VWVortex.com - Koni STR.T (orange) review
    Results 1 to 5 of 5
    Thread: Koni STR.T (orange) review
    1. Member SGLoki's Avatar
      Dec 12th, 2004
      The Ham
      Too Many.
      12-31-2010 02:36 PM #1
      For review : Koni STR.T absorbers, combined with neuspeed sport coils (one coil cut up front.)
      Old stuff for benchmark: Bilstein TC absorbers with stock springs (rear springs sagged)
      I am comparing to the Tc's which are a bit stiffer than stock.
      TIRES: 185/70/R13 (balloons)
      REVIEW
      KONI's w/ neuspeeds:
      Lowered 2-2.5" total
      Bound feels a lot stiffer than the TC's, by 20-25% estimate. Rebound seems about equal to bound, they jump back quick and the car doesn't float or feel malibu at all.
      Semi Rough road (washington standards) gets chewed up and spit out, like any mk1 you can still feel the road very well, but my immediate impression is that they actually handle the semi-rough roads a bit better than the TCs did Probably due to the bad springs.
      I imagine the road might feel pretty crap if I did not have balloon tires on the car, they are in a sense the first part of a suspension feel, so keep in mind they might be bone rattlers on low profiles.
      Smooth road: who could ask for more? it feels like the car is on rails, all it needs is a front lower stress bar (already have a 28?mm rear sway)
      Potholes and super rough road: as can be expected with a lowered car the car hates it, the travel is short and can't seem to handle large bumps at a decent speed. I have not bottomed the car. My bump stops are about 1/4 of the original height and I have not hit them while rallying around on the roads.
      Corner dive isn't so bad while cornering hard, in fact it is a vast improvement over the TC's. I regularly take a 90 degree turn at the posted speed limit without tapping my brakes, with the new suspension I have to relearn how to enter the corner, the suspension used to bounce/roll and cause front end slide a bit, today after an alignment I took the corner once and it felt like it was glued to the ground. (before the alignment it had slight under steer slide.)
      Note: I can fit a pack of regular length cigs under the oil pan without touching it... I'd estimate it is between 4" and 4.5" off the ground.
      Conclusion: The Koni's are awesome, especially for the price. If you can pick up your coils used like I did for $50, you can spend less than racelands, and have a good performing static drop.
      Sorry no install pics, they are on my buddy's camera and he has yet to email them. They were crap pictures anyway. Hope this review helps guys.
      Keep dubbin.
    2. Member SGLoki's Avatar
      Dec 12th, 2004
      The Ham
      Too Many.
      01-01-2011 05:21 PM #2
      Bumping this because at least 4 or 5 folks wanted a review of these.
      Update: the GF used to get very car sick in the rabbit and she says the stiffer suspension is a lot better. It's jarring to hit bumps, but there's no bouncy-malibu floating after a bump.
      Performance wise, it really is day and night, and the more I drive it the more I want to drive it... I actually want more HP now, the suspension will handle it better.
    3. Junior Member
      Sep 29th, 2008
      MI
      84 Jetta GLI coupe, 91 Jetta Diesel, 73 Honda N600
      01-01-2011 08:00 PM #3
      thank you sir
    4. Member early westy rabbit's Avatar
      Jun 9th, 2010
      texas
      1980 rabbit 2 door carbed 1.6 4-speed
      01-02-2011 03:52 PM #4
      ive been running the str.t's for a little while now with h&r sports and 155 80 13's and i too like them alot.
      good acurite review loki
      wku88omerta
      "Exactly! You should have to wear that badge of dishonor like a scarlet letter. A big 'A' for adulterating this forum with your mk4 filth lol."
    5. Junior Member krinkov's Avatar
      May 9th, 2005
      San Francisco
      07 Corvette, 98 Subaru 2.5rs, 84 GTI
      05-26-2011 10:39 PM #5
      hey thanks for the review! I was looking to run these on Neuspeeds Sports as well so this helps alot. BTW, are they full strut assemlies or is it cartridges? thanks!
    « Back
