VWVortex.com - VAG-COM/VCDS Questions
    Results 1 to 23 of 23
    Thread: VAG-COM/VCDS Questions
    1. 01-13-2011 02:31 PM #1
      Hi,
      I have a 2008 VW JETTA MKV 2.0T WOLFSBURG EDITION
      I want to do the following;
      -When locking doors turn off honk to only blinking lights.
      -Turn off daytime running lights (Will this remove light in dash as well?)
      -Turn off Tire pressure monitoring system light in dash due to aftermarket wheels.
      -Enable windows up & dn on keyless entry.
      -Turn off seat belt noise.
      -Power steering assist adjust.
      What are some other cool common things can do? I have no fog lights, no memory seats, no euro switch.
      Can someone send me the link(s) of items I need to do the following above? It's just a usb cable, software from your site, & need to have a lap top correct? I want the cheapest option.
      Can I get this under $250?
      Can I resale this later to someone else?
      Thanks,
      Vince
      08 Jetta V 2.0T DSG w/ many modifications
    2. Junior Member TheRamon's Avatar
      May 21st, 2009
      The Netherlands
      01-13-2011 03:24 PM #3
      Almost all your questions are answered here:
      http://www.ross-tech.com/vag-com/cars/Golf5.html
      I'm not sure if the blinker and DRL settings are different on US-spec cars but for the TPMS:
      17-Instruments>>Adaptation>>Ch. 61 and subtract 512 from the value you find there.
      For the seat belt warning, check this:
      http://forums.vwvortex.com/showthread.php?1649757
      For the power steering:
      44-Steering assist>>Adaptation>>Ch. 1. A higher value means lighter steering (max. 5), lower means stiffer handling.
    3. Member Hi-Speed's Avatar
      Apr 3rd, 2008
      Goldsboro, NC
      08 GTI, 02 Jetta TDI, 73 Mach 1
      01-13-2011 03:36 PM #4
      All those requests on you list can be accomplished. If you are not looking to keep the Vag-Com cable, I think the best thing to do would be to look for a local performance shop. Call them up and see what they will charge to take care of what you have in mind. If you prefer to buy your own then the cable listed at the following link would be the chepest you can buy. http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM
      This cable can either be upgraded later or it can be sold.
      If you can afford to screw up twice, why can't you afford to do it right the first time?
    4. Member
      Jun 1st, 2003
      Dearborn Heights, MI
      2005.5 MKV TDI
      01-13-2011 03:41 PM #5
      Power Steering Assist (adjustment) most likely not available on a 2008.
      The Controller was set to a "fixed" value during the 2006 production cycle.
      Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
    5. 01-13-2011 04:33 PM #6
      If decided to buy. How much can I sell it used for? The new buyer just needs the cable? Wont need to pay for register for software?
    6. Member Josh Sp's Avatar
      Aug 15th, 2010
      Ashland, ME
      06 Jetta 2.0T
      01-13-2011 05:18 PM #7
      Seriously man, all these questions are answered on ross-tech's website...read the FAQ.
      But yes, the license is "built in" to the cable...no additional license purchases necessary.
    7. 01-13-2011 06:07 PM #8
      Sorry.
      I just want to make sure it can do the following;
      -When locking doors blinking lights instead of honk.
      -Turn off daytime running lights/remove DRL light in dash.
      -Enable windows/sunroof to roll up & dn using keyless entry.
      Is it worth buying and resale it or go to a local tuning place and get it done?
      How much would I get reselling it?
      Thanks.
    8. Member Atömic's Avatar
      Jul 30th, 2010
      Casper, WY
      08 Rabbit 2.5T
      01-13-2011 06:25 PM #10
      Quote Originally Posted by 2.0t0886 View Post
      YES, can even be done through the MFD stalk.
      YES
      YES
      YES
      - Pete
    9. 01-13-2011 06:37 PM #11
      Thanks.
      As far as Tire pressure light do you do this only in module 19. I seen some mention module 65 as well?
      The coming/leaving home feature. Will that work w/o a euro switch?
    10. Member Atömic's Avatar
      Jul 30th, 2010
      Casper, WY
      08 Rabbit 2.5T
      01-13-2011 06:41 PM #12
      Should be able to find quick under the VCDS forums with a quick search.
      I don't remember the two off bat, but yes there are two places you have to change:
      1) Removes the actual "DRL" light on the dash.
      2) Removes the warning in the MFD IF you have it.
      Pretty sure you need the Euro switch w/ the coming home feature.
      Good Luck!
