VWVortex.com - Kitchen Countertops other than granite...
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 75
    Thread: Kitchen Countertops other than granite...
    1. Member imallstressed's Avatar
      Jan 26th, 2003
      Bucks County, PA
      11 Q5 2.0T, B7 S4 2.7T, B7 A4 2.0T, 99 Dodge Ram 2500
      01-11-2011 09:14 PM #1
      Hi. We are planning a new kitchen in the near future. I was exploring different options for countertops ie. recycled glass, concrete, llimestone, soapstone,and so forth. What are some of the advantages and disadvantages of each type of countertop? Price is also somewhat of a factor. I know of a local place where I can choose from a bunch of colors of granite for less than 50.00 per sq. ft. installed. We wanted something more different, though.
      Also, we are going with a more modern look in the kitchen. Cabinets will be similar to a slab or shaker style.
    2. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      01-12-2011 02:48 AM #2
      Personally, I don't like granite. It's cold. It breaks crystal if you knock over a glass. It screams the nuveau riche McMansion cliché. I prefer Corian.
    3. Senior Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      '15 STI & '16 R
      01-12-2011 09:36 AM #3
      When we were building our house we originally planned on putting on Corian but the builder didn't have a color we liked and due to pricing they had from their granite supplier it turned out to be cheaper to have granite put in.
      As for the McMansion cliche- there are 100s of varieties of granites in all types of colors but you commonly see the same 10 or so colors. Just choose a more unique one.
      Recycled glass would be pretty cool.
    4. Member
      Dec 17th, 2007
      Littleton, CO
      01-12-2011 09:46 AM #4
      We put Corian in our kitchen and love it. We were going to go with the granite and like the look of the Corian better because it gives great updated look, but not so cookie cutter.
    5. 01-12-2011 10:50 AM #5
      My Kitchen has soapstone, which is very dark gray.
    6. Member Grinder's Avatar
      Feb 6th, 2004
      Converts, '77 super beetle and '07 Eos; '06 Odyssey; 2015 TDI Sportwagen; 2016 Golf R
      01-12-2011 11:19 AM #6
      Our Kitchen also has soapstone. Ours has lots of lighter tremolite in it making it easier to scratch but lots of veining. The scratches seem to disappear when oiled or sooner. A few chips from dropping things have stayed around but are easy to live with. I think that it would chip more if we had an undermount sink.
      Not sure that it has a modern look though.
    7. Member EuroJetta's Avatar
      Nov 21st, 2001
      BC, Canada
      '02 A4 Avant
      01-12-2011 11:39 AM #7
      If you're thinking about recycled glass, look at Icestone. Some really nice stuff from what I've seen.
    8. Member imallstressed's Avatar
      Jan 26th, 2003
      Bucks County, PA
      01-12-2011 04:08 PM #8
      Update... After hours of reading online last night and talking to people, I have decded to rule out concrete. I was quoted over 150 per square foot!!!!
      I read a lot about soapstone and talked to a company that sells, fabricates and installs it today. There are some things about soapstone that I really like. You can put a put directly from the stove on it. It is impervious to staining, therefore it doesnt have to be sealed. The oil is to only alter the color. I like the grey tones with the veins in them. Apparently there are black and green shades, also. I would deinitely want to go with an undermount sink. I like the look of the stainless undermounts. Apparently when you scratch it, you are only removing the oil from the surface and you can re-oil it to hide the scratch. From what I've read, deeper scratches can be sanded out.
      I am going to look at some soapstone within the next couple of weeks, and I will try to come up with some sort of decision then. I have yet to actually see it in a real live kitchen.
    9. Banned sirswank's Avatar
      Mar 17th, 2003
      RI
      '07 Jetta 2.0t
      01-13-2011 09:13 AM #9
      we were looking at countertops and decided that we would do a 2-part countertop system.
      corian is great, but not heat resistant. however, it does not need ANY maintenance.
      we will use this for all countertops around the sink and prep areas.
      silestone is heat resistant, and while expensive, less so than granite. it too needs far less maintenance than granite. we will use this on either side of the cooking area.
    10. Member
      Dec 17th, 2007
      Littleton, CO
      01-13-2011 09:43 AM #10
      Corian does scratch, but they sell buffer pads at HD and other places and the scratches come out like nothing. About being heat resistant, unless you are sitting a pot right on the counter without a towel or something, it's going to be fine.
      just fyi
    11. Senior Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      '15 STI & '16 R
      01-13-2011 10:18 AM #11
      Quote Originally Posted by sirswank View Post
      Huh? You have to seal granite counter tops once, maybe twice a year. It takes 10-15 minutes.
    12. 01-13-2011 10:19 AM #12
      Not to dissuade you from other choices but in my opinion the best countertop material is the man made quartz products from a variety of manufacturers. If you are trying to get something that doesn't "look" like granite they have some pretty cool options that really have a nice style to them.
      BRENT
    13. Member Grinder's Avatar
      Feb 6th, 2004
      01-13-2011 01:06 PM #13
      With soapstone, the darker, the more scratch resistant. You do scratch more than the oil, but oil hides it well. A chip could also be repaired by mixing epoxy and stone dust, then sanding out. We are happy with ours, especially that warm and soft look that it has without a high gloss and lots of veining and things going on.
    14. Member titleist1976's Avatar
      Feb 25th, 2002
      Mini R55 S, Mazda Miata NA, Honda Pilot
      01-13-2011 01:21 PM #14
      We love our silestone.
