The fuel pump unit in a 2.5 Eurovan petrol engine is a in-tank unit. The tank access panel is located between the front seats, just to the passenger side of the e-brake handle. You do *not* need to remove the seats to access, test and replace the tank.
[b] DIY for replacing the fuel pump.
1. While in the center of the van, looking forwards between the front seats, pry up the front carpet section in the middle of the seats. You're aiming to find a black metal circular cover, held in by three philips screws. You may need to remove the trim from the e-brake handle.
2. Now that you can see the cover, you should be able to see three 13mm bolts that are holding the e-brake handle. I decided to remove these bolts so the handle could be moved out of the way for better access.
3. Now the carpet is folded forwards, you can remove the three philips head screws on the black cover. I decided to 'split' (rip) the carpet very slightly, where it's most narrow just behind the e-brake handle. This allowed me to really move it all of the way clear. Anyway, remove those three screws, and lift the cover off.
4. Now you can see the top of the fuel inlet/outlet cover. There's two fuel hoses (1 in, 1 out) and a single 4 pin connector. Remove all of these.
FOR STEPS 5 UNTIL THE END, THIS IS THE SAME JOB AS A Mk3 GOLF/JETTA.
5. The cover is secured by the large black plastic ring. You will see that it has ridges on the top of it. If you have a large enough pair of pliars, or the Dealer tool, use them, if not get a large flathead screwdriver and a hammer. Place the flathead against a comfortable to reach ridge and hit with a hammer to start to move the ring anti-clockwise just as you would undo a nut from a bolt.
6. Continue to move the ring around until it frees and can be removed fully. Once it's undone, you can lift it off, and then remove the cover. The seal will likely come with it.
7. You now have the cover removed, but it's still attached to the actual fuel pump sending unit. This is secured to the bottom of the tank by 4 tabs. To remove it, simply grab it and turn it. I think it's clockwise, but don't remember.. but it's one way or the other.
8. Once it's twisted clear, you can remove the cover, the hoses, the fuel level sender, the wiring and the pump sender all in one piece. It's a little tricky to remove all of this through the hole in the fuel tank, but do the cover/level sender first, then the sender pump last and it'll all fit.
Do the reverse to install, making sure to have the seal installed before the cover goes in.
REPLACEMENT FUEL PUMP SENDING UNIT IS THE EXACT SAME AS A Mk3 Golf/JETTA 2.0 1993-1996, amongst others..!
1H0919651P is the part number for the actual fuel pump unit if anyone needs it in the future.
The ground checks out, and a resistance check on the wires appear okay too. Damn.