      - Pete
    11. 01-13-2011 06:58 PM #13
      Both Coming Home and Leaving Home can be enabled with a standard US non-automatic switch, though the automatic switch is what was intended. Each must be activated in the Central Electronics controller with a VagCom.
      When using a non-automatic switch, simply leave the light switch in the "on" position all the time. Coming Home and Leaving Home will both work as intended in this position. Once the switch is turned to the "off" position, only the Leaving Home feature will work.
    12. 01-13-2011 07:00 PM #14
      That was from the Mk5 euro switch thread
    13. Member
      Jun 1st, 2003
      2005.5 MKV TDI
      01-14-2011 03:38 PM #15
      The CAN Cables are transferrable, but you would not want to sell yours once you see what it can give you, over time.
    14. 01-14-2011 11:43 PM #16
      Quote Originally Posted by liketorow View Post
      Why can´t enable CH-LH in my Jetta MK5 2010, such I had coding the central electric module and don't make errors at scan, and after to install a euroswitch with autolamp.. Help, please!
    15. 01-17-2011 12:32 AM #17
      Went to a tuning place and got the following done for $20. Happy about that.
      -Turn off daytime running lights.
      -Turn off Tire pressure monitoring system light.
      -Enable windows/sunroof up & dn on keyless entry.
    16. 01-18-2011 11:32 PM #18
      I do all the changes you recommended, but anyway doesn't work, i think that maybe change de set lights standard (EPROM) for GTI mk5 (ROW) could make funcionality.. and what a hell! now appear a message like this:
      Tuesday,18,January,2011,22:19:49:60804
      VCDS Version: Release 10.6.0
      Address 09: Cent. Elect. Labels: 1K0-937-08x-09.clb
      Control Module Part Number: 5K0 937 087 B HW: 5K0 937 087 B
      Component and/or Version: BCM PQ35 H 008 0019
      Software Coding: 6D200B3F902F3AE40008000000000D200500008651008D605C 8020000000
      Work Shop Code: WSC 14470 993 75790
      VCID: 346C99262E53
      2 Faults Found:
      00984 - Left Tail Light (M4)
      010 - Open or Short to Plus
      Freeze Frame:
      Fault Status: 01101010
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 136
      Mileage: 13566 km
      Time Indication: 0
      Date: 2014.14.25
      Time: 21:32:09
      Freeze Frame:
      Term 15 On
      Voltage: 12.05 V
      ON
      ON
      OFF
      OFF
      OFF
      00985 - Right Tail Light (M2)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 136
      Mileage: 13566 km
      Time Indication: 0
      Date: 2014.14.25
      Time: 21:32:09
      Freeze Frame:
      Term 15 On
      Voltage: 12.05 V
      ON
      ON
      OFF
      OFF
      OFF
      and i tried to restore the initial long coding from central electric, check the rear lamps and don't find how to revert this, also the xenon range don't make down and up the lups -oops-
      have an idea 2.0t0886 or anyone else, please?
      Thanks a lot for your assistance.
      Good Luck!
    17. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      01-21-2011 10:41 AM #19
      Are you using a genuine Ross-Tech interface bought from us or from one of our authorized distributors? If so, please contact us for assistance:
      http://ross-tech.com/contact.html
    18. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      03-27-2011 05:02 PM #20
      Andy:
      FWIW, I have seen the same fault codes as F33L reports above when diagnosing a friend's MK V GTI, and I do have a genuine Ross-Tech interface, running the latest firmware and software.
      Michael
    19. Member
      Jun 1st, 2003
      2005.5 MKV TDI
      03-28-2011 04:50 PM #21
      F33L is trying to use (most likely) Coding from the MKV Forum FAQ/DIY.
      He has a 2010 MKV, and transferring Coding from a pre-2010 Jetta to a 2010 Jetta just won't work.
      F33L should go into the DEBUG Folder on his installed VAG Software (Hard Drive on his computer), and revert all the way back to original coding. (same issues for pre-2010 GTI/Rabbits, and true 2010 GTI/Rabbits)
    20. Awaiting Email Confirmation 845ryders's Avatar
      Oct 31st, 2010
      845 City Of King's
      2007 VW 2.5 Jetta Wolfsburg
      03-28-2011 05:50 PM #22
      Quote Originally Posted by Tim Birney View Post
      agreed i just did my buddy's 2010 mk5 tdi cup. he had all mk6 electronics. was easy to do once i realized it i just went under a diy of mk6 all worked.
    21. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      1k-m-cbta-02q-PTE5858
      03-28-2011 08:24 PM #23
      based on OP. it is an easy thing to do.
      grab vag com and search
