VWVortex.com - Osir/ Aluminum shift paddle installation~ with detailed step by step
    Results 1 to 4 of 4
    Thread: Osir/ Aluminum shift paddle installation~ with detailed step by step
    1. Member spoon8818's Avatar
      Jan 28th, 2004
      GTi 20th Anniversary--> 2010 A4 B8 Avant Quattro
      01-13-2011 12:34 PM #1
      Hey folks,
      I did a write up, please enjoy.. I knew someone did this before, but I didn't really get the full picture from that write up, so here's another one.
      Pleaes forgive my English if there's any confusion! Tried my best to explained....
      Please go to MediaFire to download the WORD file.
      VIRUS FREE !
      http://www.mediafire.com/?4n90wwk59e22fdt
    2. Member Daniel's Avatar
      Sep 7th, 2003
      Scottsdale
      2009 Audi A4 2.0T
      01-15-2011 04:53 AM #2
      no ones gonna wanna download some sketchy sh1t
      just post it man
    3. Member spoon8818's Avatar
      Jan 28th, 2004
      01-16-2011 11:15 PM #3
      Tried before. No luck
      Anyone download it first and post for me?
    4. Member spoon8818's Avatar
      Jan 28th, 2004
      01-17-2011 12:31 PM #4
      Hope it works this time~~
      Audi A4 B8 Osir Aluminum Shift Paddle Installation Guide
      Tools Needed:
      - Torx 20, Torx 30 screw driver
      - a really small philip screw driver
      - long nose pliers (regular pliers will do the job)
      Time Needed: 30 minutes
      * Please disconnect your battery before disconnecting air bag.
      STEP:
      1. Turn your steering wheel 90 degree to reach 2 T30 screws behind the wheel that secure the air bag. AUDI design a space for this job.
      Tip: turn your steering wheel first, then disconnect battery. Repeat again for second screw.
      2. Carefully remove your air bag, there is another plastic ring where the air bag sits on, you need to remove that as well to be able to slide out the steering control modules. DON’T’ SCRATCH YOUR STEERING WHEEL.(I used a towel to hold the air bag without disconnecting the harness, don’t want to have faulty code later on.)
      3. Unscrew T20 screw to remove the shift paddle, and also disconnect the wire indicated in my photo to separate the shift paddle assembly.
      4. Please gently remove the paddle, you don’t want to lose that small spring. Once it’s separated, this is how it looks like inside. Please do not lose the little pin and the small spring.
      5. Reverse above steps, and get a six-pack for celebration!!!!