    15. Member
      Jul 17th, 2003
      Kingston, Jamaica MA
      01-13-2011 01:32 PM #15
      We just went to Granite on a new island and redo our formica counter tops. we bought a real unique slab. Thing looks awesome.
      We looked at recycled materials for tops and they wanted like 90 bucks a sq ft for ground up tires and what not. We passed
      Our Granite was like 95 bucks a sq but it was well worth it. Definatley added value to the house
    16. Member audicoupej's Avatar
      Nov 5th, 2004
      Binghamton, NY
      2004 R32
      01-13-2011 01:58 PM #16
      There are several options to recycled glass.
      As was mentioned above, Icestone makes a cement based recycled glass counter top.
      It is basically terrazzo (poured marble), which has been around for thousands of years. It was originally used as floors (and still is).
      Terrazzo is either cement based (as Icestone) or epoxy based.
      The cement based can scratch (use a cutting board) and is slightly porus so it does require some maintenance like granite. However it should handle hot items with ease although I'd still recommend a heat trivet regardless of what material you decide to use since the sealers can be affected by heat.
      My family has a commercial Tile and Terrazzo business so when I bought my house I decided to make an epoxy terrazzo countertop. The epoxy is anti microbial and can be had in any color you want. The aggregrate in typical terrazzo is marble chips. Sometimes mother of pearl (crushed seashells) and recycled glass is used as well. There are many various materials that can be used for the aggregate (marble, glass, porcelain, granite, quartz, metals, even some glow in the dark aggregates).
      I chose to used mother of pearl and mirror in mine. The mother of pearl has various white, blue and green shades of pearlescents. The mirror just looks good since it reflects indirect lighting well and gives it a sparkle.
      Here is my crude example:
      If you have any questions PM me. I think no matter what you get it will change your kitchen dramatically and you will enjoy it.
      JEMM Auto Detailing: Cars, Trucks, Motorcycles, Planes, RVs, Bathtubs, if you pay me I will buff it
      John
    17. Senior Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      '15 STI & '16 R
      01-13-2011 02:21 PM #17
      Quote Originally Posted by audicoupej View Post
      That looks real nice.
    18. Banned sirswank's Avatar
      Mar 17th, 2003
      RI
      '07 Jetta 2.0t
      01-13-2011 06:19 PM #18
      prolly, but thats still more than i care to do. also, doesn't the frequency of sealing depend on how much you use and wash it? with kids, that can be a lot.
    19. Member audicoupej's Avatar
      Nov 5th, 2004
      Binghamton, NY
      2004 R32
      01-13-2011 08:15 PM #19
      Thanks.
      I like it but I'm not satisfied. I plan on refinishing them this year to improve the overall appearance. The good thing is I've had it installed for 2+ years and so far so good.
      I made them out of extra materials sitting around the shop and finished them with grits normally used on floors. The final grit was 120. I plan on refinishing up to somewhere in the 1000-3000 grit range.
      John
    20. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      01-14-2011 01:03 AM #20
      That's entirely personal taste. I don't care how unique it is, I just don't like the look of granite and I don't like working on the surface. If I were expecting to sell my house, I'd use granite because that is what people expect in a high end kitchen. I have white corian. It's the look and feel I like. I also like butcher block but that's a lot more care & feeding than corian.
      My range has cast iron enamel grates on the whole cooking surface. I really have no need to ever put a glowing-red pot on the counter.
    21. Geriatric Member spockcat's Avatar
      Jun 4th, 2003
      West Coast, not that west coast. Bay area, not that bay area.
      11 328i Touring, 16 Colorado Crew, Versys, 2017 Barracuda
      01-14-2011 07:42 AM #21
      Huh? We've had granite in our kitchen for at least 10, maybe 15 years. We've never done anything to it other than normal cleaning. It still looks as good as the day it was installed.
      Touareg Audio Accessories - Keyless Start - Paddle Shift
      If you use Tapatalk, you aren't seeing the whole message. Tapatalk shortens GIFs, cuts URLs and deletes signatures.
    22. 01-14-2011 11:08 AM #22
      Quote Originally Posted by imallstressed View Post
      I'm shocked, we got our concrete counters for $65 sq/ft installed with all plumbing hook ups done. Granted we did find a guy that had only had his business for about a year but I would suggest shopping around a bit more if you like concrete.
      Dale GT: AllHighOnLife
      1991 BMW E30 Touring
    23. 01-14-2011 07:52 PM #23
      I have no idea how durable this is but I like the look a lot
    24. Member unimogken's Avatar
      Jan 19th, 2005
      South of Jazzydub, WA
      6 Tap Kegerator
      01-14-2011 09:48 PM #24
      A buddy of mine just redid his kitchen and used a product called Paperstone that is manufactured in the town that he lives in.
      He bought his as factory seconds and saved a bunch and was able to parts of the kitchen that he wasn't going to. He also got enough material to make counter tops for his workbenches in his garage.
      I really liked the look and feel of it and I took a sample piece back to my wife and she really liked it also!
      I really wish everyone would update their location in their profile!
      Someone buy my car already!!
      Always looking for free firewood to feed my hungry wood stove!
    25. Member
      Sep 3rd, 2001
      south jersey
      01-15-2011 05:23 PM #25
      poured concrete looks dope.
