuning.com/Volkswagen-...tch/ES1851810/
All in all I want to let everyone know that all of this work was warrantied and free of charge to the customer. Below is my recent statement of work with "NoCharge" for Total-Customer.
Feel free to use this customer copy to show your dealerships that the work should be warrantied with no cost to you.
